cgal-discuss - Re: [cgal-discuss] Subtracting spheres from a mesh
  • To:
  • Subject: Re: [cgal-discuss] Subtracting spheres from a mesh
  • Date: Mon, 26 Apr 2021 11:26:38 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-hdrordr: A9a23:cFIofa/0oAVMgC31aBNuk+B4I+orLtY04lQ7vn1ZYxpTb8CeioSSh/wdzxD5k3I8X3snlNCGNsC7MBHh3LRy5pQcOqrnYRn+tAKTXeJfxKbr3jGIIUbD38FH06MIScJDIf32SWN3lMPrpDS/euxO/PCi0ISFwdjT1G1sSwYCUcFdxiN0EBySHEEzZCQuP/YEPaGR7MZGuDasEE5/BviTPXULU/POoNfGjvvdDyIuPQIt6wWFkFqTiYLSLhmC0h8SFxNJzLsymFK19TDR26S5v/m3jiLbzm/Yhq4m/+fJ990rPqGxo/lQDj3tjwqyDb4RP4GqjXQSu+Gg6FEjjdnKrVMBBq1ImhbsQl0=
  • Ironport-phdr: A9a23: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
I think there is a missing return statement in make_skin_suface_mesh_3.h after line 37.
Adding that fixed my issue.
On Mon, Apr 26, 2021 at 11:21 AM Sebastien Loriot <> wrote:
Do you have a minimal example we could use to reproduce the issue?
Did you also try this example:
https://doc.cgal.org/latest/Skin_surface_3/Skin_surface_3_2union_of_balls_simple_8cpp-example.html
Best,
Sebastien.
On 4/26/21 11:09 AM, Bruno Manganelli ( via
cgal-discuss Mailing List) wrote:
> That indeed is exactly what I needed, thanks!
> Without mesh subdivision and shrink_factor of 1, the algorithm takes
> less than 5s.
> However, trying to execute CGAL::subdivide_skin_surface_mesh_3 on the
> surface generated with the shrink_factor of 1 results in an assertion
> failure in in triangulate_mixed_complex_3.h:983
> CGAL_assertion(orientation(ch) == POSITIVE);
> Is this expected? I couldn't find the requirement that shrink_factor
> must be < 1 in the documentation.
> On Mon, Apr 26, 2021 at 8:26 AM Sebastien Loriot <
> <mailto:>> wrote:
>     Andreas mentioned that there is the following package that also might
>     fit you need (in case you want more that spheres):
>     https://doc.cgal.org/latest/Skin_surface_3/index.html#Chapter_3D_Skin_Surface_Meshing
>     <https://doc.cgal.org/latest/Skin_surface_3/index.html#Chapter_3D_Skin_Surface_Meshing>
>     Best,
>     Sebastien.
>     On 4/25/21 11:42 AM, Sebastien Loriot wrote:
>      > Did you switch on parallel meshing?
>      > By default the points on the spheres are computing by bisection.
>      > It is possible to provide a specific functor for computing points
>      > on the surface.
>      > Best,
>      > Sebastien.
>      > On 4/25/21 11:12 AM, Bruno Manganelli (
>     <mailto:> via
>      > cgal-discuss Mailing List) wrote:
>      >> Thanks for all your dedication to help :)
>      >> I have tried your method, and indeed it works. However it is still
>      >> fairly slow, taking around 70 s to process 761 spheres (on a
>     ryzen 5
>      >> 3600). Do you think there are any optimizations that I could try
>     or do
>      >> you think it will be hard to significantly speed  up this approach?
>      >> On Sat, Apr 24, 2021 at 2:50 PM Sebastien Loriot
>      >> < <mailto:>
>     <mailto: <mailto:>>> wrote:
>      >>     With the following code (quick and dirty):
>      >> https://gist.github.com/sloriot/d563b5ce27d28fcfd73beb1b628d72b5
>     <https://gist.github.com/sloriot/d563b5ce27d28fcfd73beb1b628d72b5>
>     <https://gist.github.com/sloriot/d563b5ce27d28fcfd73beb1b628d72b5>>
>      >>     I could generate a mesh.
>      >>     Best,
>      >>     Sebastien.
>      >>     PS: there might be some initialization issues if you have
>     several
>      >>     (small) connected components and initial points should be added.
>      >>     If you need clean intersections then some extra work is also
>     needed.
>      >>     On 4/24/21 2:06 PM, Sebastien Loriot wrote:
>      >>      > If you take the maximum radius, you can collect all the
>     closest
>      >> point
>      >>      > to the query and stop when you exceed the maximum radius.
>      >>      > You can associate the radius to each point like in this
>     exemple:
>     https://doc.cgal.org/latest/Spatial_searching/Spatial_searching_2searching_with_point_with_info_8cpp-example.html
>     <https://doc.cgal.org/latest/Spatial_searching/Spatial_searching_2searching_with_point_with_info_8cpp-example.html>
>     <https://doc.cgal.org/latest/Spatial_searching/Spatial_searching_2searching_with_point_with_info_8cpp-example.html>>
>      >>      > HTH,
>      >>      > Sebastien.
>      >>      > On 4/24/21 11:28 AM, Bruno Manganelli
>     ( <mailto:>
>      >>     <mailto:
>     <mailto:>> via
>      >>      > cgal-discuss Mailing List) wrote:
>      >>      >> Thanks for the reply Sebastien :)
>      >>      >> Unfortunately I can't use a kd-tree because the spheres
>     can have
>      >>      >> different radii, so a point won't necessarily be inside the
>      >> closest
>      >>      >> sphere.
>      >>      >> I have tried adapting an AABB tree to use spheres as
>     primitives,
>      >>     but
>      >>      >> it doesn't seem to work when querying for intersections
>     with
>      >> points.
>      >>      >> I admittedly don't know how the bounding boxes are
>     created or
>      >>     whether
>      >>      >> querying for intersections is a valid thing to do.
>      >>      >> For reference, this is what I was doing with AABB trees:
>      >>      >> class AABBSpherePrimitive {
>      >>      >>   public:
>      >>      >>     using Point = Point_3;
>      >>      >>     using Datum = Sphere_3;
>      >>      >>     using Point_reference = Point;
>      >>      >>     using Datum_reference = Datum;
>      >>      >>     using Id = Datum;
>      >>      >>     AABBSpherePrimitive(Sphere_3 sphere)
>      >>      >>         : m_sphere_datum(sphere)
>      >>      >>       m_reference_point = sphere.center();
>      >>      >>       m_reference_point +=
>      >>      >> K::Vector_3{std::sqrt(sphere.squared_radius()), 0, 0};
>      >>      >>     Datum_reference datum() const { return m_sphere_datum; }
>      >>      >>     Id id() const { return m_sphere_datum; }
>      >>      >>     Point_reference reference_point() const { return
>      >>     m_reference_point; }
>      >>      >>   private:
>      >>      >>     Datum m_sphere_datum;
>      >>      >>     Point m_reference_point;
>      >>      >> using SphereTreeTraits = CGAL::AABB_traits<K,
>      >> AABBSpherePrimitive>;
>      >>      >> using SphereTree = CGAL::AABB_tree<SphereTreeTraits>;
>      >>      >> On Sat, Apr 24, 2021 at 7:42 AM Sebastien Loriot
>      >>      >> < <mailto:>
>     <mailto: <mailto:>>
>      >>     <mailto: <mailto:>
>     <mailto: <mailto:>>>> wrote:
>      >>      >>     What I would do is generate a mesh for the union of
>      >> spheres by
>      >>      >> adapting
>      >>      >>     this example:
>     https://doc.cgal.org/latest/Mesh_3/Mesh_3_2mesh_implicit_sphere_8cpp-example.html
>     <https://doc.cgal.org/latest/Mesh_3/Mesh_3_2mesh_implicit_sphere_8cpp-example.html>
>     <https://doc.cgal.org/latest/Mesh_3/Mesh_3_2mesh_implicit_sphere_8cpp-example.html>>
>     <https://doc.cgal.org/latest/Mesh_3/Mesh_3_2mesh_implicit_sphere_8cpp-example.html>>>
>      >>      >>     to handle several spheres.
>      >>      >>     To do that, I think the simplest way to do it is to
>     use a
>      >>     kd-tree
>      >>      >> [1] to
>      >>      >>     get the closest sphere center from the query point
>     and then
>      >>     use the
>      >>      >>     existing formula with the selected sphere.
>      >>      >>     Let us know if you could do it.
>      >>      >>     Best,
>      >>      >>     Sebastien.
>      >>      >>     [1]
>     https://doc.cgal.org/latest/Spatial_searching/index.html
>     <https://doc.cgal.org/latest/Spatial_searching/index.html>
>      >>     <https://doc.cgal.org/latest/Spatial_searching/index.html
>     <https://doc.cgal.org/latest/Spatial_searching/index.html>>
>     <https://doc.cgal.org/latest/Spatial_searching/index.html>>>
>      >>      >>     On 4/23/21 11:57 PM, bmanga (
>     <mailto:>
>      >>     <mailto:
>     <mailto:>>
>      >>      >>     <mailto:
>     <mailto:>
>      >>     <mailto:
>     <mailto:>>> via cgal-discuss
>      >>      >>     Mailing List) wrote:
>      >>      >>      > I have also tried to use
>      >>     PMP::experimental::autorefine_and_remove_self_intersections, but
>      >>      >>     it fails
>      >>      >>      > with the following:
>      >>      >>      > CGAL error: precondition violation!
>      >>      >>      > _expression_ : vaa != vbb
>      >>      >>      > Sent from:
>     http://cgal-discuss.949826.n4.nabble.com/
>     <http://cgal-discuss.949826.n4.nabble.com/>
>      >>     <http://cgal-discuss.949826.n4.nabble.com/
>     <http://cgal-discuss.949826.n4.nabble.com/>>
>      >>      >>     <http://cgal-discuss.949826.n4.nabble.com/
>     <http://cgal-discuss.949826.n4.nabble.com/>>>
>      >>      >>     --     You are currently subscribed to cgal-discuss.
>      >>      >>     To unsubscribe or access the archives, go to
>      >>      >> https://sympa.inria.fr/sympa/info/cgal-discuss
>     <https://sympa.inria.fr/sympa/info/cgal-discuss>
>      >>     <https://sympa.inria.fr/sympa/info/cgal-discuss
>     <https://sympa.inria.fr/sympa/info/cgal-discuss>>
>      >>      >>     <https://sympa.inria.fr/sympa/info/cgal-discuss
>     <https://sympa.inria.fr/sympa/info/cgal-discuss>>>
>      >>      >> You are currently subscribed to cgal-discuss.
