- To: "" <>
- Subject: [cgal-discuss] Larger minimum angle in the criteria for make_surface_mesh.
- Date: Wed, 6 Jan 2021 04:30:04 +0000
- Accept-language: en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=epmap-system.com; dmarc=pass action=none header.from=epmap-system.com; dkim=pass header.d=epmap-system.com; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=f2oPLY5UyQ2D5iiiZrE90bL7neP8EAE1iNO5RsoOzuI=; b=VQIrlgApt64+GFBfGw0rY2neF3NvnyUK0AkeLaEaXk1AjKhAYxFpMOMlOOCwjPWn1ygFhSoxeFgaD4QYfDG22tY5MA1VB1tlmGOm3ImtlhzqEK/yi44OH9yPMp6TnXe4PY9hJNAuZz9aq4bYLplJu/2sCUp/YKnwcHmNMvBTAbk+BS3ndlWGlSIGqriuCUUmNuizfwhlVOpInsNgo6C++ZIEoa/jKF1OPfPvNFtnHgdJK5jV3NCllqYhfuUkwMMv7fYCugeENn5MIPJ4sqF3Qdku5GmVT6Bnc8Kg34GL8+1GPdMPvBnPya7pwdyEDXMcUHuI3+N0Yy0z3ddMTS7hBA==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=Dz9OA98GmvH7v+lRqeU9dhDolD0ghpsXcgzfqU5YINaEX22Is5hirivqDKh9Q4ozY51wO1odV9GbcH4zUpIq8MdzBCdEDqxecb26YaoHennUC/xQV0E+zeRnjuRovPUNDSBaYPlm38i1rYGttZGHy1IGG5VSY6WKhaCvVIrIo8kvOnz4ICvh7st9SvJRgemxfSvKpnEq3TGvbW/p9gwBkzAYKbKRcUh45ICZPq046PrjZTnH7XsJPw3ClF0AZ6cwo8ePKi0Tn7s6jLza3K07ty1eMonybNEYempxlGzt6jAbAb75RhjsjwhQe0T1pt9ScuTSGdaEi5xEkV+aHR1LaQ==
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-phdr: 9a23:oALSNBBsdwGu3lWr9CaVUyQJP3N1i/DPJgcQr6AfoPdwSP37o82wAkXT6L1XgUPTWs2DsrQY0rWQ6fuwEjJZqb+681k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i764jEdAAjwOhRoLerpBIHSk9631+ev8JHPfglEnjWwba5wIRmsswncuMobjYRjJ6os1xDEvmZGd+NKyG1yOFmdhQz85sC+/J5i9yRfpfcs/NNeXKv5Yqo1U6VWACwpPG4p6sLrswLDTRaU6XsHTmoWiBtIDBPb4xz8Q5z8rzH1tut52CmdIM32UbU5Uims4qt3VBPljjoMOjgk+2/Vl8NwlrpWrhK/qRJi347aboKbNPticazSZt4VX3ZNUtpLWiBdHo+wco0CBPcBM+ZCqIn9okMDowW5BQmqBOLk1yNFhmf33aImzeshFQXG0xY9FN8JrHTUq9P1NacIXuCtzanH0SvMb/dS2Tjn84XHbAghofSWUrJoaMbR0kkuFxjZjlqOrIzpJS+a1uMIs2WC6edrSO2ghXI9pQ5rvjiv2tkjipPPho8N11zJ6Dh1zoY6KNCkVkJ3f8OpHZtfuSyUNoZ4TMwvTm5rtSs117ELu4K3cigXxZkkyBPSdeKKfoaV7hzjVeudPDF1j29mdrKnnxu//lSsxvfhWsWo0ltGtDdJnsfOu3wX1xHe5dCLRuV880u9xDqC0gHe5+5GLE0xlafUNZ0szqI1m5UJs0nMAjP6lUD1gaCLeEgp+O2l5/rpYrjkuJCRMpJ7hhz/P6ksn8GzH+o1PwkKUmSD5+ix1aHv8EP8TblXkvE5iKjUvZXBKsgGuqK0Bg9Y34Mm5hqiDzqr1skTk2MdI1JfYh2HipDkO1HQL/D8Cveym1qinjhlyPzaI7HtG4jAIHffnLv4erZy8FBTxBA0zdBC+5JbEbYBIO/1WkDsrtDYFgU5Mwuow+n5FNp9yoIeWWWJAqODN6PSrEOI5uYoI+mLZ48ZoiryK/8g5/L2jH85n0ESfbWx0JYYdHy0BOlqL1mbbHb2n9sND2UHshA+QeHlkFGCVCRcZ3e2X6Iy/DE7D4emAJ/fRoCqhryA3D20HoVXZm9aFF+MFXPoeJ+fVvgScCKSJ9VukiQdWbi6S44hzg2uuxH/y7Z9MuXU/SgYuYr51Ndp/+3TiQ0y9TtsAsuB3GGCVWV0knoVSD83x6BwvVF9ykyY0aVjmPxZFdlT5+tTXQsgNJ7cyfZ6C9HoVQ7bcNeJUgXuftLzSzo+R9Z0z94VaFtmAP2jiArC1mykGfVdw7eEDZhx/qPH1GXqPO58zWzH3e8vlQ91bNFIMDiagahuvyHLBoXEl0GQ3/K2cqIN1TbM/2qHyWOmsVldWRY1SrTeQX0aIEDRqIKqtQv5U7ayBOF/YUN6wsmYJ/4SM4G7vRB9XP7mfe/mTSepgW7pVUSF3raFdM/xan4B0SCbA08BwVhKoCS2cDMmDyLkmFrwSTxjEVWzPBHA3NQm8TaRYxdxyAuHKUp8y7Cy5xgZw+SGTO8e1a4FvyFnrChoGFG63JTdDN/S/lMwLpUZWss05RJ87UycsgV8OpK6KKU71gwTawF+pwb1xg5rB4AGms8v/ion
I am trying to use a larger minimum angle in the facets criteria when making a surface mesh. I have good results at 30 degrees, but I would like to try for a larger minimum angle. Once the angle gets above 35 degrees then make_surface_mesh either silently
exits without completing ( manifold with boundary or manifold tags ) or, using the non manifold tag, the error is "already inserted on the surface".
Thank you
- [cgal-discuss] Larger minimum angle in the criteria for make_surface_mesh., Tony Apicella, 01/06/2021
- Re: [cgal-discuss] Larger minimum angle in the criteria for make_surface_mesh., Sebastien Loriot, 01/07/2021
