cgal-discuss - Re: [cgal-discuss] Polyhedron demo crashes loading polylines
  • To:
  • Subject: Re: [cgal-discuss] Polyhedron demo crashes loading polylines
  • Date: Wed, 3 Feb 2021 18:03:11 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hello, Sebastien,
I added such an empty line at the end but it still does not work. Find attached an example of a polyline which does not work (in general I could not import any polyline at all since using the demo, only if they are generated by hand with "Generate object" menu).
Thanks,
David
On Wed, 3 Feb 2021 at 17:54, Sebastien Loriot <> wrote:
Try adding an empty line at the end of the file.
If it does not work, could you share the input file?
Thanks,
Sebastien.
On 2/3/21 5:52 PM, David Rochera wrote:
> Hello everybody,
> I noticed that the Polyhedron demo crashes when using the polyline io
> plugin to import a polyline from a .txt file. The problem I'm
> experiencing is similar to the one detailed here:
> https://github.com/CGAL/cgal/issues/1084
> <https://github.com/CGAL/cgal/issues/1084>
> That thread is from some time ago (2016) so I suppose it should have
> been solved in the recent versions of CGAL (I'm using CGAL 5.1.1), but
> it still does not work for me (I'm a Mac OS user). If anyone knows how
> to solve the problem I would be very grateful. Thank you!
> Best regards,
> David
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
-0.34566 -0.52128 0.189805 -0.508204 -0.471796 0.291555
-0.34566 -0.52128 0.189805 -0.376489 -0.438269 0.161321
-0.34566 -0.52128 0.189805 -0.495134 -0.368388 0.227462
