- To:
- Subject: Re: [cgal-discuss] Problems with Sharp Features in 3d Mesh Generation
- Date: Tue, 8 Sep 2020 14:54:53 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
You have to make the end points of those two polylines identical,
otherwise small protecting balls will be inserted so as to separate
then. Then there is a interpolation of the size of the protecting balls
along polylines.
Best,
Sebastien.
On 9/8/20 1:53 PM, MariusZeinhofer wrote:
Thanks for your reply. I modified my code in the wrong way prior to posting
here therefore these polylines are not what I wanted them to be. I have
tried again to provide a minimal example which illustrates the issue at the
end of this message, which produces the following image:
<http://cgal-discuss.949826.n4.nabble.com/file/t376248/CylinderProblem.jpg>
But from your answer I may have understood what the problem is:
Say I parametrize two polylines:
//top of cylinder
for (int i = 31; i < 360; ++i)
Point p(15.0, 10 * std::cos(i * CGAL_PI / 180), 10 *
std::sin(i * CGAL_PI
/ 180));
polyline.push_back(p);
polylines.push_back(polyline);
//line: (-15 < x < 15, y = 10 * cos(pi/6), z = 10 * sin(pi/6) )
for (int i = 0; i < 100; ++i)
Point p(-15.0 + i * ((30.) / 99.), 10 * std::cos(CGAL_PI /
6), 10 *
std::sin(CGAL_PI / 6));
polyline6.push_back(p);
polylines.push_back(polyline6);
those two lines (almost) meet at one point, namely: (15.0, cos(pi/6),
sin(pi/6) ) which causes problems with the protection algorithm? So if I
have several sharp 1D features that I want to preserve I should be careful
with my polylines not sharing points?
Thank you again and sorry for the faulty minimal example.
Cheers Marius
Minimal Example:
#include <vector>
#include <CGAL/Mesh_triangulation_3.h>
#include <CGAL/Mesh_complex_3_in_triangulation_3.h>
#include <CGAL/Mesh_criteria_3.h>
#include <CGAL/Labeled_mesh_domain_3.h>
#include <CGAL/Mesh_domain_with_polyline_features_3.h>
#include <CGAL/make_mesh_3.h>
#include <cmath>
// Kernel
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
// Domain
typedef K::FT FT;
typedef K::Point_3 Point;
typedef FT(Function)(const Point&);
typedef
CGAL::Mesh_domain_with_polyline_features_3<CGAL::Labeled_mesh_domain_3<K>
Mesh_domain;
// Polyline
typedef std::vector<Point> Polyline_3;
typedef std::list<Polyline_3> Polylines;
#ifdef CGAL_CONCURRENT_MESH_3
typedef CGAL::Parallel_tag Concurrency_tag;
#else
typedef CGAL::Sequential_tag Concurrency_tag;
#endif
// Triangulation
typedef CGAL::Mesh_triangulation_3<Mesh_domain, CGAL::Default,
Concurrency_tag>::type Tr;
typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr,
Mesh_domain::Corner_index, Mesh_domain::Curve_index> C3t3;
// Criteria
typedef CGAL::Mesh_criteria_3
Mesh_criteria;
// To avoid verbose function and named parameters call
using namespace CGAL::parameters;
// Functions
// describes cylinder: \{ (x,y,z) \in \mathbb{R}^3 \mid |(y,z)|_euclid <=
10, -15 <= x <= 15 \}
FT cylinder_function(const Point& p)
const FT x2 = p.x() * p.x();
const FT y2 = p.y() * p.y();
const FT z2 = p.z() * p.z();
FT aux = y2 + z2 - 100;
if (p.x() > 15 && aux < 0)
aux = -aux;
if (p.x() < -15 && aux < 0)
aux = -aux;
return aux;
// section of cylinder of larger radius: \{ (x,y,z) \in \mathbb{R}^3 \mid
|(y,z)|_euclid <= 12, -15 <= x <= 15, angle in (y,z) plane between 0 and
\pi/6 \}
FT cylinder_section_function(const Point& p)
FT aux = y2 + z2 - 144;
aux = -aux;
aux = -aux;
if ( (aux < 0 && !(0 < std::atan(p.z() / p.y()) && std::atan(p.z() /
p.y())
< CGAL_PI / 6.) ) || p.y() < 0 || p.z() < 0 )
aux = 1;
return aux;
FT set_union(const Point& p)
if (cylinder_section_function(p) < 0 || cylinder_function(p) < 0)
return -1;
else
return 1;
int main(int argc, char* argv[])
//---------------------------------------------------------------------generate-.mesh-file-----------------------------------------------------------------------------------------------------------//
// Domain (Warning: Sphere_3 constructor uses squared radius !)
Mesh_domain domain =
Mesh_domain::create_implicit_mesh_domain(set_union,
K::Sphere_3(CGAL::ORIGIN, 400));
// Mesh criteria
Mesh_criteria criteria(edge_size = 0.49, facet_angle = 25, facet_size
0.5, cell_radius_edge_ratio = 3.5, cell_size = .8, facet_distance = 0.6);
// Create edge that we want to preserve
Polylines polylines;
//Polyline_3& polyline = polylines.front();
//Polyline_3& polyline2 = polylines.back();
Polyline_3 polyline;
Polyline_3 polyline6;
//top of cylinder
/ 180));
//fixateur line: (-15 < x < 15, y = 10 * cos(pi/6), z = 10 *
sin(pi/6) )
6), 10 *
// Insert edge in domain
domain.add_features(polylines.begin(), polylines.end());
// Mesh generation without feature preservation
C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria,
CGAL::parameters::no_features());
// Output
std::ofstream medit_file("out-no-protection.mesh");
c3t3.output_to_medit(medit_file);
medit_file.close();
c3t3.clear();
// Mesh generation with feature preservation
c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria);
// Output
medit_file.open("out.mesh");
medit_file.close();
return 0;
Description: PNG image
- [cgal-discuss] Problems with Sharp Features in 3d Mesh Generation, MariusZeinhofer, 09/07/2020
- Re: [cgal-discuss] Problems with Sharp Features in 3d Mesh Generation, Sebastien Loriot (GeometryFactory), 09/07/2020
- Re: [cgal-discuss] Problems with Sharp Features in 3d Mesh Generation, Andreas Fabri, 09/07/2020
- Re: [cgal-discuss] Problems with Sharp Features in 3d Mesh Generation, MariusZeinhofer, 09/07/2020
- Re: [cgal-discuss] Problems with Sharp Features in 3d Mesh Generation, Sebastien Loriot (GeometryFactory), 09/08/2020
- Re: [cgal-discuss] Problems with Sharp Features in 3d Mesh Generation, MariusZeinhofer, 09/08/2020
