Re: [cgal-discuss] Infinite loop in PMP::corefine_and_compute_union since 4.14.2
- To:
- Subject: Re: [cgal-discuss] Infinite loop in PMP::corefine_and_compute_union since 4.14.2
- Date: Tue, 9 Jun 2020 16:24:52 +1000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Thank you for the insight. It was a loss of precision problem this end - coordinate transformations have pulled the two boxes apart slightly, most likely - if I take more care with precision they stay together and the problem goes away. Longer term solution for robustness may be to make sure they penetrate each other by a small epsilon.
Merci,
G.
On 8/06/2020 11:51 pm, "Sebastien Loriot (GeometryFactory)" ( via cgal-discuss Mailing List) wrote:
If the output of the union is non-manifold and the function is returning
false to indicate it.
The two boxes are sharing only an edge so the union will be non-manifold
and cannot be represented in a halfedge data structure (without creating self-intersections).
There is some on-going work to handle those operations with self-intersections but nothing is publicly available for now.
Best regards,
Sebastien.
On 6/8/20 11:40 AM, Giles Puckett wrote:
Hello all,
I have caught PMP (CGAL 5.0) failing to do a corefinement and union, after creating meshes out of simple shapes (cylinders and rect prisms). No self-intersection exception is thrown.
I have reproduced the problem by writing OFF files in double precision. A test program and files are here:
https://www.dropbox.com/sh/7sv3p0yxomsjrxn/AAC_xP_HH9EoMFajZSpK4m71a?dl=0
I built on Windows 10 using Visual Studio 2019 (tool set 1.42). The source is a modification of one of the PMP examples and it builds under that environment. CGAL is at 5.0. Let me know if you want me to raise an issue.
G.
- Re: [cgal-discuss] Infinite loop in PMP::corefine_and_compute_union since 4.14.2, Giles Puckett, 06/08/2020
- [cgal-discuss] Failure in PMP::corefine_and_compute_union, Giles Puckett, 06/08/2020
- Re: [cgal-discuss] Failure in PMP::corefine_and_compute_union, Trần Anh, 06/08/2020
- Re: [cgal-discuss] Infinite loop in PMP::corefine_and_compute_union since 4.14.2, Sebastien Loriot (GeometryFactory), 06/08/2020
- Re: [cgal-discuss] Infinite loop in PMP::corefine_and_compute_union since 4.14.2, Giles Puckett, 06/09/2020
