cgal-discuss - Re: [cgal-discuss] Problems compiling an example using CGAL::Polygon_mesh_processing::split
  • To:
  • Subject: Re: [cgal-discuss] Problems compiling an example using CGAL::Polygon_mesh_processing::split
  • Date: Thu, 3 Dec 2020 10:46:51 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
Hi Andrew,
Is float what you use in your applications?   Adding support for it would not be a major issue,
but you are the first user who requests that.
Best,
Andreas
On 12/2/2020 10:33 PM, Andrew Cunningham wrote:
The issue can be resolved by using the <double> kernel. That's an
acceptable solution for me but does point out the difficulty of
template based programming when error messages can be obscure to say
the least.
On Wed, Dec 2, 2020 at 10:16 AM Andrew Cunningham <>
wrote:
The error from the Visual C++ compiler ( 2019) is similar ( this is
not a Intel Compiler issue)
1>D:\CGAL-5.1\include\CGAL/NT_converter.h(33,1): error C2440:
'<function-style-cast>': cannot convert from 'const NT1' to 'NT2'
1> with
1> [
1> NT1=CGAL::Lazy_exact_nt<CGAL::Gmpq>
1> ]
1> and
1> [
1> NT2=float
1> ]
1>D:\CGAL-5.1\include\CGAL/NT_converter.h(33,19): message : No
user-defined-conversion operator available that can perform this
conversion, or the operator cannot be called
1>D:\CGAL-5.1\include\CGAL/NT_converter.h(32): message : while
compiling class template member function 'NT2
CGAL::NT_converter<CGAL::Lazy_exact_nt<CGAL::Gmpq>,NT2>::operator
()(const NT1 &) const'
On Wed, Dec 2, 2020 at 10:06 AM Andrew Cunningham <>
wrote:
Hi,
I am trying to use
void CGAL::Polygon_mesh_processing::split ( TriangleMesh & tm,
const Plane_3 & plane,
const NamedParameters & np )
There are no examples in 5.1 for this API.
When I do try and compile my code using this API and a <float> kernel
I am getting an error message
using K = CGAL::Simple_cartesian< float >;
using Point_3 = K::Point_3;
using Mesh = CGAL::Surface_mesh< Point_3 >;
using Plane = K::Plane_3;
CGAL/NT_converter.h(33): error : no suitable conversion function from
"const CGAL::Lazy_exact_nt<CGAL::Gmpq>" to "float" exists
I am using the Intel 19.1 C++ compiler.
Andrew
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
