cgal-discuss - Re: [cgal-discuss] texture mapping
  • To:
  • Subject: Re: [cgal-discuss] texture mapping
  • Date: Thu, 25 Nov 2021 09:36:34 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-data: A9a23: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
  • Ironport-hdrordr: A9a23:8iCpJ6mRVqz15krcagSBQAZs2m7pDfKC3DAbv31ZSRFFG/Fw9vre/sjzsCWetN9/Yh0dcK+7Sdm9qB/nm6Kdy7NhTItKJTOWxldAdbsSkrcKoAeQeBEWlNQx6U46SdkDNDSYNzETsS+d2miF+r4bquVvm5rGuQ6x9RdQZDAvQall9g94BAHeLk16LTM2eKYRJd63+tBboT6tYjA4bsnTPAh+Y8Hz4/fWjo/hZRIcQyIm5WC1/EiVwY+/PhSc3ggTSCMK+7cumFK16zDR1+GOmMvT8G6k64aq1eUxpDIX8KolOOW8zvIIIS/nkQaiaJ8kZ72O1QpFxN2H2RIWi9HHoRcmMYBf6365RBDRnSfQ
  • Ironport-phdr: A9a23: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
If you are talking about visualization of the result of the texture
mapping, this is out of the scope of the CGAL library and depends on
what technology you are going to use to display your meshes.
Best,
Sebastien.
On 11/24/21 11:29 AM, Vi Gho ( via cgal-discuss Mailing List) wrote:
Hello,
I am using this tutorial (https://doc.cgal.org/latest/Surface_mesh_parameterization/index.html <https://doc.cgal.org/latest/Surface_mesh_parameterization/index.html>) to texture a surface I have. I could generate the UV map and corresponding vertices. But the tutorial does not give any code about how to achieve the final textured output as it is shown in the tutorial figure (3rd one). I am new to CGAL and Computer Graphics. Can you please guide me with some code which is available.
Thank you in advance,
Regards
