cgal-discuss - Re: [cgal-discuss] Problems with Sharp Features in 3d Mesh Generation
  • To:
  • Subject: Re: [cgal-discuss] Problems with Sharp Features in 3d Mesh Generation
  • Date: Tue, 8 Sep 2020 06:53:56 -0500 (CDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=Pass
  • Ironport-phdr: 9a23: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
Thanks for your reply. I modified my code in the wrong way prior to posting
here therefore these polylines are not what I wanted them to be. I have
tried again to provide a minimal example which illustrates the issue at the
end of this message, which produces the following image:
<http://cgal-discuss.949826.n4.nabble.com/file/t376248/CylinderProblem.jpg>
But from your answer I may have understood what the problem is:
Say I parametrize two polylines:
//top of cylinder
for (int i = 31; i < 360; ++i)
Point p(15.0, 10 * std::cos(i * CGAL_PI / 180), 10 *
std::sin(i * CGAL_PI
/ 180));
polyline.push_back(p);
polylines.push_back(polyline);
//line: (-15 < x < 15, y = 10 * cos(pi/6), z = 10 * sin(pi/6) )
for (int i = 0; i < 100; ++i)
Point p(-15.0 + i * ((30.) / 99.), 10 * std::cos(CGAL_PI /
6), 10 *
std::sin(CGAL_PI / 6));
polyline6.push_back(p);
polylines.push_back(polyline6);
those two lines (almost) meet at one point, namely: (15.0, cos(pi/6),
sin(pi/6) ) which causes problems with the protection algorithm? So if I
have several sharp 1D features that I want to preserve I should be careful
with my polylines not sharing points?
Thank you again and sorry for the faulty minimal example.
Cheers Marius
Minimal Example:
#include <vector>
#include <CGAL/Mesh_triangulation_3.h>
#include <CGAL/Mesh_complex_3_in_triangulation_3.h>
#include <CGAL/Mesh_criteria_3.h>
#include <CGAL/Labeled_mesh_domain_3.h>
#include <CGAL/Mesh_domain_with_polyline_features_3.h>
#include <CGAL/make_mesh_3.h>
#include <cmath>
// Kernel
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
// Domain
typedef K::FT FT;
typedef K::Point_3 Point;
typedef FT(Function)(const Point&);
typedef
CGAL::Mesh_domain_with_polyline_features_3<CGAL::Labeled_mesh_domain_3&lt;K>
> Mesh_domain;
// Polyline
typedef std::vector<Point> Polyline_3;
typedef std::list<Polyline_3> Polylines;
#ifdef CGAL_CONCURRENT_MESH_3
typedef CGAL::Parallel_tag Concurrency_tag;
#else
typedef CGAL::Sequential_tag Concurrency_tag;
#endif
// Triangulation
typedef CGAL::Mesh_triangulation_3<Mesh_domain, CGAL::Default,
Concurrency_tag>::type Tr;
typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr,
Mesh_domain::Corner_index, Mesh_domain::Curve_index> C3t3;
// Criteria
typedef CGAL::Mesh_criteria_3
Mesh_criteria;
// To avoid verbose function and named parameters call
using namespace CGAL::parameters;
// Functions
// describes cylinder: \{ (x,y,z) \in \mathbb{R}^3 \mid |(y,z)|_euclid <=
10, -15 <= x <= 15 \}
FT cylinder_function(const Point& p)
const FT x2 = p.x() * p.x();
const FT y2 = p.y() * p.y();
const FT z2 = p.z() * p.z();
FT aux = y2 + z2 - 100;
if (p.x() > 15 && aux < 0)
aux = -aux;
if (p.x() < -15 && aux < 0)
aux = -aux;
return aux;
// section of cylinder of larger radius: \{ (x,y,z) \in \mathbb{R}^3 \mid
|(y,z)|_euclid <= 12, -15 <= x <= 15, angle in (y,z) plane between 0 and
\pi/6 \}
FT cylinder_section_function(const Point& p)
FT aux = y2 + z2 - 144;
aux = -aux;
aux = -aux;
if ( (aux < 0 && !(0 < std::atan(p.z() / p.y()) && std::atan(p.z() /
p.y())
< CGAL_PI / 6.) ) || p.y() < 0 || p.z() < 0 )
aux = 1;
return aux;
FT set_union(const Point& p)
if (cylinder_section_function(p) < 0 || cylinder_function(p) < 0)
return -1;
else
return 1;
int main(int argc, char* argv[])
//---------------------------------------------------------------------generate-.mesh-file-----------------------------------------------------------------------------------------------------------//
// Domain (Warning: Sphere_3 constructor uses squared radius !)
Mesh_domain domain =
Mesh_domain::create_implicit_mesh_domain(set_union,
K::Sphere_3(CGAL::ORIGIN, 400));
// Mesh criteria
Mesh_criteria criteria(edge_size = 0.49, facet_angle = 25, facet_size
0.5, cell_radius_edge_ratio = 3.5, cell_size = .8, facet_distance = 0.6);
// Create edge that we want to preserve
Polylines polylines;
//Polyline_3& polyline = polylines.front();
//Polyline_3& polyline2 = polylines.back();
Polyline_3 polyline;
Polyline_3 polyline6;
//top of cylinder
/ 180));
//fixateur line: (-15 < x < 15, y = 10 * cos(pi/6), z = 10 *
sin(pi/6) )
6), 10 *
// Insert edge in domain
domain.add_features(polylines.begin(), polylines.end());
// Mesh generation without feature preservation
C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria,
CGAL::parameters::no_features());
// Output
std::ofstream medit_file("out-no-protection.mesh");
c3t3.output_to_medit(medit_file);
medit_file.close();
c3t3.clear();
// Mesh generation with feature preservation
c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria);
// Output
medit_file.open("out.mesh");
medit_file.close();
return 0;
