cgal-discuss - Re: [cgal-discuss] Global numeration (indexing) of Constrained_Delaunay_triangulation_2 Vertex
  • To:
  • Subject: Re: [cgal-discuss] Global numeration (indexing) of Constrained_Delaunay_triangulation_2 Vertex
  • Date: Mon, 22 Mar 2021 08:31:39 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-hdrordr: A9a23:VtD3S6skYNKp8m7aGwKMrGHa7skCKIMji2hD6mlwRA09T+WzkceykPMHkSLlkTp5YgBYpfmsGomlBUnd+5l8/JULMd6ZNjXOlWO0IOhZnO7f6hL6HSmWzJ8+6Y5BdOxEBMT0HRxGi6/BkWqFOvIB5PXCz6yyn+fZyB5WLD1CT6179Q92BkK6PyRNNW17LKE0Hpad+cZLzgDIER8qR/+2CXUfU+/Iq8ejrvLbSCQbDB0q4hTmt0LO1JfGFXGjr3EjegIK77Nn1WTeiQT26uGYrvmnxnbnu1P73tB5nt3uz9cGKe6trowuKjvqghu1f4gJYdC/lQFwjueo5lMn1OPJvg5lBcJu8HncF1vbnTLdnzLt2jov9HPuoGX3vUfe
  • Ironport-phdr: A9a23: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
You can have a look at that example : https://doc.cgal.org/latest/Triangulation_2/Triangulation_2_2info_insert_with_pair_iterator_2_8cpp-example.html
The principle is to use a Vertex_with_index and add the ids yourself while creating the triangulation.You can then access the ID with `Vertex_handle::info()`
Le ven. 19 mars 2021 à 23:46, Bruno Rammon <> a écrit :
I would like to know if it exists some kind of global numeration of the
vertices of a Constrained_Delaunay_triangulation_2. That is, I am wondering
if each vertex of a /created/ triangulation of that type that has a unique
index associated to it. If it does not exist, is there any kind of c++ data
structure that might uniquely distinguish each vertex? For example, a
pointer to an vertex object or something like that, so that I can create a
std::unordered_map<data_structure,int> which associate this data structure
to an unique index.
Best regards,
Bruno
