- To:
- Subject: Re: [cgal-discuss] Importing PLY file with different face orientations
- Date: Wed, 10 Mar 2021 08:44:48 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi,
What function(s) did you try, and what version of CGAL are you using ? In the version that will be released in a few months, there is a function that should do what you need. It is available in our master branch on github.
Le mar. 9 mars 2021 à 20:32, kunzarizvi <> a écrit :
I did try using this method and tried to change it according to the surface
mesh data structure but I was unable to load the faces individually as
described in their algorithms and examples. This may owe to my limited
knowledge of CGAL if you could advise a way around it?
- [cgal-discuss] Importing PLY file with different face orientations, kunzarizvi, 03/09/2021
- Re: [cgal-discuss] Importing PLY file with different face orientations, Sebastien Loriot, 03/09/2021
- Re: [cgal-discuss] Importing PLY file with different face orientations, kunzarizvi, 03/09/2021
- Re: [cgal-discuss] Importing PLY file with different face orientations, Maxime Gimeno, 03/10/2021
- Re: [cgal-discuss] Importing PLY file with different face orientations, kunzarizvi, 03/10/2021
- Re: [cgal-discuss] Importing PLY file with different face orientations, kunzarizvi, 03/14/2021
- Re: [cgal-discuss] Importing PLY file with different face orientations, Maxime Gimeno, 03/14/2021
- Re: [cgal-discuss] Importing PLY file with different face orientations, kunzarizvi, 03/15/2021
- Re: [cgal-discuss] Importing PLY file with different face orientations, Maxime Gimeno, 03/15/2021
- Re: [cgal-discuss] Importing PLY file with different face orientations, Andreas Fabri, 03/15/2021
