Re: [cgal-discuss] Valid and closed polyhedron cannot be converted into nef polyhedron
- To:
- Subject: Re: [cgal-discuss] Valid and closed polyhedron cannot be converted into nef polyhedron
- Date: Wed, 5 May 2021 14:32:12 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-hdrordr: A9a23:Ool7XK5BNFmBHJmrXQPXwADXdLJzesId70hD6mlaTxtJfsuE0/2/hfhz726WtB89UGwt8OrwXZWobmjb8fdOj7U5GZeHcE3YtHCzLIdkhLGD/xTFFzfl/uBQkYdsGpIOauHYNlRxgcbk7ATQKb9Jq7O62ZulnOLPi0pqJDsKV4hb8wx7BgyHe3cbeCB6A/MCeaa0145irzqkdW9/VKuGOkU=
- Ironport-phdr: A9a23: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
Indeed in such cases, you need to stick to Nef.
There has been a try to implement one simple approximate version:
https://github.com/CGAL/cgal/pull/3302
But we were having some expensive runtime issues that I did not have
time to look at and fix it.
Sebastien.
On 5/5/21 11:24 AM, Matthew Lai ( via cgal-discuss Mailing List) wrote:
Thanks!
I am actually only using Nef as input to convex decomposition. I assume it only supports Nef?
Matthew
On Wed, May 5, 2021 at 9:48 AM Sebastien Loriot < <>> wrote:
Note that there is an alternative package to perform Boolean operations
(with some restrictions on the kind of input/output handled) available
in the Polygon mesh processing package:
https://doc.cgal.org/latest/Polygon_mesh_processing/#title13
<https://doc.cgal.org/latest/Polygon_mesh_processing/#title13>
Those restriction enables this package to have better runtimes than
Nef.
Best regards,
Sebastien.
On 5/5/21 10:36 AM, Matthew Lai (
<> via cgal-discuss
> Thanks Maxime.
> I had missed that part of the documentation, and indeed switching to
> EPECK fixed it.
> Thanks for your help!
> On Wed, May 5, 2021 at 8:03 AM Maxime Gimeno
> < <>>> wrote:
> Hi,
> I think the problem is your kernel. If you look at the
documentation
> <https://doc.cgal.org/latest/Nef_3/classCGAL_1_1Nef__polyhedron__3.html <https://doc.cgal.org/latest/Nef_3/classCGAL_1_1Nef__polyhedron__3.html>>,
> you can see that the kernel used for a Nef_polyhedron_3 must be
> exact, and the one you are using has inexact constructions.
You can
> try to replace Epick by Epeck
> <https://doc.cgal.org/latest/Kernel_23/classCGAL_1_1Exact__predicates__exact__constructions__kernel.html <https://doc.cgal.org/latest/Kernel_23/classCGAL_1_1Exact__predicates__exact__constructions__kernel.html>>,
> I have tried on my machine and it works.
> Le mar. 4 mai 2021 à 23:46, Matthew Lai
<>>> a écrit :
> Hello!
> I am running into an assertion fail trying to convert a
> polyhedron into a Nef polyhedron, despite the polyhedron
being
> apparently closed and valid. Can someone help?
> I have simplified it down to this minimal test case including
> the model file:
> #include <iostream>
> #include <sstream>
> #include
"CGAL/Exact_predicates_inexact_constructions_kernel.h"
> #include "CGAL/Nef_polyhedron_3.h"
> #include "CGAL/Polyhedron_3.h"
> namespace {
> constexpr char kModel[] = R"""(
> OFF
> 24 52 0
> 296.9305 -36.80449 0
> 296.9305 -280 0
> 296.9305 -36.80449 50
> 296.9305 -280 50
> 30.94792 -36.80449 0
> 30.94792 -36.80449 50
> 30.94792 -280 0
> 30.94792 -280 50
> 296.9305 -322.1497 0
> 296.9305 -529.0251 0
> 296.9305 -322.1497 50
> 296.9305 -529.0251 50
> 30.94792 -322.1497 0
> 30.94792 -322.1497 50
> 30.94792 -529.0251 0
> 30.94792 -529.0251 50
> 0 0 0
> 0 -560 0
> 0 0 50
> 0 -560 50
> 330 -3.944305e-30 0
> 330 0 50
> 330 -560 0
> 330 -560 50
> 3 0 1 2
> 3 2 1 3
> 3 4 0 5
> 3 5 0 2
> 3 6 4 7
> 3 7 4 5
> 3 1 6 3
> 3 3 6 7
> 3 8 9 10
> 3 10 9 11
> 3 12 8 13
> 3 13 8 10
> 3 14 12 15
> 3 15 12 13
> 3 9 14 11
> 3 11 14 15
> 3 16 17 18
> 3 18 17 19
> 3 20 16 21
> 3 21 16 18
> 3 22 20 23
> 3 23 20 21
> 3 17 22 19
> 3 19 22 23
> 3 15 19 11
> 3 11 19 23
> 3 11 23 10
> 3 10 23 3
> 3 10 3 7
> 3 15 13 19
> 3 19 13 7
> 3 19 7 18
> 3 18 7 5
> 3 18 5 2
> 3 13 10 7
> 3 18 2 21
> 3 21 2 3
> 3 21 3 23
> 3 12 14 17
> 3 17 14 9
> 3 17 9 22
> 3 22 9 8
> 3 22 8 1
> 3 1 8 12
> 3 1 12 6
> 3 6 12 17
> 3 6 17 16
> 3 22 1 20
> 3 20 1 0
> 3 20 0 16
> 3 16 0 4
> 3 16 4 6
> using Kernel =
CGAL::Exact_predicates_inexact_constructions_kernel;
> using Polyhedron_3 = CGAL::Polyhedron_3<Kernel>;
> using Nef_polyhedron_3 = CGAL::Nef_polyhedron_3<Kernel>;
> } // namespace
> int main(int argc, char** argv) {
> Polyhedron_3 poly;
> std::stringstream ss(kModel);
> ss >> poly;
> poly.normalize_border();
> std::cout << "is_closed(): " << poly.is_closed() <<
std::endl;
> std::cout << "is_valid(): " << poly.is_valid(false, 1) <<
> std::endl;
> std::cout << "is_pure_triangle(): " <<
> poly.is_pure_triangle() << std::endl;
> std::cout << "# faces: " << poly.size_of_facets() <<
std::endl;
> std::cout << "# vertices: " << poly.size_of_vertices() <<
> std::endl;
> std::cout << "# border halfedges: " <<
> poly.size_of_border_halfedges() << std::endl;
> Nef_polyhedron_3 nef_poly(poly);
> std::cout << "volumes: " <<
nef_poly.number_of_volumes() <<
> std::endl;
> std::cout << "nef(poly) is_valid: " <<
> nef_poly.is_valid(false, 3) << std::endl;
> std::cout << "is_simple: " << nef_poly.is_simple() <<
std::endl;
> And this is the output:
> is_closed(): 1
> is_valid(): 1
> is_pure_triangle(): 1
> # faces: 52
> # vertices: 24
> # border halfedges: 0
> CGAL error: assertion violation!
> Expression : ss_circle.has_on(sv_prev->point())
> File : CGAL/Nef_3/polygon_mesh_to_nef_3.h
> Line : 256
> Explanation:
> Refer to the bug-reporting instructions at
> https://www.cgal.org/bug_report.html
<https://www.cgal.org/bug_report.html>
<https://www.cgal.org/bug_report.html>>
> Unhandled exception:
> @ 0x55c31fb34732 GoogleTerminateHandler()
> @ 0x55c31fc5a768 std::__terminate()
> @ 0x55c31fc59dfb __cxxabiv1::failed_throw()
> @ 0x55c31fc59d75 __cxa_throw
> @ 0x55c31fab767c CGAL::assertion_fail()
> @ 0x55c31faecdcd CGAL::polygon_mesh_to_nef_3<>()
> @ 0x55c31fac2ec2 CGAL::polyhedron_3_to_nef_3<>()
> @ 0x55c31fab6ea6
> CGAL::Nef_polyhedron_3<>::Nef_polyhedron_3<>()
> @ 0x55c31fab5bbb main
> @ 0x7f1dff68abbd __libc_start_main
> @ 0x55c31fab5569 _start
> libc++abi: terminating with uncaught exception of type
> CGAL::Assertion_exception: CGAL ERROR: assertion violation!
> Expr: ss_circle.has_on(sv_prev->point())
> File: CGAL/Nef_3/polygon_mesh_to_nef_3.h
> Line: 256
> *** SIGABRT received by PID 3953462 (TID 3953462) on cpu
10 from
> PID 3953462; ***
> E0504 22:31:27.565500 3953462 process_state.cc:770] RAW:
Raising
> signal 6 with default behavior
> Aborted
> Matthew
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
<https://sympa.inria.fr/sympa/info/cgal-discuss>>
-- You are currently subscribed to cgal-discuss.
- [cgal-discuss] Valid and closed polyhedron cannot be converted into nef polyhedron, Matthew Lai, 05/04/2021
- Re: [cgal-discuss] Valid and closed polyhedron cannot be converted into nef polyhedron, Maxime Gimeno, 05/05/2021
- Re: [cgal-discuss] Valid and closed polyhedron cannot be converted into nef polyhedron, Matthew Lai, 05/05/2021
- Re: [cgal-discuss] Valid and closed polyhedron cannot be converted into nef polyhedron, Sebastien Loriot, 05/05/2021
