cgal-discuss - Re[2]: [cgal-discuss] Speeding up Intersection
  • To:
  • Subject: Re[2]: [cgal-discuss] Speeding up Intersection
  • Date: Wed, 05 May 2021 16:49:07 +0300
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
  • Ironport-hdrordr: A9a23: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
  • Ironport-phdr: A9a23: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
Thank you for you fast reply.
Are you using the same kernel and datatype as me?
Am I getting you right, that the black box function «Intersection» itself cannot be sped up. It’s only possible to reduce number of calls, to reduce computational time?
Среда, 5 мая 2021, 16:43 +03:00 от Sebastien Loriot <>:
Of course it depends on your real scenario but I would use something
like this example:
https://doc.cgal.org/latest/Box_intersection_d/Box_intersection_d_2triangle_self_intersect_8cpp-example.html
with the do_intersect and a fast kernel without exact constructions
to collect pairs of triangles intersecting and then I'll use a kernel
with exact constructions to compute intersections.
Best,
Sebastien.
On 5/5/21 3:37 PM, jana jelenki ( via cgal-discuss Mailing
List) wrote:
> Hi Sebastien,
> below is an MWE, that sums up my code. I have numbers that span from
> 1.0e-7 to 100, therefore the strange looking points.
> Result of this intersection is a Segment_3:
> P1: 66.666666722222    50.0000001    0
> P2: 100.0000001    50.0000001    0
> It takes nearly 0.1ms for each intersection. So 10s for 100,000
> intersections. Can this be sped up by another kernel or data type? I
> tested for example inexact construction but it gave wrong results.
> Best
> #include <CGAL/Exact_predicates_exact_constructions_kernel.h> #include
> <iostream> #include <chrono>
> typedef CGAL::Exact_predicates_exact_constructions_kernelKernel; typedef Kernel::Point_3Point3; typedef Kernel::Triangle_3Triangle3;
> int main() {
> std::vector<Point3> APoints(3); std::vector<Point3> BPoints(3);
> APoints[0] = Point3(0, 0, 0); APoints[1] = Point3(100.0000001, 0, 0); APoints[2] = Point3(100.0000001, 100.0000001, 0);
> BPoints[0] = Point3(0, 50.0000001, -100.0000001); BPoints[1] = Point3(200.0000001, 50.0000001, -100.0000001); BPoints[2] = Point3(200.0000001, 50.0000001, 200.0000001);
> Triangle3 TriangleA(APoints[0], APoints[1], APoints[2]); Triangle3 TriangleB(BPoints[0], BPoints[1], BPoints[2]);
> int end =100000;
> auto start =std::chrono::high_resolution_clock::now();
> for (int i =0; i < end; i++)
> auto result = CGAL::intersection(TriangleA, TriangleB);
> auto finish =std::chrono::high_resolution_clock::now(); std::chrono::duration<double> elapsed = finish - start; std::cerr<< elapsed.count()<< "\t" << elapsed.count() / end *1000 << std::endl; }
> Среда, 5 мая 2021, 15:30 +03:00 от Sebastien Loriot
> Without seeing any code it is hard to tell. Are you using do_intersect
> or intersection?
> Best,
> Sebastien.
> On 5/4/21 9:01 AM, jana jelenki ( via cgal-discuss Mailing
> List) wrote:
> > Hi,
> > I find this topic very interesting. I already use spatial
> partitioning
> > and also OpenMP. For an average Triangle_3 Triangle_3 intersection my
> > program needs on average 0.1ms in release mode. I also use the exact
> > kernel. Is this the limit of the CGLAL implementation, are there any
> > numbers or benchmarks?  Or can you squeeze there even further?
> > Best
> > Вторник, 4 мая 2021, 6:35 +03:00 от Andrew Cunningham
> > < </compose?To=cgal@a%2dcunningham.com>>:
> > Hi Anish,
> > Since your code is a N^2 algorithm , it's not surprising that this is
> > taking a long time. The first thing that comes to mind is to bound
> > each triangle with a CGAL AABB (BoundingBox) and use CGAL AABB
> > algorithms to find the pairs of intersecting bounding boxes(pairs of
> > potential triangle intersections). That would make a huge difference
> > in execution time.
> > And once you have done that, you could loop over the intersecting
> > pairs and use OpenMP or other threading approaches like TBB to
> process
> > the intersecting pairs in parallel. I personally have had great
> > success with OpenMP tasks and CGAL.
> > Andrew
> > On Mon, May 3, 2021 at 1:17 PM Rasal Raj, Anish
> </compose?To=anish.rasal@rwth%2daachen.de>
> > </compose?To=anish.rasal@rwth%2daachen.de>> wrote:
> > > Hello Guys,
> > > I have recently started working with CGAL. I have a doubt.
> > > I am using CGAL intersection operation on a list of triangles.
> > currently, it takes some time to complete the information. What are
> > the possible ways to improve the execution time?
> > > Note: the list of triangles contains around 25k triangles. I have
> > attached a sample code with this e-mail. I am using
> > Exact_predicates_exact_constructions_kernel kernel.
> > > You are currently subscribed to cgal-discuss.
> > > To unsubscribe or access the archives, go to
> > > https://sympa.inria.fr/sympa/info/cgal-discuss
> <https://sympa.inria.fr/sympa/info/cgal-discuss>
> <https://sympa.inria.fr/sympa/info/cgal-discuss>>
> > jana jelenki
> jana jelenki
jana jelenki
