cgal-discuss - [cgal-discuss] How to collect the new facets after an isotropic remeshing on a subset of facests
  • To:
  • Subject: [cgal-discuss] How to collect the new facets after an isotropic remeshing on a subset of facests
  • Date: Thu, 16 Jul 2020 01:18:30 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Greetings,
Does anyone know how to get a collection of the newly generated facets after performing an isotropic remeshing on a subset of facets from a Surface_mesh mesh?
When I was doing the refreshing, I collect the subset of facets in an std::unordered_set, and send this unordered set to CGAL::Polygon_mesh_processing::isotropic_remeshing(). After the remeshing, I'd like to collect all the newly generated facets into a container. However, I did not find a way to do that. Does anyone know a proper way for doing this?
I am also thinking that if operations on a subset of facets are not possible, how about dividing the original mesh into pieces. And then we can do remeshing on the individual pieces of sub-meshes. In this way, I could collect the entire facets belong to a sub-mesh. However, what is the correct way to split or separate facets into a sub-mesh from the original mesh?
Thanks!
Yaoyu
