cgal-discuss - [cgal-discuss] Grid-based Hexahedral Mesh
  • To: "" <>
  • Subject: [cgal-discuss] Grid-based Hexahedral Mesh
  • Date: Sun, 11 Oct 2020 09:07:18 +0000
  • Accept-language: it-IT, en-US
  • Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=student.univaq.it; dmarc=pass action=none header.from=student.univaq.it; dkim=pass header.d=student.univaq.it; arc=none
  • Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=iaZ19tuYhev1F0GjMpMYyHOpdR02gh4n7YoGgFf4FqE=; b=Mo7dnO/eqrctQ23d9gmJxaI/BTc9xSmDg3PKK0BJy9ZL7sP0tICO+VFA/uHfB1qAywWvF97ua+VkZ7UacH9Fdx7RC3C5aZPwFZYyGg2rrwHA46FAlrnDjpionQuv31wn4EZN2rwQyu+8pP/9rH0e2w6Qd+It4sdWz5kpn+iTU3O8vd6KVsQNmXs4KCr+IfImrewIg+W6trVwABVKqaYbnaMQNrv8piH7/6IQ1B+q2VcUriTu3Mrv6NpYwooce1T6WX+GEtg8HxhNXWL4yKHAaqRgdMPD5xytQ84GC7Rlox7vHRAaXeIu/+braEQzvGi3HgwbD0S9OZoqicOpXTI1Zw==
  • Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=QD2IsMKKtQoC3E54UynNQWihPms2aVABVEqgisgUXbQNJ6U9OMPxDQ2gh6d5D78ga72fbTMgJ3GlmWGRwiKXrA5KcTdBYtFFyjKE1uN6MDipONaK963kRYIYB1NbJxArRTfH22sfn9MZJQA8AWJ8KOnWXfmyj/0O5nrSIFhqB4hbVfemNchtaM0dtSyR9QCtxOLibw79i5I5Ycu6RpsWDhzaPLz9MoW9XKoFE2UKiF57i8qA4bQ+AyvtPd5Z3IapP7vN6ewXwLKqYzrxx7TS12UcjzWrpentkwMwuRPf3oKHu5wKq7Z35gN31HN/Heb1dK0hJEiIio2tNZ72KFeRqQ==
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
  • Ironport-phdr: 9a23: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
Dear all,
I am trying to generate a rudimental full hexahedral mesh using the grid-based approach, CGAL library, in particular the linear cell complex class. To do this, I have followed the following steps:
0. Imported the object to mesh (figure1);
1. Created a structured grid over the object to mesh (figure2);
2. Removed the hexahedrons outside of the object boundary and the hexahedrons which intersect the boundary. Therefore I have found the initial mesh (figure3);
3. Selected only the hexahedrons more external of the initial mesh. For each of these hexahedrons, I have found the normal of each external vertex and the intersection between the normal and the object boundary. Then I have set the geometric point of the initial mesh on the intersection point found.
4. Drawn the linear cell complex (lcc) (figure4)
When I draw the lcc, I see many errors (figure4). It seems I moved points not in the right place. Can please anyone help me to find out where I am wrong?
I attached figures and part of the code, if more code or details are needed please ask.
Thank you all.
Best regards,
Riccardo
Attachment: figure4.jpg
Description: figure4.jpg
Attachment: figure3.jpg
Description: figure3.jpg
Attachment: figure2.jpg
Description: figure2.jpg
Attachment: figure1.jpg
Description: figure1.jpg
Attachment: code.pdf
Description: code.pdf
