Re: [cgal-discuss] Precondition Violations Using CGAL Bezier Curves Arrangement
- To: Efi Fogel <>
- Subject: Re: [cgal-discuss] Precondition Violations Using CGAL Bezier Curves Arrangement
- Date: Sun, 5 Jul 2020 14:59:18 +0000 (UTC)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi Efi,
Thank you very much for your answer. I will keep you posted as I progress.
For your information, the Bezier Curves which have the issues are derived from self intersecting Bezier Splines. I suspect I may be losing some accuracy in the conversion process.
One other quick question. So far I have successfully used CGAL Arrangements for shapes composed of either Polylines or Beziers Curves. I would like to add mixed mode shapes with both types of edges. My plan is to covert lines to "straight" Cubic Bezier Curves. Do you have any alternatives suggestions?
Thank you again.
Jeb
From: [mailto:] On Behalf Of Efi Fogel ( via cgal-discuss Mailing List)
Sent: Thursday, July 02, 2020 4:40 AM
To:
Hi Jeb,
You may know most or all of the facts below, but for the sake of other readers I repeat it.
Saving an arrangement instantiated with the Bezier geometry traits and reading back the saved information directly is impossible (without the risk of encountering problems caused by limited precision). The reason, in general, is because (intersection) points do not have exact representation; you can only obtain an approximation.
The solution is to save the curves that induced the arrangement in the first place.
Observe that you need to save the original curves (before inserted into the arrangement) and not the curves that are the geometric embeddings of the edges of the arrangement.
Then, to restore the arrangement, you need to read the curves and insert them into an arrangement (essentially re-constructing the arrangement).
Saving the curves must be done in an exact way, that is, the coordinates of the control points must be saved in an exact manner.
PS, you can write
os << CGAL::exact(x)
for any kernel object x. However you will need to provide your own (rather simple) implementation for exporting an object of the Curve_2 type of the Bezier traits.
I think that I'll add it to some future release of CGAL, but it may take some time...
Cheers,
Efi
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
On Thu, 2 Jul 2020 at 00:41, Jeb Gaither <> wrote:
Hello,
Problem Description
I have successfully used the C:\del64\CGAL-5.0.1\examples\Arrangement_on_surface_2\build\Debug\Bezier_curves.exe for several years using different versions of CGAL as they have become available. My only modifications to the example code are to load the curves from a file and save the results to a file.
Recently I have been encountering a number of precondition violations. I have observed that sometimes if I repeatedly run the program with the same set of curves, once in a while it will produce a violation free result.
In reviewing other situations where individuals have encountered precondition violations, the solution is to change to an exact solution.
I cannot figure out how to do this for Bezier Curves.
I have include my source code and a failure example below.
Thank you!
Jeb Gaither
Source Code
//! \file examples/Arrangement_on_surface_2/Bezier_curves.cpp
// Constructing an arrangement of Bezier curves.
#include <fstream>
#include <CGAL/basic.h>
#ifndef CGAL_USE_CORE
#include <iostream>
int main ()
std::cout << "Sorry, this example needs CORE ..." << std::endl;
return 0;
#else
#include <CGAL/Cartesian.h>
#include <CGAL/CORE_algebraic_number_traits.h>
#include <CGAL/Arr_Bezier_curve_traits_2.h>
#include <CGAL/Arrangement_2.h>
#include <CGAL/IO/Arr_iostream.h>
#include "arr_inexact_construction_segments.h"
#include "arr_print.h"
typedef CGAL::CORE_algebraic_number_traits Nt_traits;
typedef Nt_traits::Rational NT;
typedef Nt_traits::Rational Rational;
typedef Nt_traits::Algebraic Algebraic;
typedef CGAL::Cartesian<Rational> Rat_kernel;
typedef CGAL::Cartesian<Algebraic> Alg_kernel;
typedef Rat_kernel::Point_2 Rat_point_2;
typedef CGAL::Arr_Bezier_curve_traits_2<Rat_kernel, Alg_kernel, Nt_traits>
Traits_2;
typedef Traits_2::Curve_2 Bezier_curve_2;
typedef CGAL::Arrangement_2<Traits_2> Arrangement_2;
//typedef CGAL::Arrangement_2<Traits_2> Arrangement;
// Save all vertices (points) and edges (curves) along a connected component
// boundary.
template<class Arrangement>
void save_ccb(typename Arrangement::Ccb_halfedge_const_circulator circ,std::ofstream &aOutputFile)
typename Arrangement::Ccb_halfedge_const_circulator curr = circ;
typename Arrangement::Halfedge_const_handle he;
aOutputFile << "(" << curr->source()->point() << ")";
aOutputFile << std::endl;
do
he = curr;
aOutputFile << " [" << he->curve() << "] "
<< "(" << he->target()->point() << ")";
++curr;
} while (curr != circ);
return;
// Save the boundary description of an arrangement face.
void save_face(typename typename Arrangement::Face_const_handle f, std::ofstream &aOutputFile)
// Print the outer boundary.
if (f->is_unbounded())
aOutputFile << "Unbounded face. " << std::endl;
else
aOutputFile << "Outer boundary: ";
print_ccb<Arrangement>(f->outer_ccb(), aOutputFile);
// Print the boundary of each of the holes.
typename Arrangement::Hole_const_iterator hole;
int index = 1;
for (hole = f->holes_begin(); hole != f->holes_end(); ++hole, ++index)
aOutputFile << " Hole #" << index << ": ";
print_ccb<Arrangement>(*hole, aOutputFile);
// Print the isolated vertices.
typename Arrangement::Isolated_vertex_const_iterator iv;
for (iv = f->isolated_vertices_begin(), index = 1;
iv != f->isolated_vertices_end(); ++iv, ++index)
aOutputFile << " Isolated vertex #" << index << ": "
<< "(" << iv->point() << ")" << std::endl;
return;
// Save the given arrangement to file.
void save_arrangement(const Arrangement& arr, std::ofstream &aOutputFile)
CGAL_precondition(arr.is_valid());
// Print the arrangement vertices.
typename Arrangement::Vertex_const_iterator vit;
aOutputFile << arr.number_of_vertices() << " vertices:" << std::endl;
for (vit = arr.vertices_begin(); vit != arr.vertices_end(); ++vit)
aOutputFile << "(" << vit->point() << ")";
if (vit->is_isolated())
aOutputFile << " - Isolated." << std::endl;
else
aOutputFile << " - degree " << vit->degree() << std::endl;
// Print the arrangement edges.
typename Arrangement::Edge_const_iterator eit;
aOutputFile << arr.number_of_edges() << " edges:" << std::endl;
for (eit = arr.edges_begin(); eit != arr.edges_end(); ++eit)
aOutputFile << "[" << eit->curve() << "]" << std::endl;
// Print the arrangement faces.
typename Arrangement::Face_const_iterator fit;
aOutputFile << arr.number_of_faces() << " faces:" << std::endl;
for (fit = arr.faces_begin(); fit != arr.faces_end(); ++fit)
// save_face(fit->face(), aOutputFile);
if (fit->is_unbounded())
else
save_ccb<Arrangement>(fit->outer_ccb(), aOutputFile);
int index = 1;
for (hole = fit->holes_begin(); hole != fit->holes_end(); ++hole, ++index)
save_ccb<Arrangement>(*hole, aOutputFile);
for (iv = fit->isolated_vertices_begin(), index = 1;
iv != fit->isolated_vertices_end(); ++iv, ++index)
return;
int main (int argc, char *argv[])
// Get the name of the input file from the command line, or use the default
// Bezier.dat file if no command-line parameters are given.
const char *filename = (argc > 1) ? argv[1] : "Bezier.dat";
const char *outfilename = (argc > 1) ? argv[1] : "BezierOut.dat";
// Open the input file.
std::ifstream in_file (filename);
if (! in_file.is_open()) {
std::cerr << "Failed to open " << filename << std::endl;
return 1;
// Read the curves from the input file.
unsigned int n_curves;
std::list<Bezier_curve_2> curves;
Bezier_curve_2 B;
unsigned int k;
in_file >> n_curves;
for (k = 0; k < n_curves; k++) {
// Read the current curve (specified by its control points).
in_file >> B;
curves.push_back (B);
std::cout << "B = {" << B << "}" << std::endl;
in_file.close();
// Construct the arrangement.
Arrangement_2 arr;
insert (arr, curves.begin(), curves.end());
// Print the arrangement size.
std::ofstream out_file(outfilename);
out_file << "The arrangement size:" << std::endl
<< " V = " << arr.number_of_vertices()
<< ", E = " << arr.number_of_edges()
<< ", F = " << arr.number_of_faces() << std::endl;
// out_file << arr;
save_arrangement(arr,out_file);
out_file.close();
return 0;
#endif
Failure Example
B = {4 3711507924 2865278219 3387450460 2979371134 3732852274 765306650 4082921600 751693496}
B = {4 4082921600 751693496 138023630 738080342 492760467 2924918518 150946400 2833985697}
B = {4 150946400 2833985697 4104099630 2743052877 3065734660 374349059 3364942830 563526687}
B = {4 3364942830 563526687 3664151001 752704315 1005965016 3499763387 780346946 3228647410}
B = {4 780346946 3228647410 554728876 2957531432 2761678721 3963207703 2889287872 4291330058}
B = {4 2889287872 4291330058 3016897023 324485117 1065165481 4270020853 1050800113 3916166178}
B = {4 1050800113 3916166178 1036434745 3562311503 2959435552 3204033711 2856266200 3548982900}
B = {4 2856266200 3548982900 2753096848 3893932088 623757336 647140960 837105897 345708045}
B = {4 837105897 345708045 1050454457 44275131 3606491089 2688200429 3301513570 2915003916}
B = {4 3301513570 2915003916 2996536052 3141807404 4125511678 951489078 198993326 823727760}
B = {4 198993326 823727760 567442270 695966440 175364532 2630762126 4073586476 2644375203}
B = {4 4073586476 2644375203 3676841125 2657988281 3275428162 750418751 3661633657 855020001}
B = {4 3661633657 855020001 4047839152 959621250 926695811 3076393280 589726066 2861216888}
B = {4 589726066 2861216888 252756322 2646040497 2699960175 98915684 2953013560 405815950}
B = {4 2953013560 405815950 3206066946 712716216 1264969863 3873641561 1122937075 3503452199}
B = {4 1122937075 3503452199 980904286 3133262837 2637935791 3526926066 2652301229 3925012512}
B = {4 2652301229 3925012512 2666666667 28131662 1038366037 430641326 1155958989 43625208}
B = {4 1155958989 43625208 1273551940 3951576384 3137038473 2775034485 2896254476 3112251688}
B = {4 2896254476 3112251688 2655470480 3449468891 310415954 1005477905 653155187 752675593}
B = {4 653155187 752675593 995894419 499873282 4026427409 2438259646 3613587087 2579689395}
B = {4 3613587087 2579689395 3200746765 2721119143 3639500427 1065592276 4082921600 1051979157}
B = {4 4082921600 1051979157 231375477 1038366037 679464162 2666666667 248867213 2548397013}
B = {4 248867213 2548397013 4113237559 2430127360 2803954977 565287424 3693372790 319518432}
CGAL error: precondition violation!
_expression_ : comp_f(object, nodeP->object) != LARGER
File : C:\del64\CGAL 5.01\include\CGAL/Multiset.h
Line : 2131
Explanation:
Refer to the bug-reporting instructions at https://www.cgal.org/bug_report.html
C:\del64\CGAL-5.0.1\examples\Arrangement_on_surface_2\build\Debug\Bezier_curves.exe (process 5928) exited with code -1.
To automatically close the console when debugging stops, enable Tools->Options->Debugging->Automatically close the console when debugging stops.
Press any key to close this window . . .
- [cgal-discuss] Precondition Violations Using CGAL Bezier Curves Arrangement, Jeb Gaither, 07/01/2020
- Re: [cgal-discuss] Precondition Violations Using CGAL Bezier Curves Arrangement, Efi Fogel, 07/02/2020
- RE: [cgal-discuss] Precondition Violations Using CGAL Bezier Curves Arrangement, Jeb Gaither, 07/03/2020
- Re: [cgal-discuss] Precondition Violations Using CGAL Bezier Curves Arrangement, Efi Fogel, 07/05/2020
- Re: [cgal-discuss] Precondition Violations Using CGAL Bezier Curves Arrangement, Carlos Rabelo, 07/05/2020
