[cgal-discuss] Using Bezier-Bezier intersections as vertices in an CGAL::Arrangment
- To:
- Subject: [cgal-discuss] Using Bezier-Bezier intersections as vertices in an CGAL::Arrangment
- Date: Sun, 28 Nov 2021 22:16:23 -0800
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-data: A9a23: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
- Ironport-hdrordr: A9a23:awydN6k+P+X9x3QnPYzi/vm13ljpDfJL3DAbv31ZSRFFG/Fw8PrOoB1773HJYVkqKRIdcLy7Scu9qBDnmqKdn7NwAV7KZmCP0wGVxepZgbcKrQeMJxHD
- Ironport-phdr: A9a23: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
Hi,
I'm using a CGAL::Arrangment and am trying to connect edges to the intersection of Beziers.
In the application, I'm getting a precondition violation, complaining that the intersection is not rational.
I tried to construct a synthetic example to reproduce the problem, which I've posted on stackoverflow, and it gets a segfault.
But, assuming the segfault is just a bug, my question is really about the intended API for Beziers. Is it possible to connect an edge to a vertex which is the intersection of two Bezier curves? If so, what's the mechanism I'm supposed to use to avoid the precondition violation?
Thanks in advance for your help.
Kevin
- [cgal-discuss] Using Bezier-Bezier intersections as vertices in an CGAL::Arrangment, Kevin Morgan, 11/29/2021
- Re: [cgal-discuss] Using Bezier-Bezier intersections as vertices in an CGAL::Arrangment, Ahmed Essam, 11/29/2021
- Re: [cgal-discuss] Using Bezier-Bezier intersections as vertices in an CGAL::Arrangment, Efi Fogel, 11/29/2021
- Re: [cgal-discuss] Using Bezier-Bezier intersections as vertices in an CGAL::Arrangment, Kevin Morgan, 11/30/2021
- Re: [cgal-discuss] Using Bezier-Bezier intersections as vertices in an CGAL::Arrangment, Efi Fogel, 11/30/2021
