cgal-discuss - [cgal-discuss] Intersection between plane and triangle through the same three points
  • To:
  • Subject: [cgal-discuss] Intersection between plane and triangle through the same three points
  • Date: Mon, 17 May 2021 19:07:47 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-hdrordr: A9a23:DQIV/KF9O+U8HDVopLqEIceALOsnbusQ8zAXPidKOHhom62j5qWTdJZy73XJYVMqNU3I9urhBEC/ewKiyXcY2+Us1ZnLZniahIKDFvAb0WPaqweQYREXHIZmpNtdmtFFeabN5DtB/KTHCWuDYrUdKYK8gdmVbI7lph8HcegNUcBdBihCe3im+yZNKzWua6BWKHJcjvA3wAZJ9hwsH6KGOkU=
  • Ironport-phdr: A9a23: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
Dear all,
I’m a checking the intersection between Triangle_3 and Plane_3 objects. If
both are constructed from the same triple of points, the result is false for
most triples, but sometimes true. I’m using the exact predicates / inexact
constructions kernel. Is this the expected / desired behavior? I had hope
because of the exact predicates that the result for such intersection tests
is at least consistent (and actually consistently true).
Thanks!
-Marc
