- To:
- Subject: Re: [cgal-discuss] Visualize non-2-manifold object
- Date: Mon, 1 Jun 2020 09:04:31 -0700
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi Ali,
The vcpkg team at Microsoft has not yet released a port for CGAL 5.1; as you note, the current version in vcpkg is 5.0.2.
If you want them to upgrade their port, I’d suggest filing an issue here:
Cheers,
Adam
On May 31, 2020, at 6:56 AM, AliiAsgharii ( via cgal-discuss Mailing List) <> wrote:Hi Andreas,
I tried to upgrade CGAL using vcpkg. However, the version that vcpkg tries
to download and install is still the latest stable version of CGAl, version
5.0.2. How can I upgrade CGAL to version 5.1 which supports draw_nef_3?
In addition, the link for CGAL-5.1-examples.zip
https://github.com/CGAL/cgal/releases/download/releases/CGAL-5.1/CGAL-5.1-examples.zip,
does not work and could not find the examples.
I would be appreciated if you could give me some advice regarding this.
Best regards,
Ali
- Re: [cgal-discuss] Visualize non-2-manifold object, Adam Getchell, 06/01/2020
- Re: [cgal-discuss] Visualize non-2-manifold object, Maxime Gimeno, 06/02/2020
- <Possible follow-up(s)>
- Re: [cgal-discuss] Visualize non-2-manifold object, Laurent Rineau (CGAL/GeometryFactory), 06/02/2020
