cgal-discuss - Re: [cgal-discuss] Computing barycentric coordinates with Epick<Dynamic_dimension_tag>::Points
  • To:
  • Subject: Re: [cgal-discuss] Computing barycentric coordinates with Epick<Dynamic_dimension_tag>::Points
  • Date: Tue, 3 Nov 2020 23:17:00 +0100 (CET)
On Tue, 3 Nov 2020, Renaud GILLON wrote:
Is there a technical reason that the construction of barycentric
coordinates for the Epick kernel is not specified or implemented? There is
only a dummy placeholder in CGAL 5.1.
Are you talking about Epick_d? When I wrote that kernel, I wrote what I needed, plus the minimum to satisfy the Kernel_d concept, and it happens that the people who wrote that concept a long, long time ago forgot to document a few things, including Barycentric_coordinates_d. So all I technically needed was a dummy typedef...
I think it would be good to implement some of those missing pieces for real. However I don't think I am likely to find time to do that, unless I need to use it myself.
Is there a problem to implement the transform() method for Epick::Point
objects ?
The mapping of cartesian to barycentric coordinates could be implemented as
an affine transform.
You may notice that affine transformations are not implemented either in Epick_d.
If I didn't have to follow the existing Kernel_d concept, we could have Eigen::VectorXd as point type, and then it would be easy to use Eigen directly yourself for such missing functionality. We almost have that internally with undocumented interfaces...
The transform could be stored as Data in the full_cells of a Triangulation.
Marc Glisse
