- To:
- Subject: [cgal-discuss] Failure in PMP::corefine_and_compute_union
- Date: Mon, 8 Jun 2020 19:42:35 +1000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Sorry, title should be "Failure in...". Cut-n-paste in haste :-)
On 8/06/2020 7:40 pm, Giles Puckett wrote:
Hello all,
I have caught PMP (CGAL 5.0) failing to do a corefinement and union, after creating meshes out of simple shapes (cylinders and rect prisms). No self-intersection exception is thrown.
I have reproduced the problem by writing OFF files in double precision. A test program and files are here:
https://www.dropbox.com/sh/7sv3p0yxomsjrxn/AAC_xP_HH9EoMFajZSpK4m71a?dl=0
I built on Windows 10 using Visual Studio 2019 (tool set 1.42). The source is a modification of one of the PMP examples and it builds under that environment. CGAL is at 5.0. Let me know if you want me to raise an issue.
G.
- Re: [cgal-discuss] Infinite loop in PMP::corefine_and_compute_union since 4.14.2, Giles Puckett, 06/08/2020
- [cgal-discuss] Failure in PMP::corefine_and_compute_union, Giles Puckett, 06/08/2020
- Re: [cgal-discuss] Failure in PMP::corefine_and_compute_union, Trần Anh, 06/08/2020
- Re: [cgal-discuss] Infinite loop in PMP::corefine_and_compute_union since 4.14.2, Sebastien Loriot (GeometryFactory), 06/08/2020
- Re: [cgal-discuss] Infinite loop in PMP::corefine_and_compute_union since 4.14.2, Giles Puckett, 06/09/2020
