cgal-discuss - [cgal-discuss] Precondition Violations Using CGAL Bezier Curves Arrangement
  • To: <>
  • Subject: [cgal-discuss] Precondition Violations Using CGAL Bezier Curves Arrangement
  • Date: Wed, 1 Jul 2020 17:41:09 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
Hello,
Problem Description
I have successfully used the C:\del64\CGAL-5.0.1\examples\Arrangement_on_surface_2\build\Debug\Bezier_curves.exe for several years using different versions of CGAL as they have become available. My only modifications to the example code are to load the curves from a file and save the results to a file.
Recently I have been encountering a number of precondition violations. I have observed that sometimes if I repeatedly run the program with the same set of curves, once in a while it will produce a violation free result.
In reviewing other situations where individuals have encountered precondition violations, the solution is to change to an exact solution.
I cannot figure out how to do this for Bezier Curves.
I have include my source code and a failure example below.
Thank you!
Jeb Gaither
Source Code
//! \file examples/Arrangement_on_surface_2/Bezier_curves.cpp
// Constructing an arrangement of Bezier curves.
#include <fstream>
#include <CGAL/basic.h>
#ifndef CGAL_USE_CORE
#include <iostream>
int main ()
  std::cout << "Sorry, this example needs CORE ..." << std::endl;
  return 0;
#else
#include <CGAL/Cartesian.h>
#include <CGAL/CORE_algebraic_number_traits.h>
#include <CGAL/Arr_Bezier_curve_traits_2.h>
#include <CGAL/Arrangement_2.h>
#include <CGAL/IO/Arr_iostream.h>
#include "arr_inexact_construction_segments.h"
#include "arr_print.h"
typedef CGAL::CORE_algebraic_number_traits              Nt_traits;
typedef Nt_traits::Rational                             NT;
typedef Nt_traits::Rational                             Rational;
typedef Nt_traits::Algebraic                            Algebraic;
typedef CGAL::Cartesian<Rational>                       Rat_kernel;
typedef CGAL::Cartesian<Algebraic>                      Alg_kernel;
typedef Rat_kernel::Point_2                             Rat_point_2;
typedef CGAL::Arr_Bezier_curve_traits_2<Rat_kernel, Alg_kernel, Nt_traits>
                                                        Traits_2;
typedef Traits_2::Curve_2                               Bezier_curve_2;
typedef CGAL::Arrangement_2<Traits_2>                   Arrangement_2;
//typedef CGAL::Arrangement_2<Traits_2>                   Arrangement;
// Save all vertices (points) and edges (curves) along a connected component
// boundary.
template<class Arrangement>
void save_ccb(typename Arrangement::Ccb_halfedge_const_circulator circ,std::ofstream &aOutputFile)
                typename Arrangement::Ccb_halfedge_const_circulator  curr = circ;
                typename Arrangement::Halfedge_const_handle          he;
                aOutputFile << "(" << curr->source()->point() << ")";
                aOutputFile << std::endl;
                do
                                he = curr;
                                aOutputFile << "   [" << he->curve() << "]   "
                                                << "(" << he->target()->point() << ")";
                                ++curr;
                } while (curr != circ);
                return;
// Save the boundary description of an arrangement face.
void save_face(typename typename Arrangement::Face_const_handle f, std::ofstream &aOutputFile)
                // Print the outer boundary.
                if (f->is_unbounded())
                                aOutputFile << "Unbounded face. " << std::endl;
                else
                                aOutputFile << "Outer boundary: ";
                                print_ccb<Arrangement>(f->outer_ccb(), aOutputFile);
                // Print the boundary of each of the holes.
                typename Arrangement::Hole_const_iterator  hole;
                int                                         index = 1;
                for (hole = f->holes_begin(); hole != f->holes_end(); ++hole, ++index)
                                aOutputFile << "    Hole #" << index << ": ";
                                print_ccb<Arrangement>(*hole, aOutputFile);
                // Print the isolated vertices.
                typename Arrangement::Isolated_vertex_const_iterator  iv;
                for (iv = f->isolated_vertices_begin(), index = 1;
                                iv != f->isolated_vertices_end(); ++iv, ++index)
                                aOutputFile << "    Isolated vertex #" << index << ": "
                                                << "(" << iv->point() << ")" << std::endl;
                return;
// Save the given arrangement to file.
void save_arrangement(const Arrangement& arr, std::ofstream &aOutputFile)
                CGAL_precondition(arr.is_valid());
                // Print the arrangement vertices.
                typename Arrangement::Vertex_const_iterator  vit;
                aOutputFile << arr.number_of_vertices() << " vertices:" << std::endl;
                for (vit = arr.vertices_begin(); vit != arr.vertices_end(); ++vit)
                                aOutputFile << "(" << vit->point() << ")";
                                if (vit->is_isolated())
                                                aOutputFile << " - Isolated." << std::endl;
                                else
                                                aOutputFile << " - degree " << vit->degree() << std::endl;
                // Print the arrangement edges.
                typename Arrangement::Edge_const_iterator    eit;
                aOutputFile << arr.number_of_edges() << " edges:" << std::endl;
                for (eit = arr.edges_begin(); eit != arr.edges_end(); ++eit)
                                aOutputFile << "[" << eit->curve() << "]" << std::endl;
                // Print the arrangement faces.
                typename Arrangement::Face_const_iterator    fit;
                aOutputFile << arr.number_of_faces() << " faces:" << std::endl;
                for (fit = arr.faces_begin(); fit != arr.faces_end(); ++fit)
//                            save_face(fit->face(), aOutputFile);
                                if (fit->is_unbounded())
                                else
                                                save_ccb<Arrangement>(fit->outer_ccb(), aOutputFile);
                                int                                         index = 1;
                                for (hole = fit->holes_begin(); hole != fit->holes_end(); ++hole, ++index)
                                                save_ccb<Arrangement>(*hole, aOutputFile);
                                for (iv = fit->isolated_vertices_begin(), index = 1;
                                                iv != fit->isolated_vertices_end(); ++iv, ++index)
                return;
int main (int argc, char *argv[])
  // Get the name of the input file from the command line, or use the default
  // Bezier.dat file if no command-line parameters are given.
                const char   *filename = (argc > 1) ? argv[1] : "Bezier.dat";
                const char   *outfilename = (argc > 1) ? argv[1] : "BezierOut.dat";
  // Open the input file.
  std::ifstream   in_file (filename);
  if (! in_file.is_open()) {
    std::cerr << "Failed to open " << filename << std::endl;
    return 1;
  // Read the curves from the input file.
  unsigned int               n_curves;
 std::list<Bezier_curve_2>  curves;
  Bezier_curve_2             B;
  unsigned int               k;
  in_file >> n_curves;
  for (k = 0; k < n_curves; k++) {
    // Read the current curve (specified by its control points).
    in_file >> B;
    curves.push_back (B);
    std::cout << "B = {" << B << "}" << std::endl;
  in_file.close();
  // Construct the arrangement.
  Arrangement_2                   arr;
  insert (arr, curves.begin(), curves.end());
  // Print the arrangement size.
  std::ofstream out_file(outfilename);
  out_file << "The arrangement size:" << std::endl
                                                << "   V = " << arr.number_of_vertices()
            << ",  E = " << arr.number_of_edges()
            << ",  F = " << arr.number_of_faces() << std::endl;
//  out_file << arr;
  save_arrangement(arr,out_file);
  out_file.close();
  return 0;
#endif
Failure Example
B = {4  3711507924 2865278219  3387450460 2979371134  3732852274 765306650  4082921600 751693496}
B = {4  4082921600 751693496  138023630 738080342  492760467 2924918518  150946400 2833985697}
B = {4  150946400 2833985697  4104099630 2743052877  3065734660 374349059  3364942830 563526687}
B = {4  3364942830 563526687  3664151001 752704315  1005965016 3499763387  780346946 3228647410}
B = {4  780346946 3228647410  554728876 2957531432  2761678721 3963207703  2889287872 4291330058}
B = {4  2889287872 4291330058  3016897023 324485117  1065165481 4270020853  1050800113 3916166178}
B = {4  1050800113 3916166178  1036434745 3562311503  2959435552 3204033711  2856266200 3548982900}
B = {4  2856266200 3548982900  2753096848 3893932088  623757336 647140960  837105897 345708045}
B = {4  837105897 345708045  1050454457 44275131  3606491089 2688200429  3301513570 2915003916}
B = {4  3301513570 2915003916  2996536052 3141807404  4125511678 951489078  198993326 823727760}
B = {4  198993326 823727760  567442270 695966440  175364532 2630762126  4073586476 2644375203}
B = {4  4073586476 2644375203  3676841125 2657988281  3275428162 750418751  3661633657 855020001}
B = {4  3661633657 855020001  4047839152 959621250  926695811 3076393280  589726066 2861216888}
B = {4  589726066 2861216888  252756322 2646040497  2699960175 98915684  2953013560 405815950}
B = {4  2953013560 405815950  3206066946 712716216  1264969863 3873641561  1122937075 3503452199}
B = {4  1122937075 3503452199  980904286 3133262837  2637935791 3526926066  2652301229 3925012512}
B = {4  2652301229 3925012512  2666666667 28131662  1038366037 430641326  1155958989 43625208}
B = {4  1155958989 43625208  1273551940 3951576384  3137038473 2775034485  2896254476 3112251688}
B = {4  2896254476 3112251688  2655470480 3449468891  310415954 1005477905  653155187 752675593}
B = {4  653155187 752675593  995894419 499873282  4026427409 2438259646  3613587087 2579689395}
B = {4  3613587087 2579689395  3200746765 2721119143  3639500427 1065592276  4082921600 1051979157}
B = {4  4082921600 1051979157  231375477 1038366037  679464162 2666666667  248867213 2548397013}
B = {4  248867213 2548397013  4113237559 2430127360  2803954977 565287424  3693372790 319518432}
CGAL error: precondition violation!
_expression_ : comp_f(object, nodeP->object) != LARGER
File       : C:\del64\CGAL 5.01\include\CGAL/Multiset.h
Line       : 2131
Explanation:
Refer to the bug-reporting instructions at https://www.cgal.org/bug_report.html
C:\del64\CGAL-5.0.1\examples\Arrangement_on_surface_2\build\Debug\Bezier_curves.exe (process 5928) exited with code -1.
To automatically close the console when debugging stops, enable Tools->Options->Debugging->Automatically close the console when debugging stops.
Press any key to close this window . . .
