- To:
- Subject: [cgal-discuss] Using TBB / CMake imported targets with Meson
- Date: Wed, 15 Sep 2021 20:38:40 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-hdrordr: A9a23:5V30eKEFL97BK0oqpLqE/ceALOsnbusQ8zAXPjNKOHlom62j5qKTdZsguyMc5Ax8ZJhko6HiBEDiexPhHPxOjrX5VI3KNDUO+lHEEGgI1+DfKlPbcREWutQ96Ztd
- Ironport-phdr: A9a23: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
Hi,
I'm building my top-level application that uses CGAL with the Meson build
system.
I would like to use CGAL's TBB support to get multithreading
The docs say (https://doc.cgal.org/5.2.3/Manual/thirdparty.html#title16):
> In order to use Tbb in CGAL programs, the executables should be linked with
> the CMake imported target CGAL::TBB_support provided in
> CGAL_TBB_support.cmake.
I found an example of that with CMake here:
https://github.com/CGAL/cgal/blob/8c9fc331cd0e523f897f830da480483b6fb70d5d/Polyhedron/demo/Polyhedron/CMakeLists.txt#L87-L96
But how can I enable TBB support with a non-CMake build system like Meson?
Meson invokes CMake to find it as a dependency, and I can pass `cmake_args`
for that, but I'm not sure if that'll help.
I'd appreciate any pointers!
Niklas
- [cgal-discuss] Using TBB / CMake imported targets with Meson, Niklas Hambüchen, 09/15/2021
- Re: [cgal-discuss] Using TBB / CMake imported targets with Meson, Sebastien Loriot (GeometryFactory), 09/16/2021
