cgal-discuss - [cgal-discuss] how the isovalue impact the vertices and facets of surface mesh
  • To:
  • Subject: [cgal-discuss] how the isovalue impact the vertices and facets of surface mesh
  • Date: Fri, 25 Dec 2020 20:36:53 -0600 (CST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
I am trying to generate the surface mesh of a 3D binary segmented volumetric
label(the voxel value is 0 and 1) using the code in
Surface_mesher/mesh_a_3d_gray_image.cpp
<https://doc.cgal.org/latest/Surface_mesher/Surface_mesher_2mesh_a_3d_gray_image_8cpp-example.html>
. When I tried different isovalues ranging from 0.1-0.9, I get different
surface meshes with different vertices and facets.
It seems that the the isovalues was used to get the signs of f(p)-isovalue,
but what is the function f and how the isovalue can impact the meshing
result?
Thank you.
  • [cgal-discuss] how the isovalue impact the vertices and facets of surface mesh, ianben, 12/26/2020
