- To:
- Subject: [cgal-discuss] Problem with CGAL 4.8.1 and boost.
- Date: Thu, 27 May 2021 07:33:00 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
- Ironport-hdrordr: A9a23:UraEcqnoGyId4eIacoXSypTNdAbpDfN8imdD5ihNYBxZY6Wkfg6V7ZEmPGzP+UgssRAb6Kq90Mvpex/hHPtOjrX5Uo3SJTUO1FHYT72KqLGSpAEIeBeOjdK1t50QC5SWYeeYZTMR4Keb3OD7KadF/DDtytHPuQ6q9QYTcegcUdAS0+4WMHf4LqQPfng6dOYEPavZ3cZBryetYjAvc8q2QkMdV+zor8HQmPvdEGo7Li9i0wWIhS6l8/rCDhaVmi0GWzd0y7E4/QH+4nnEz5TmiP29wgLRzCvr8ppb3OH5wt94GcSQhqEuW0fRY9mTCrhJavmwrRQyq+Gr5BIBlt3JqxAsVv4Dmk/5TyWHsD/q0Ank3HIQ52T5yVme6EGT0fDEeA==
- Ironport-phdr: A9a23:3iaRlRSL4jjAdVaTbXkiiYur9dpsopyfAWYlg6HPa5pwe6iut67vIFbYra00ygOQDMOBu64P0rOK+4nbGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2aFLduGC94iAPERvjKwV1Ov71GonPhMiryuy+4ZLebxhMiTanf79/Lxq7oQrMusULjoZpN7o8xAbOrnZUYepd2HlmJUiUnxby58ew+IBs/iFNsP8/9MBOTLv3cb0gQbNXEDopPWY15Nb2tRbYVguA+mEcUmQNnRVWBQXO8Qz3UY3wsiv+sep9xTWaMMjrRr06RTiu86FmQwLuhSwaNTA27XvXh9R+gqxbvhyvpAFxzIHIb4+aL/d+YqHQcc8GSWZdQspdSSpMCZ68YYsVCOoBOP5VoYnnp1QUqxu+BhSnCu3uyzRVgXL2xrA10/k8HgDH3A0tBM8CvXXaodnvKKgSVuW1wbDOwD7eYPxYxS3z55LUchA9v/6MR7RwfNLTxEQzFw3Ik1udpILnMj6R1uoBr2qW4eV8We+siWMqpQJ8rzyxy8otiofFm4wYxF7K+yh93Is4Jd+1RFJ4bNOqFpZbqi+UN4xzQsw4QmFovj43yrsctpGgZycKzIooywTDZPyAdoiF5A/oWuWJITpgmX5ofLayiwy8/EWj0OHxVci53ExLoydElNTHq2oD2AbJ6sedT/tw5keh1iiL1wDU8uxEJ085mbDdK5E72bE/jZ4TvlrZEiDqn0X2ibeadkQi+ue29+Tqeqjqq5uYOoNuhAzzMb4il8++DOgiMwUDXnCX+eGm273i+U35Tq9KjvozkqTBq5DVONkbqbO4Ag5VyYsv9heyAjm83NsEmnkHKUpJeAibgIjxJ1HOPPf4AO+jjFSjijhrw+nKMaDgApXWMnfDjazhfa1m5k5HyAszyMhf6IhOBrEAJvLzQE7xu8bCAh83KQzni9rgXd5y34dbVWOUCbKCK4vTt0WJ76QhObqifogQ7RjnIv4mr9L8xSsilUIRb7iBhMVMLnu/G6I1cA2ifXPwj4JZQi8xtQ0kQbmy4LVjeTgPIXC7Vag463cwD4f0VO8rqaj03ufH1yC+TME+joVuUw7XV3zvctfcM8o=
Hi~ I am using CGAL 4.8.1 and using boost at the same time.
And I met the following error.
*Error C2499
'CGAL::internal::boost_::array_binary_tree_node<RandomAccessIterator,ID>::children_type::iterator':
a class cannot be its own base class qmat C:\Program
Files\CGAL-4.8.1\include\CGAL\internal\boost\array_binary_tree.hpp 54
*Error C2143 syntax error: missing ',' before '<' qmat C:\Program
How can we fix this?
Thank you very much!
Platform: Win10. X64.
<http://cgal-discuss.949826.n4.nabble.com/file/t376165/1622118642%281%29.jpg>
be open, be creative, be critical
- [cgal-discuss] Problem with CGAL 4.8.1 and boost., Frank Dz, 05/27/2021
- Re: [cgal-discuss] Problem with CGAL 4.8.1 and boost., Frank Dz, 05/27/2021
