- To:
- Subject: Re: [cgal-discuss] Using Hole filling using inherited Polyhedron class
- Date: Thu, 10 Sep 2020 01:31:29 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Hi Sebastien,
Not sure if i understand how to use the macros you stated. I tried
including them in the code, but the same error persisted.
Hope you are able to expand further on its usage, thanks!
regards
Calvin
- [cgal-discuss] Using Hole filling using inherited Polyhedron class, calvin_cw, 09/09/2020
- Re: [cgal-discuss] Using Hole filling using inherited Polyhedron class, Sebastien Loriot (GeometryFactory), 09/09/2020
- Re: [cgal-discuss] Using Hole filling using inherited Polyhedron class, calvin_cw, 09/10/2020
- Re: [cgal-discuss] Using Hole filling using inherited Polyhedron class, Sebastien Loriot (GeometryFactory), 09/10/2020
