cgal-discuss - Re: [cgal-discuss] Importing PLY file with different face orientations
  • To:
  • Subject: Re: [cgal-discuss] Importing PLY file with different face orientations
  • Date: Mon, 15 Mar 2021 08:52:03 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-hdrordr: A9a23:8pIXeq5JNhZ1bvgZ+wPXwcuBI+orLtY04lQ7vn1ZYQBJc8CeisCllOka0xixszoKRHQ8g7m7VZWoa3Xa6JJz/M01NbCtQAHptAKTXflfxKHlxCDtHDC7y/VU0r1uf7M7JNr7C1V7isiS2njAL/8Lxt6b/Ke0wdrP1nsFd3ANV4hM5xp0YzzrcHFeaxJBAfMCdKa0xs0CnDa4fGRSU8LTPAhjY8Hmh/nm0K3regQHARlP0njrsRqN5KThGxaVmjcyOgk/oosKymTOnwzn6qjLiZjSoXXh/lTe4JhMlNzqxsErPq2xo/IIITbhgBvAXutccoCF1QpanMiS8low1PHDrxA8Vv4Djk/5TyWSnhqo8Qzh3DEyy2aK8zOlqEqmh9P5AA8gA8BMnsZ4f3LimjEdleA575kO5Vuwk7B+MSnt9R6Nm+TgZlVUrQ6PmFIHq8Q0tFA3a/piVJZh6bMluHltOLM7IQrGxOkcYZNTMP0=
  • Ironport-phdr: A9a23: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
Hello,
I think if you have never worked with CGAL before, you should not go for using the
the master branch on github, but you should stick to a released version
and work around your problem.
Also please make an effort to better describe what problem you encounter.
Your sentences are rather cryptic.  Please don't feel offended - it only makes
it very hard  to give reasonable replies or recommendations, as we first have
to guess what you mean.
Best regards,
Andreas
On 3/15/2021 8:33 AM, kunzarizvi wrote:
I first tried to include the polygon mesh io files into my existing project
and work with that but I am running into a lot of problems with this and
even while trying to make a new project running the master version of CGAL.
Could you give me a guide on how to run the cgal version which is available
on github? I tried following the tutorial on docs.cgal but I am unable to do
so because there is no exe file for 5.3. Any help with this would be
appreciated since I have never worked with CGAL before. Thank you!
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
