Re: [cgal-discuss] Valid and closed polyhedron cannot be converted into nef polyhedron
- To:
- Subject: Re: [cgal-discuss] Valid and closed polyhedron cannot be converted into nef polyhedron
- Date: Wed, 5 May 2021 09:02:19 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-hdrordr: A9a23:7O5ZAauC8ppytoGQm5InEuIe7skCKIMji2hD6mlwRA09T+WzkceykPMHkSLlkTp5YgBYpfmsGomlBUnd+5l8/JULMd6ZNjXOlWO0IOhZnO7f6hL6HSmWzJ8+6Y5BdOxEBMT0HRxGi6/BkWqFOvIB5PXCz6yyn+fZyB5WLD1CT6179Q92BkK6PyRNNW17LKE0Hpad+cZLzgDIER8qR/+2CXUfU+/Iq8ejrvLbSCQbDB0q4hTmt0LO1JfGFXGjr3EjegIK77Nn1WTeiQT26uGYrvmnxnbnu1P73tB5nt3uz9cGKe6trowuKjvqghu1f4gJYdC/lQFwjueo5lMn1OPJvg5lBcJu8HncF1vbnTLdnzLt2jov9HPuoGX3vUfe
- Ironport-phdr: A9a23:9diY5h0GpvMp+SgLsmDOUgMyDhhPgJ3EezUN459isYplN5qZl7zcNUDSrc9gkEXOFd2Cra4d2qyM6P+rCDVIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TW94jEIBxrwKxd+KPjrFY7OlcS30P2594HObwlSizexfLd/IA+ooQjftMQajo9vJrsswRbVv3VEfPhby3l1LlyJhRb84cmw/J9n8ytOvv8q6tBNX6bncakmVLJUFDspPXw7683trhnDUBCA5mAAXWUMkxpHGBbK4RfnVZrsqCT6t+592C6HPc3qSL0/RDqv47t3RBLulSwKMSMy/mPKhcxqlK9UrxyhqB5/zYDaY4+bKeRwcb/GcNwAWWZMRNxcWzBdDo6+aYYEEuoPPfxfr4n4v1YAqgGxBAatBOPq1DBDm3743aw/0+s/FwHG2xErEtULsHvOo9T1NaISXv6vwKnHzDXDau1Z2TH66IXTfRAhpOuDXbN0ccbL1UYvEAbFg0yWpIf4MDybyv4DvHKH7+p8S+2vkWgnphl/rzWgycogl4nHiI0bx13a6Sh0wYk4KcO3RkN6fNKpDJRduzyVOoZqQc4uX31ltDo1x7Aat5C2fCcExIg6yxLDbfGMboaG4hXmVOmLIDd4gmpod66whxmo9Uis0Or8VtO70FpSrypFlMPMtnEX2BDJ5MiHUP1w9Vqi1zaXzw3f9P1ILEQumafYK5Mt2KA8moQOvUjZAyP7mln6gamLfUs+4Oeo8f7oYrD+q5+cKYB0jgb+P7wrmsOlAOQ4NhECX3aY+eihzbHj81D1TbdWgvEsnanZt5faJcsfpqGnGQNazoEj6xOnAzen1tQXg2UHIUpbdB6bi4XlIVLDLfDiAfuhnVigjS1ny+3EM7H9GpnNK2LMkLblfbZz8U5czw8zwMha551OBbABIffzVVHruNzXDx85NhK7w+DgCNhm2YMeXHiAAq6dMK/IrVCI4ecvL/GWZIAJoDb9N+Ql5/n2gHAlll8SZ62p0YIKZ3C5BfRpP1iZYWH3gtoaCmcLvg8+TPTwh1GYUD5TYWyyX6Mm6T0hBoKmF9SLe4a2nbbU3DunBoYEISddG1WUGDHpcZ+FUrECcmWJM8p5m3sFU7amDIQu3BXruA7hwKd8Nbnp/DYFv7L/0dwg5/HPjQpgsntvHsGF2ieMSXt1lyUGXXgtzaVnqAt8zFmElqN3ivgdGd1I7O5SSVQHM4XBxdB3G8ynWh7dZszbDxG9U9C+CHcwSMgwypkAeQFmCtC6h1fC2SStRLQanrjOCJ0v+b/HxCvNIJN2xH/CkaUglFI7WdBnNGu8h6c5+RKAKZTOlhC8nrarcKlU8y/I+WGEhT6LtVFZVQM2XqTAUHYYTkTTpNX9oEjFSun9WvwcLgJdxJvaeeNxYdrzgAAeLN/Tfe/Gamf0oF+eQA6Sz9ukY4/jemFb1yLYWhBsuzBWxm6PME0FPgnko2/aC1RGEFvuZwby8rA7pirkFgk7yAaFa0An3L2wqEZ9rczZcOsa2/c/gAlkrjx1GFin2Ne+I9WFrgtlOq5bZIFkiGo=
Hi,
I think the problem is your kernel. If you look at the documentation, you can see that the kernel used for a Nef_polyhedron_3 must be exact, and the one you are using has inexact constructions. You can try to replace Epick by Epeck, I have tried on my machine and it works.
Le mar. 4 mai 2021 à 23:46, Matthew Lai <> a écrit :
Hello!I am running into an assertion fail trying to convert a polyhedron into a Nef polyhedron, despite the polyhedron being apparently closed and valid. Can someone help?I have simplified it down to this minimal test case including the model file:=============================================#include <iostream>
#include <sstream>
#include "CGAL/Exact_predicates_inexact_constructions_kernel.h"
#include "CGAL/Nef_polyhedron_3.h"
#include "CGAL/Polyhedron_3.h"
namespace {
constexpr char kModel[] = R"""(
OFF
24 52 0
296.9305 -36.80449 0
296.9305 -280 0
296.9305 -36.80449 50
296.9305 -280 50
30.94792 -36.80449 0
30.94792 -36.80449 50
30.94792 -280 0
30.94792 -280 50
296.9305 -322.1497 0
296.9305 -529.0251 0
296.9305 -322.1497 50
296.9305 -529.0251 50
30.94792 -322.1497 0
30.94792 -322.1497 50
30.94792 -529.0251 0
30.94792 -529.0251 50
0 0 0
0 -560 0
0 0 50
0 -560 50
330 -3.944305e-30 0
330 0 50
330 -560 0
330 -560 50
3 0 1 2
3 2 1 3
3 4 0 5
3 5 0 2
3 6 4 7
3 7 4 5
3 1 6 3
3 3 6 7
3 8 9 10
3 10 9 11
3 12 8 13
3 13 8 10
3 14 12 15
3 15 12 13
3 9 14 11
3 11 14 15
3 16 17 18
3 18 17 19
3 20 16 21
3 21 16 18
3 22 20 23
3 23 20 21
3 17 22 19
3 19 22 23
3 15 19 11
3 11 19 23
3 11 23 10
3 10 23 3
3 10 3 7
3 15 13 19
3 19 13 7
3 19 7 18
3 18 7 5
3 18 5 2
3 13 10 7
3 18 2 21
3 21 2 3
3 21 3 23
3 12 14 17
3 17 14 9
3 17 9 22
3 22 9 8
3 22 8 1
3 1 8 12
3 1 12 6
3 6 12 17
3 6 17 16
3 22 1 20
3 20 1 0
3 20 0 16
3 16 0 4
3 16 4 6
using Kernel = CGAL::Exact_predicates_inexact_constructions_kernel;
using Polyhedron_3 = CGAL::Polyhedron_3<Kernel>;
using Nef_polyhedron_3 = CGAL::Nef_polyhedron_3<Kernel>;
} // namespace
int main(int argc, char** argv) {
Polyhedron_3 poly;
std::stringstream ss(kModel);
ss >> poly;
poly.normalize_border();
std::cout << "is_closed(): " << poly.is_closed() << std::endl;
std::cout << "is_valid(): " << poly.is_valid(false, 1) << std::endl;
std::cout << "is_pure_triangle(): " << poly.is_pure_triangle() << std::endl;
std::cout << "# faces: " << poly.size_of_facets() << std::endl;
std::cout << "# vertices: " << poly.size_of_vertices() << std::endl;
std::cout << "# border halfedges: " << poly.size_of_border_halfedges() << std::endl;
Nef_polyhedron_3 nef_poly(poly);
std::cout << "volumes: " << nef_poly.number_of_volumes() << std::endl;
std::cout << "nef(poly) is_valid: " << nef_poly.is_valid(false, 3) << std::endl;
std::cout << "is_simple: " << nef_poly.is_simple() << std::endl;
}=============================================And this is the output:=============================================is_closed(): 1
is_valid(): 1
is_pure_triangle(): 1
# faces: 52
# vertices: 24
# border halfedges: 0
CGAL error: assertion violation!
_expression_ : ss_circle.has_on(sv_prev->point())
File : CGAL/Nef_3/polygon_mesh_to_nef_3.h
Line : 256
Explanation:
Refer to the bug-reporting instructions at https://www.cgal.org/bug_report.html
Unhandled exception:
@ 0x55c31fb34732 GoogleTerminateHandler()
@ 0x55c31fc5a768 std::__terminate()
@ 0x55c31fc59dfb __cxxabiv1::failed_throw()
@ 0x55c31fc59d75 __cxa_throw
@ 0x55c31fab767c CGAL::assertion_fail()
@ 0x55c31faecdcd CGAL::polygon_mesh_to_nef_3<>()
@ 0x55c31fac2ec2 CGAL::polyhedron_3_to_nef_3<>()
@ 0x55c31fab6ea6 CGAL::Nef_polyhedron_3<>::Nef_polyhedron_3<>()
@ 0x55c31fab5bbb main
@ 0x7f1dff68abbd __libc_start_main
@ 0x55c31fab5569 _start
libc++abi: terminating with uncaught exception of type CGAL::Assertion_exception: CGAL ERROR: assertion violation!
Expr: ss_circle.has_on(sv_prev->point())
File: CGAL/Nef_3/polygon_mesh_to_nef_3.h
Line: 256
*** SIGABRT received by PID 3953462 (TID 3953462) on cpu 10 from PID 3953462; ***
E0504 22:31:27.565500 3953462 process_state.cc:770] RAW: Raising signal 6 with default behavior
Aborted=============================================Thanks for your help!Matthew
- [cgal-discuss] Valid and closed polyhedron cannot be converted into nef polyhedron, Matthew Lai, 05/04/2021
- Re: [cgal-discuss] Valid and closed polyhedron cannot be converted into nef polyhedron, Maxime Gimeno, 05/05/2021
- Re: [cgal-discuss] Valid and closed polyhedron cannot be converted into nef polyhedron, Matthew Lai, 05/05/2021
- Re: [cgal-discuss] Valid and closed polyhedron cannot be converted into nef polyhedron, Sebastien Loriot, 05/05/2021
