[cgal-discuss] Computing barycentric coordinates with Epick<Dynamic_dimension_tag>::Points
- To:
- Subject: [cgal-discuss] Computing barycentric coordinates with Epick<Dynamic_dimension_tag>::Points
- Date: Tue, 3 Nov 2020 22:26:54 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Neutral ; spf=None
- Ironport-phdr: 9a23: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
Hello,
Is there a technical reason that the construction of barycentric coordinates for the Epick kernel is not specified or implemented? There is only a dummy placeholder in CGAL 5.1.
Is there a problem to implement the transform() method for Epick::Point objects ?
The mapping of cartesian to barycentric coordinates could be implemented as an affine transform.
The transform could be stored as Data in the full_cells of a Triangulation.
Regards,
Renaud GILLON
SYDELITY
"Scaleable Virtual Prototyping"
Mobile : +32 (0)495 27 65 65
E-mail :
Web: www.sydelity.com
- [cgal-discuss] Computing barycentric coordinates with Epick<Dynamic_dimension_tag>::Points, Renaud GILLON, 11/03/2020
- Re: [cgal-discuss] Computing barycentric coordinates with Epick<Dynamic_dimension_tag>::Points, Marc Glisse, 11/03/2020
