cgal-discuss - Re: [cgal-discuss] crop infinite edges of additive weighted voronoi diagram.
  • To:
  • Subject: Re: [cgal-discuss] crop infinite edges of additive weighted voronoi diagram.
  • Date: Fri, 22 Jan 2021 10:17:43 -0600 (CST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Hi Sebastien,
Thanks a ton for the help. The code is giving the output that I wanted.
Thanks,
Virti
