- To:
- Subject: Re: [cgal-discuss] optimal_convex_partition_2 produces invalid decomposition
- Date: Thu, 16 Sep 2021 17:11:14 -0700
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-hdrordr: A9a23:Je0GHa4afa/1+rjOjQPXwHPXdLJyesId70hD6qm+c31om6uj5qaTdZUgpHjJYVMqMk3I9ursBEDtex/hHNtOkOos1VnLZnibhILqFvAe0WPaqweQZBEWj9Qtq5uIEZIfNDSANykfsS+g2njALz9I+rDum5xAx92urUuFKzsEV0gK1XYdNu/0KCNLrSB9dOsEPavZyMpbhiaqPU8aZt68ARA+LpL+juyOupL6QAIMQyUq4gmWjT+u9dfBYmOl9yZbfTNT4KsotVPImQzh5qmlrrWSxxLG23XIhq4m6OfJ+59sBNGslsNQEDnqhwqyDb4RI4G/gA==
- Ironport-phdr: A9a23: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
I was able to merge the header files manually and it did fix the issue I was running into. Is it possible to comment on asymptotic complexity of the brute force fix? Does it make the CGAL::approx_convex_partition_2 O(n^2) or not?
On Wed, Sep 15, 2021 at 1:23 PM Manoj Bist <> wrote:
The issue has been closed as duplicate. There is a temporary fix in a branch that is 5 years old. Is it possible to merge it to the main branch?I have tried manually merging it to the main branch but have been unsuccessful.On Tue, Oct 13, 2020 at 4:38 AM "Sebastien Loriot (GeometryFactory)" <> wrote:I created the following issue to track the resolution of your bug:
https://github.com/CGAL/cgal/issues/5074
Best regards,
Sebastien.
On 10/1/20 8:37 PM, Manoj Bist ( via cgal-discuss
Mailing List) wrote:
> have attached a testcase that illustrates the issue. Its a cpp file
> that you can compile to reproduce the issue.
> Please note that the input is valid. Approximate decomposition works
> correctly. Optimal decomposition fails in CGAL_partition_postcondition.
> /Please do not be confused by the name of CGAL ERROR: precondition
> violation. It is actually failing in the post condition, where in it
> verifies that the decomposition is correct./
> 1. I've verified that the input polygon is a simple counter clockwise
> polygon. I have put the following two asserts to ensure this invariant.
> assert(CGAL::is_simple_2(polygon.vertices_begin(),
> polygon.vertices_end(), Traits()));
> assert(CGAL::orientation_2(polygon.vertices_begin(),
> polygon.vertices_end(), Traits()) == CGAL::COUNTERCLOCKWISE);
> assert(!hasDuplicatePoints(polygon));
> 2. To test the logical correctness for the input polygon, I have also
> done the following.
> I've identified a point that is outside the input polygon. A point that
> is outside the input polygon should be outside all the polygons in
> convex decomposition.
> Approximate decomposition passes this.
> 3. First I run the approximate
> decomposition CGAL::approx_convex_partition_2. It works as expected.
> 4. This post condition fails for optimal decomposition.
> CGAL_partition_postcondition(
> convex_partition_is_valid_2(polygon.begin(), polygon.end(),
> res.output_so_far_begin(),
> res.output_so_far_end(), traits)
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- Re: [cgal-discuss] optimal_convex_partition_2 produces invalid decomposition, Manoj Bist, 09/15/2021
- Re: [cgal-discuss] optimal_convex_partition_2 produces invalid decomposition, Manoj Bist, 09/17/2021
