[cgal-discuss] Problems compiling an example using CGAL::Polygon_mesh_processing::split
- To:
- Subject: [cgal-discuss] Problems compiling an example using CGAL::Polygon_mesh_processing::split
- Date: Wed, 2 Dec 2020 10:06:36 -0800
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Hi,
I am trying to use
void CGAL::Polygon_mesh_processing::split ( TriangleMesh & tm,
const Plane_3 & plane,
const NamedParameters & np )
There are no examples in 5.1 for this API.
When I do try and compile my code using this API and a <float> kernel
I am getting an error message
using K = CGAL::Simple_cartesian< float >;
using Point_3 = K::Point_3;
using Mesh = CGAL::Surface_mesh< Point_3 >;
using Plane = K::Plane_3;
CGAL/NT_converter.h(33): error : no suitable conversion function from
"const CGAL::Lazy_exact_nt<CGAL::Gmpq>" to "float" exists
I am using the Intel 19.1 C++ compiler.
Andrew
- [cgal-discuss] Problems compiling an example using CGAL::Polygon_mesh_processing::split, Andrew Cunningham, 12/02/2020
- Re: [cgal-discuss] Problems compiling an example using CGAL::Polygon_mesh_processing::split, Andrew Cunningham, 12/02/2020
- Re: [cgal-discuss] Problems compiling an example using CGAL::Polygon_mesh_processing::split, Andreas Fabri, 12/03/2020
- Re: [cgal-discuss] Problems compiling an example using CGAL::Polygon_mesh_processing::split, Andrew Cunningham, 12/04/2020
- Re: [cgal-discuss] Problems compiling an example using CGAL::Polygon_mesh_processing::split, Sebastien Loriot, 12/08/2020
- Re: [cgal-discuss] Problems compiling an example using CGAL::Polygon_mesh_processing::split, Andrew Cunningham, 12/08/2020
