- To:
- Subject: Re: [cgal-discuss] Generated CGAL executable file does not run
- Date: Mon, 17 May 2021 09:47:47 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-hdrordr: A9a23:S2Gd56lAbmIHDQyQLpa+ZVqL1iPpDfJZ3DAbv31ZSRFFG/Fw+PrDoB1273LJYUgqNk3I8OroUMK9qBjnmqKdj7N6AYuf
- Ironport-phdr: A9a23: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
Apparently, this error means a 32 bit executable tries to load a 64bits dll. Check your path, something must be wrong in it.
Le dim. 16 mai 2021 à 11:33, kunzarizvi <> a écrit :
Hello,
I generated 3 different executable files for different functions to
integrate with my project. 2 out of these 3 executables run smoothly on
other computers (without CGAL installed) but one of them does not. I get an
error of /"the application was unable to start correctly 0xc00007b"/. The
executable works correctly because it is running on my own computer.
Has anyone faced this error previously?
- [cgal-discuss] Generated CGAL executable file does not run, kunzarizvi, 05/16/2021
- Re: [cgal-discuss] Generated CGAL executable file does not run, Maxime Gimeno, 05/17/2021
