Re: [cgal-discuss] CGAL 5.2 Released, Computational Geometry Algorithms Library
- To:
- Subject: Re: [cgal-discuss] CGAL 5.2 Released, Computational Geometry Algorithms Library
- Date: Tue, 22 Dec 2020 20:42:27 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
On 22.12.20 17:47, Laurent Rineau (CGAL/GeometryFactory) wrote:
The CGAL Open Source Project is pleased to announce the release 5.2 of CGAL,
the Computational Geometry Algorithms Library.
Debian packages for CGAL 5.2 are now available as well. Simply add
deb http://debian.cgal.org buster main
deb-src http://debian.cgal.org buster main
deb http://debian.cgal.org bullseye main
deb-src http://debian.cgal.org bullseye main
to /etc/apt/sources.list (you only need the pair of lines
corresponding to the release you are using) and make sure that the
package apt-transport-https is installed. For sid/unstable,
packages are shortly available from the official Debian
repository. The packages are called libcgal-dev, libcgal-qt5-dev,
libcgal-demo, and libcgal-ipelets.
In case you want to download the packages manually, have a look at
https://debian.cgal.org/pool/main/c/cgal/ .
See also https://www.cgal.org/FAQ.html#debian_packages .
Best regards,
Joachim
- [cgal-discuss] CGAL 5.2 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 12/22/2020
- [cgal-discuss] CGAL 5.1.2 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 12/22/2020
- Re: [cgal-discuss] CGAL 5.2 Released, Computational Geometry Algorithms Library, Joachim Reichel, 12/22/2020
