cgal-discuss - Re: [cgal-discuss] Larger minimum angle in the criteria for make_surface_mesh.
  • To:
  • Subject: Re: [cgal-discuss] Larger minimum angle in the criteria for make_surface_mesh.
  • Date: Thu, 7 Jan 2021 08:58:06 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
In the doc you can find:
"First, the meshing algorithm is proved to terminate if the lower bound on facets angles is not bigger than |30| degrees"
https://doc.cgal.org/latest/Surface_mesher/index.html#title5
Then there might be some bugs in the code but without any minimal example showing the problem we can hardly help.
Best regards,
Sebastien.
On 1/6/21 5:30 AM, Tony Apicella wrote:
I am trying to use a larger minimum angle in the facets criteria when making a surface mesh.   I have good results at 30 degrees, but I would like to try for a larger minimum angle.  Once the angle gets above 35 degrees then make_surface_mesh either silently exits without completing ( manifold with boundary or manifold tags )   or, using the non manifold tag, the error is "already inserted on the surface".
Thank you
