- To:
- Subject: Re: [cgal-discuss] Subtracting spheres from a mesh
- Date: Sat, 24 Apr 2021 11:28:22 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-hdrordr: A9a23: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
- Ironport-phdr: A9a23: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
Thanks for the reply Sebastien :)
Unfortunately I can't use a kd-tree because the spheres can have different radii, so a point won't necessarily be inside the closest sphere.
I have tried adapting an AABB tree to use spheres as primitives, but it doesn't seem to work when querying for intersections with points.
I admittedly don't know how the bounding boxes are created or whether querying for intersections is a valid thing to do.
For reference, this is what I was doing with AABB trees:
class AABBSpherePrimitive {
public:
using Point = Point_3;
using Datum = Sphere_3;
using Point_reference = Point;
using Datum_reference = Datum;
using Id = Datum;
AABBSpherePrimitive(Sphere_3 sphere)
: m_sphere_datum(sphere)
m_reference_point = sphere.center();
m_reference_point += K::Vector_3{std::sqrt(sphere.squared_radius()), 0, 0};
Datum_reference datum() const { return m_sphere_datum; }
Id id() const { return m_sphere_datum; }
Point_reference reference_point() const { return m_reference_point; }
private:
Datum m_sphere_datum;
Point m_reference_point;
using SphereTreeTraits = CGAL::AABB_traits<K, AABBSpherePrimitive>;
using SphereTree = CGAL::AABB_tree<SphereTreeTraits>;
public:
using Id = Datum;
private:
On Sat, Apr 24, 2021 at 7:42 AM Sebastien Loriot <> wrote:
What I would do is generate a mesh for the union of spheres by adapting
this example:
https://doc.cgal.org/latest/Mesh_3/Mesh_3_2mesh_implicit_sphere_8cpp-example.html
to handle several spheres.
To do that, I think the simplest way to do it is to use a kd-tree [1] to
get the closest sphere center from the query point and then use the
existing formula with the selected sphere.
Let us know if you could do it.
Best,
Sebastien.
[1] https://doc.cgal.org/latest/Spatial_searching/index.html
On 4/23/21 11:57 PM, bmanga ( via cgal-discuss
Mailing List) wrote:
> I have also tried to use
> PMP::experimental::autorefine_and_remove_self_intersections, but it fails
> with the following:
> CGAL error: precondition violation!
> _expression_ : vaa != vbb
> Sent from: http://cgal-discuss.949826.n4.nabble.com/
- [cgal-discuss] Subtracting spheres from a mesh, bmanga, 04/23/2021
- Re: [cgal-discuss] Subtracting spheres from a mesh, bmanga, 04/23/2021
- Re: [cgal-discuss] Subtracting spheres from a mesh, Sebastien Loriot, 04/24/2021
- Re: [cgal-discuss] Subtracting spheres from a mesh, Bruno Manganelli, 04/24/2021
- Re: [cgal-discuss] Subtracting spheres from a mesh, Bruno Manganelli, 04/25/2021
- Re: [cgal-discuss] Subtracting spheres from a mesh, Sebastien Loriot, 04/25/2021
- Re: [cgal-discuss] Subtracting spheres from a mesh, Sebastien Loriot, 04/26/2021
- Re: [cgal-discuss] Subtracting spheres from a mesh, Bruno Manganelli, 04/26/2021
