- To:
- Subject: Re: [cgal-discuss] 3D Mesh Generation: How to enable parallel meshing
- Date: Thu, 14 Jan 2021 10:49:35 -0600 (CST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
- Ironport-phdr: 9a23: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
I am trying to get the Mesh_3 capability to run in parallel. I tried to
build the Mesh_3 example, so I could use the information on this thread,
but cmake kept asking for more installs. I had to install pthreads, eigen3
and vtk and now there is an error message "add_library cannot create ALIAS
target "pugixml" because target "pugixml::pugixml" is imported but not
globally visible."
All I want to do is take the skull example from Mesh_3 and get a timing
difference between serial and parallel.
Thank you.
- Re: [cgal-discuss] 3D Mesh Generation: How to enable parallel meshing, TonyAp, 01/14/2021
