cgal-discuss - Re: [cgal-discuss] CGAL 5.1 Released, Computational Geometry Algorithms Library
  • To:
  • Subject: Re: [cgal-discuss] CGAL 5.1 Released, Computational Geometry Algorithms Library
  • Date: Wed, 9 Sep 2020 22:02:32 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:OnSkihcr28DNTIOvA/EbSLB5lGMj4u6mDksu8pMizoh2WeGdxcSybR7h7PlgxGXEQZ/co6odzbaP7ea5AzBLsc/JmUtBWaQEbwUCh8QSkl5oK+++Imq/EsTXaTcnFt9JTl5v8iLzG0FUHMHjew+a+SXqvnYdFRrlKAV6OPn+FJLMgMSrzeCy/IDYbxlViDanbr5+MRS7oR/MusUIjoZuJaU8xgbUqXZUZupawn9lK0iOlBjm/Mew+5Bj8yVUu/0/8sNLTLv3caclQ7FGFToqK2866tHluhnFVguP+2ATUn4KnRpSAgjK9w/1U5HsuSbnrOV92S2aPcrrTbAoXDmp8qlmRAP0hCoBKjU09nzchM5tg6JBuB+vugJxw4DUbo+WOvRxcKzSctEGSmRORctRSy5MD5mgY4cTAecMP+BVpJT9qVsUqhu+ABGhCufoyjBSmnD23aw60+E8Gg/awgMgHs4BsHTKo9XxKawfVuK1zK7Swjrfb/NW2DL95JLSch8/oPGDQbJwftTVyUQ0DwPFiU6QqZD7MDOSzOgCrnaU4vNmWOmyhGEptxt/rSKzxscwlIbJnIQVx0jK+yh5wYs7K9O1RFNnbdO4H5Vdti6XOo92TM4jXW1luyY0x6EGt5OlfyUH1JsqyRHdZvGZfIaE/BHuWeePLDl2gn9uZbyxhxG38Ue6y+38UNG530pFriVfltnArHcN1wbc6sWBV/Bz/V+h1C6S2w3Q6uxIO0E5mKjBJ5Mvw7M8jJsevETbEiL1nEj6lrKae0ol9+Sy9ejrfKnqqoWBO4J6lg3zNLkllNalDuQiKAcOWnCW+eSi273n+k30WLBKjvorkqnFrJzWON4Xpra+Aw9OzoYs9RG/Ay2739sGhXUHLVRFdwybj4XxJl3DI/D1Ae2+jlmuijtmyfHLMqfgD5jNNnTDla3ufbd5605S0gozytVf6opWCrEGOv38Rk/xtN3dDhMjKQy73efnB8l91owAXWKCGbeZMKTJsV+U+O0vJPOAa5ILtzrlMfgq++bujWMlmV8aZaSmwZQXZ2q8Hvh/PkqZYGHsjcscEWcRpQozV/fqiV2HUT5LfXm+RaM85jchCIKnF4jPXI6tgKbSlBu8S5ZZb2QDBlGXGmrzbK2FXe0NYWScOJxPiDsBAJqmQoQh1BTmjgL7wLpqKqKA+CoRvpLi0Z5v6uzYlRw23SRzFNiQ1CeBQjcnzSszWzYq0fUn8gRGwVCZ3P0g2qAKJZlo//pMFzwCG9vE1eUjUoLqXRndc9DPRFv0Goz7UwF0dco4xpo1W2g4G9imiUmTjS+tHqNNzvqTA4co/6Wa03Wjf58smUaD77EoihwdeuUKMGSngqBl8A2KXtzRlF6FmqHsealOhSM=
On 08.09.20 18:24, Laurent Rineau (CGAL/GeometryFactory) wrote:
> The CGAL Open Source Project is pleased to announce the release 5.1
> of CGAL, the Computational Geometry Algorithms Library.
Debian packages for CGAL 5.1 are now available as well. Simply add
deb http://debian.cgal.org buster main
deb-src http://debian.cgal.org buster main
deb http://debian.cgal.org bullseye main
deb-src http://debian.cgal.org bullseye main
to /etc/apt/sources.list (you only need the pair of lines
corresponding to the release you are using) and make sure that the
package apt-transport-https is installed. For sid/unstable,
packages are available from the official Debian repository. The
packages are called libcgal-dev, libcgal-qt5-dev, libcgal-demo, and
libcgal-ipelets.
In case you want to download the packages manually, have a look at
https://debian.cgal.org/pool/main/c/cgal/ .
See also https://www.cgal.org/FAQ.html#debian_packages .
Best regards,
Joachim
