cgal-discuss - Re: [cgal-discuss] classification
  • To:
  • Subject: Re: [cgal-discuss] classification
  • Date: Sat, 24 Apr 2021 20:31:22 -0500 (CDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
  • Ironport-hdrordr: A9a23:+79RyayU/z+ZWpTiGOzpKrPw+71zdoIgy1knxilNYDZSddGVkN3roe8S0gX6hC1UdHYrn92BP6foexPh3LRy5pQcOqrnYRn+tAKTTb1KwIP+z1TbcBHW2fVa0c5bGZRWLP3VIRxEgd3h4A++euxP/PCi/LqzjenTi1dBJDsHV4ha4w10ChmWHyRNLWF7LKAkH5mR7NcvnVWdUEkQB/7XOkU4
  • Ironport-phdr: A9a23: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
Dear si
I use the source code to generate the feature.
features.add<verticality>(pts, normal_map);
it shows that
C:\dev\boost\boost/property_map/property_map.hpp(304): error C2678:
二进制(binary)“[”: 没有找到接受“const
CGAL::Point_set_3<Point,CGAL::Vector_3&lt;Kernel_>>::Property_map<Vector>”类型的左操作数的运算符(left
operator of type)(或没有可接受的转换(no acceptable transform))
but in the source code,
generator.generate_normal_based_features (pointwise_features,
pts.normal_map());
in the function generate_normal_based_features,
the source code is
features.add<verticality>(pts,normal_map);
can you tell me what's wrong?
thank you!
wangtao
