cgal-discuss - [cgal-discuss] Gradient estimation for vertices on convex hull boundary
  • To:
  • Subject: [cgal-discuss] Gradient estimation for vertices on convex hull boundary
  • Date: Tue, 25 May 2021 22:16:24 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-hdrordr: A9a23:n2QeIaDCtkFVOljlHenZ55DYdb4zR+YMi2TDuHocdfU4SKGlfr6V8sjzvCWc4F0ssRob9uxoVpPrfU/h
  • Ironport-phdr: A9a23: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
Hi,
I am trying to understand why Sibson gradient fitting does not work for vertices on the convex hull boundary (see links below).  Are there viable alternatives?  Naively, I would expect it's fine to estimate the gradient using the edges that do exist (i.e. like estimating 1D finite differences using a forward difference instead of a centered difference).  It seems one could solve an Nx2 linear system for the gradient components, with N >= 2, even for vertices on the boundary.
Any insight would be greatly appreciated!
Ryan
https://doc.cgal.org/5.2/Interpolation/index.html#title22
https://github.com/CGAL/cgal/blob/v5.2.1/Interpolation/include/CGAL/sibson_gradient_fitting.h#L214-L215
  • [cgal-discuss] Gradient estimation for vertices on convex hull boundary, Ryan McKinnon, 05/26/2021
