cgal-discuss - Re: [cgal-discuss] Polyhedron demo crashes loading polylines
  • To:
  • Subject: Re: [cgal-discuss] Polyhedron demo crashes loading polylines
  • Date: Wed, 3 Feb 2021 17:54:26 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Try adding an empty line at the end of the file.
If it does not work, could you share the input file?
Thanks,
Sebastien.
On 2/3/21 5:52 PM, David Rochera wrote:
Hello everybody,
I noticed that the Polyhedron demo crashes when using the polyline io plugin to import a polyline from a .txt file. The problem I'm experiencing is similar to the one detailed here:
https://github.com/CGAL/cgal/issues/1084 <https://github.com/CGAL/cgal/issues/1084>
That thread is from some time ago (2016) so I suppose it should have been solved in the recent versions of CGAL (I'm using CGAL 5.1.1), but it still does not work for me (I'm a Mac OS user). If anyone knows how to solve the problem I would be very grateful. Thank you!
Best regards,
David
