- To:
- Subject: Re: [cgal-discuss] Speeding up Intersection
- Date: Wed, 5 May 2021 15:52:23 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-hdrordr: A9a23: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
- Ironport-phdr: A9a23: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
do_intersect can be safely used with CGAL::Exact_predicates_inexact_constructions_kernel (EPICK),
intersection requires EPECK.
I would indeed reduce the number of expensive calls using bboxes
and do_intersect predicates.
But again this depends on your scenario. If you have all triangles
intersecting all triangles then the filter is useless.
Sebastien.
On 5/5/21 3:49 PM, jana jelenki ( via cgal-discuss Mailing List) wrote:
Thank you for you fast reply.
Are you using the same kernel and datatype as me?
Am I getting you right, that the black box function «Intersection» itself cannot be sped up. It’s only possible to reduce number of calls, to reduce computational time?
Среда, 5 мая 2021, 16:43 +03:00 от Sebastien Loriot
Of course it depends on your real scenario but I would use something
like this example:
https://doc.cgal.org/latest/Box_intersection_d/Box_intersection_d_2triangle_self_intersect_8cpp-example.html
<https://doc.cgal.org/latest/Box_intersection_d/Box_intersection_d_2triangle_self_intersect_8cpp-example.html>
with the do_intersect and a fast kernel without exact constructions
to collect pairs of triangles intersecting and then I'll use a kernel
with exact constructions to compute intersections.
Best,
Sebastien.
On 5/5/21 3:37 PM, jana jelenki ( via cgal-discuss Mailing
List) wrote:
> Hi Sebastien,
> below is an MWE, that sums up my code. I have numbers that span from
> 1.0e-7 to 100, therefore the strange looking points.
> Result of this intersection is a Segment_3:
> P1: 66.666666722222 50.0000001 0
> P2: 100.0000001 50.0000001 0
> It takes nearly 0.1ms for each intersection. So 10s for 100,000
> intersections. Can this be sped up by another kernel or data type? I
> tested for example inexact construction but it gave wrong results.
> Best
> #include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include
> <iostream> #include <chrono>
> typedef CGAL::Exact_predicates_exact_constructions_kernelKernel;
typedef Kernel::Point_3Point3; typedef Kernel::Triangle_3Triangle3;
> int main() {
> std::vector<Point3> APoints(3); std::vector<Point3> BPoints(3);
> APoints[0] = Point3(0, 0, 0); APoints[1] = Point3(100.0000001, 0,
0); APoints[2] = Point3(100.0000001, 100.0000001, 0);
> BPoints[0] = Point3(0, 50.0000001, -100.0000001); BPoints[1] =
Point3(200.0000001, 50.0000001, -100.0000001); BPoints[2] =
Point3(200.0000001, 50.0000001, 200.0000001);
> Triangle3 TriangleA(APoints[0], APoints[1], APoints[2]);
Triangle3 TriangleB(BPoints[0], BPoints[1], BPoints[2]);
> int end =100000;
> auto start =std::chrono::high_resolution_clock::now();
> for (int i =0; i < end; i++)
> auto result = CGAL::intersection(TriangleA, TriangleB);
> auto finish =std::chrono::high_resolution_clock::now();
std::chrono::duration<double> elapsed = finish - start; std::cerr<<
elapsed.count()<< "\t" << elapsed.count() / end *1000 << std::endl; }
> Среда, 5 мая 2021, 15:30 +03:00 от Sebastien Loriot
> < </compose?To=cgal%>>:
> Without seeing any code it is hard to tell. Are you using
do_intersect
> or intersection?
> Best,
> Sebastien.
> On 5/4/21 9:01 AM, jana jelenki ( via cgal-discuss
Mailing
> List) wrote:
> > Hi,
> > I find this topic very interesting. I already use spatial
> partitioning
> > and also OpenMP. For an average Triangle_3 Triangle_3
intersection my
> > program needs on average 0.1ms in release mode. I also use the
exact
> > kernel. Is this the limit of the CGLAL implementation, are
there any
> > numbers or benchmarks? Or can you squeeze there even further?
> > Best
> > Вторник, 4 мая 2021, 6:35 +03:00 от Andrew Cunningham
> > < </compose?To=cgal@a%2dcunningham.com>
</compose?To=cgal@a%2dcunningham.com>>:
> > Hi Anish,
> > Since your code is a N^2 algorithm , it's not surprising that
this is
> > taking a long time. The first thing that comes to mind is to bound
> > each triangle with a CGAL AABB (BoundingBox) and use CGAL AABB
> > algorithms to find the pairs of intersecting bounding
boxes(pairs of
> > potential triangle intersections). That would make a huge
difference
> > in execution time.
> > And once you have done that, you could loop over the intersecting
> > pairs and use OpenMP or other threading approaches like TBB to
> process
> > the intersecting pairs in parallel. I personally have had great
> > success with OpenMP tasks and CGAL.
> > Andrew
> > On Mon, May 3, 2021 at 1:17 PM Rasal Raj, Anish
</compose?To=anish.rasal@rwth%2daachen.de>
> > </compose?To=anish.rasal@rwth%2daachen.de>> wrote:
> > > Hello Guys,
> > > I have recently started working with CGAL. I have a doubt.
> > > I am using CGAL intersection operation on a list of triangles.
> > currently, it takes some time to complete the information. What are
> > the possible ways to improve the execution time?
> > > Note: the list of triangles contains around 25k triangles. I have
> > attached a sample code with this e-mail. I am using
> > Exact_predicates_exact_constructions_kernel kernel.
> > > You are currently subscribed to cgal-discuss.
> > > To unsubscribe or access the archives, go to
> > > https://sympa.inria.fr/sympa/info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
<https://sympa.inria.fr/sympa/info/cgal-discuss>>
<https://sympa.inria.fr/sympa/info/cgal-discuss>>>
> > jana jelenki
> jana jelenki
jana jelenki
- [cgal-discuss] Speeding up Intersection, Rasal Raj, Anish, 05/03/2021
- Re: [cgal-discuss] Speeding up Intersection, Andrew Cunningham, 05/04/2021
- Re[2]: [cgal-discuss] Speeding up Intersection, jana jelenki, 05/04/2021
- Re: [cgal-discuss] Speeding up Intersection, Sebastien Loriot, 05/05/2021
- Re[2]: [cgal-discuss] Speeding up Intersection, jana jelenki, 05/05/2021
