- To:
- Subject: Re: [cgal-discuss] Visualize non-2-manifold object
- Date: Tue, 2 Jun 2020 08:52:23 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
The latet stable verison of CGAL is still the 5.0, don't bother filling an issue. If you want to upgrade to an early 5.1, you'll have to download the sources at https://github.com/CGAL/cgal.
Le lun. 1 juin 2020 à 18:05, Adam Getchell <> a écrit :
Hi Ali,The vcpkg team at Microsoft has not yet released a port for CGAL 5.1; as you note, the current version in vcpkg is 5.0.2.If you want them to upgrade their port, I’d suggest filing an issue here:Cheers,AdamOn May 31, 2020, at 6:56 AM, AliiAsgharii ( via cgal-discuss Mailing List) <> wrote:Hi Andreas,
I tried to upgrade CGAL using vcpkg. However, the version that vcpkg tries
to download and install is still the latest stable version of CGAl, version
5.0.2. How can I upgrade CGAL to version 5.1 which supports draw_nef_3?
In addition, the link for CGAL-5.1-examples.zip
https://github.com/CGAL/cgal/releases/download/releases/CGAL-5.1/CGAL-5.1-examples.zip,
does not work and could not find the examples.
I would be appreciated if you could give me some advice regarding this.
Best regards,
Ali
- Re: [cgal-discuss] Visualize non-2-manifold object, Adam Getchell, 06/01/2020
- Re: [cgal-discuss] Visualize non-2-manifold object, Maxime Gimeno, 06/02/2020
- <Possible follow-up(s)>
- Re: [cgal-discuss] Visualize non-2-manifold object, Laurent Rineau (CGAL/GeometryFactory), 06/02/2020
