cgal-discuss - Re: [cgal-discuss] Surface mesh cannot be smoothed after removing faces
  • To:
  • Subject: Re: [cgal-discuss] Surface mesh cannot be smoothed after removing faces
  • Date: Thu, 16 Jul 2020 09:30:44 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
Hello,
Note that smooth_mesh() is intended to improve the quality of the elements on the discretization of a surface, not to change the shape of the surface itself (although that some change will happen due to re-projections on the initial surface happening within smooth_mesh()).
PMP::duplicate_non_manifold_vertices() indeed creates new vertices but does not change the geometry. There is some on-going work to repair on manifold vertices / edges, but it is not ready to be used just yet. It seems that the experimental self-intersection function that Maxime pointed out in a previous message would best fit your needs for now as it will also handle non-manifold vertices (after duplication).
Best,
Mael
On 15/07/2020 20:31, Yaoyu Hu ( via cgal-discuss Mailing List) wrote:
Thank you Maxime and Mael! The Euler::remove_face() finally works. I was so silly when I first attempted to use Euler::remove_face(), where I remove more elements than I really wanted. Now the downstream smoothing works fine.
I also tried Mael's suggestion and apply duplicate_non_manifold_vertices(). As long as I understand, this function will duplicate the non-manifold vertices in the same spatial positions. Say, a single non-manifold vertex becomes multiple manifold vertices, am I right? If this is the case, how can I smooth out the local regions around the original non-manifold vertices, to make the region more smooth? It seems to me that the facets associated with the newly duplicated vertices and the nearby facets are still arranged in a pattern much more complex than a plain surface.
In the sample surface mesh I enclosed in the previous email, there are some wired facets locate around the surfaces near the top. These facets consist of most of the original self-intersections and non-manifold vertices. After I remove the self-intersecting facets and duplicate the non-manifold vertices, but the remaining facets are still in wired positions. How can I further process the mesh so that these bad regions become more like a plain surface?
Thank you for the help!
