- To: "wangtao8869 ( via cgal-discuss Mailing List)" <>
- Subject: Re: [cgal-discuss] classification
- Date: Mon, 26 Apr 2021 08:25:02 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-hdrordr: A9a23:QC4ona0Ii4qr/X9Z1OXxnwqjBbFyeYIsi2QD101hICF9WtCElsyogfQQ3QL1jjFUY307hdWcIsC7LE/035hz/IUXIPOGVA7ppGOnIOhZnPPf6hfnHDDz8fMY6LxpdLJwBMa1IV9xi8v75wfQKadY/PCs9qe0ieDCi0p8VA0CUdAH0y5VAhuWe3cGJjVuKoE+EPOnhvZvhz3lQngPa9T+O39tZZmlm/TutLbLJSELHAQm7g7mt0LN1JffHwKD1hkTFxNjqI1SklTtqADy6qW9v/zT8Ha1vAXuxq9bl9f7xtxICNbksKkoAw/xgQWlbpkJYdK/lQ0yydvA1H8XitXW5z8vM8NvgkmhG12dkF/K5Ail+jMv53j+6UbwuxfeiP28Yi06T/dbjYhUaV/45iMbzapB+ZMO4FncjaN+KTnpoB7QjuK4Ky1Cpw6Kmj4ZqMY2tVZ4aqd2Us4tkaUvuHxvVK04NAbB1agbPIBVfbvh2Mo=
- Ironport-phdr: A9a23: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
Dear wangtao,
Again, it's hard to tell with so little information: can you share the full source code, or at least some context (typedefs, variable declarations, etc.)?
Best,
Simon Giraudot, PhD
R&D Engineer
GeometryFactory - http://geometryfactory.com/
Le 25/04/2021 à 03:31, wangtao8869 ( via cgal-discuss Mailing List) a écrit :
Dear si
I use the source code to generate the feature.
features.add<verticality>(pts, normal_map);
it shows that
C:\dev\boost\boost/property_map/property_map.hpp(304): error C2678:
二进制(binary)“[”: 没有找到接受“const
CGAL::Point_set_3<Point,CGAL::Vector_3<Kernel_>>::Property_map<Vector>”类型的左操作数的运算符(left
operator of type)(或没有可接受的转换(no acceptable transform))
but in the source code,
generator.generate_normal_based_features (pointwise_features,
pts.normal_map());
in the function generate_normal_based_features,
the source code is
features.add<verticality>(pts,normal_map);
can you tell me what's wrong?
thank you!
wangtao
- [cgal-discuss] classification, wangtao8869, 04/22/2021
- Re: [cgal-discuss] classification, Simon Giraudot, 04/22/2021
- Re: [cgal-discuss] classification, wangtao8869, 04/25/2021
- Re: [cgal-discuss] classification, Simon Giraudot, 04/26/2021
- Re: [cgal-discuss] classification, wangtao8869, 04/27/2021
- Re: [cgal-discuss] classification, Simon Giraudot, 04/27/2021
- Re: [cgal-discuss] classification, wangtao8869, 04/30/2021
