Re: [cgal-discuss] Global numeration (indexing) of Constrained_Delaunay_triangulation_2 Vertex
- To:
- Subject: Re: [cgal-discuss] Global numeration (indexing) of Constrained_Delaunay_triangulation_2 Vertex
- Date: Mon, 22 Mar 2021 08:56:17 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-hdrordr: A9a23:hXmiK66mFSqkySUz2gPXwcuBI+orLtY04lQ7vn1ZYQBJc8CeisCllOka0xixszoKRHQ8g7m7VZWoa3Xa6JJz/M01NbCtQAHptAKTXflfxKHlxCDtHDC7y/VU0r1uf7M7JNr7C1V7isiS2njAL/8Lxt6b/Ke0wdrP1nsFd3ANV4hM5xp0YzzrcHFeaxJBAfMCdKa0xs0CnDa4fGRSU8LTPAhjY8Hmh/nm0K3regQHARlP0njrsRqN5KThGxaVmjcyOgk/oosKymTOnwzn6qjLiZjSoXXh/lTe4JhMlNzqxsErPq2xo/IIITbhgBvAXutccoCF1QpanMiS8low1PHDrxA8Vv4Djk/5TyWSnhqo8Qzh3DEyy2aK8zOlqEqmh9P5AA8gA8BMnsZ4f3LimjEdleA575kO5Vuwk7B+MSnt9R6Nm+TgZlVUrQ6PmFIHq8Q0tFA3a/piVJZh6bMluHltOLM7IQrGxOkcYZNTMP0=
- Ironport-phdr: A9a23:XNRcwhyJx9xYhZbXCzKmzFBlVkAck4WxBRYc798ds5kLTJ7L16rrMEGX3/hxlliBBdydt6sVzbOK6Ou5ADdIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TW94jEIBxrwKxd+KPjrFY7OlcS30P2594HObwlSizexfLd/IA+roQjeuMQajpZuJrs/xxDUvnZGZuNayH9yK1mOhRj8/MCw/JBi8yRUpf0s8tNLXLv5caolU7FWFSwqPG8p6sLlsxnDVhaP6WAHUmoKiBpIAhPK4w/8U5zsryb1rOt92C2dPc3rUbA5XCmp4ql3RBP0jioMKjg0+3zVhMNtlqJWuA+vqQJxw4DUY4+bOvRxcazfctwGSmRMRdpRWi5bD4+gc4cCAegMMOBFpIf9vVsOqh6+CBGwCePp1zBInGH50rch0+88EQ/JxhcvH8gPsH/Jq9j6LqESXv2vzKbW1zrDdOla2Tnn54fTaBAhoOqBXb1ufsrWzEkgCR/Fjk+QqIzrJTyayvgNs2+B7+tgT+6gl2knqwRorzWp28wjhZXHiJgPxVDY6SV23pw1JdugRUN7btCpDZVeuj2eOodrTM0vQ2NltSQ6xLAHtpO3YSYExponyRPQd/GJfJSE7B39WeuMLzl1hXJodK+hixux/katzPD3WMez0FZPtCVFk9/Mu2gL1xPJ8ceIUf998Vm71TmT0ADT7+dJKl03m6rDM5Mszb89moAOvUjfHiL6gkX7gayMekk65OSl6vzrb7H6qpOGKoN4lwDzPr4wlsG/H+g0KBUCU3Sf9OikyLHv51H1TK9WgvEsjqXUto3RKNofpq6kGA9Vzpgs6wyiATen0dUXg2EKIE5DdRmalYbmIUvOL+r9Dfqng1SjjjNrx/feM7DvGJnNK3/DnKn7cbZ48UFcyQ4zwclY55JJFrENOvXzWlHxtNDCCB82LRC0z/7mCNV7yIweRXqCD6CYPa/IrFOE+uIiL/OMaYIWojrxNeYp6v/2gX88g1AdfK2p3ZUNaHC/G/RrO1+WYXzxjdcbD2gFpBE+QPbkiFKYSjFTfXeyUrkz5j4lD4KmCJnMRpy3gL2B0ie0BIFZZnxBClCWEXbkbZmLW/AJaC6KOM9ujiQEVaS9S48mzRyhqAD6xKBjLubN5yIYtInj28Ro5+3IjhE/7id0DsSY02GVVW54hGIIRzks3KB+u0Nx0FmD0bJgj/xdEtxc+u1GXx8hNZ7Z0+x6E8n+WgXcfteVUFqmQsupATU2Tt8p298OZ1xyGtW8gRDZ3SemHbwYm6aLBJMu6K7c2GbxJ8Znx3bAyqYhk0EqQspJNWK4mq5y7xTfC5TVn0mDi6qmb7gQ0DbX9Gif1WqOoF1YUAloXKrZUnAQfE/Woc3k6UPDVL+hFaknMhBaycOZK6tKbMfpjVRcS/v5NtTeeTH5p2DlDhmBwvaAbZHhZn4G9CTbEkkN1Q4JrlicMg1rLyGtuW/XF3RAHFj1Ygu4+O9ysn6yVQk6xguQbmVu2r2w9wIPlPKVQO8UxKNCsyAk/WYnVG2h1s7bXoLT7zFqe79RNItVyGcC7nrQsklGBrLlL61mgTY2KEJyuBmo0hx2DsBHjNRsq20qigx/NfDAuHtxMgiA1JW1AYX5b2z7/RShcanTsnnR3dGT97sV+foxoEnkphDvHU0noS0P++kQ6GOV49DxNCRXSYj4Om44+h9/qq3Acyc07J/Tz2wqOq6x4Geq5g==
Hello,
Indices are needed if you want to associate information with the help of a std::vector,
but you can use vertex handles directly as key in a std::map or std::unordered_map
typedef CGAL::Constrained_Delaunay_triangulation_2<K>::Vertex_handle Vertex_handle;
std::map<Vertex_handle, double> vertex_temperature;
vertex_temparature[cdt.infinite_vertex()] = std::numeric_limits<double>::max();
best,
andreas
On 3/19/2021 11:46 PM, Bruno Rammon ( via cgal-discuss Mailing List) wrote:
I would like to know if it exists some kind of global numeration of the--
vertices of a Constrained_Delaunay_triangulation_2. That is, I am wondering
if each vertex of a /created/ triangulation of that type that has a unique
index associated to it. If it does not exist, is there any kind of c++ data
structure that might uniquely distinguish each vertex? For example, a
pointer to an vertex object or something like that, so that I can create a
std::unordered_map<data_structure,int> which associate this data structure
to an unique index.
Best regards,
Bruno
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
- [cgal-discuss] Global numeration (indexing) of Constrained_Delaunay_triangulation_2 Vertex, Bruno Rammon, 03/19/2021
- Re: [cgal-discuss] Global numeration (indexing) of Constrained_Delaunay_triangulation_2 Vertex, Maxime Gimeno, 03/22/2021
- Re: [cgal-discuss] Global numeration (indexing) of Constrained_Delaunay_triangulation_2 Vertex, Andreas Fabri, 03/22/2021
