- To:
- Subject: Re: [cgal-discuss] Union of balls and self-intersecting mesh
- Date: Thu, 2 Dec 2021 17:52:20 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-data: A9a23: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
- Ironport-hdrordr: A9a23:d7BayaBFGDDGKp/lHemP55DYdb4zR+YMi2TDpHoBNCC9Ffbo6/xG/c5rryMc7Qx6ZJhOo6HnBEDtewK5yXcx2/hrAV7AZnifhILLFvAE0WKK+VSJcE3DH6xmpMJdmsBFaeEYZmIK7voSjjPIcerIjOP3iZxARt2z856ud2xXgm1bgDuRwzz0LnFL
- Ironport-phdr: A9a23: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
The best workaround I could advise is to perturb the input point.
Postprocessing the mesh requires removing degenerate faces first
(PMP::remove_degenerate_faces()) before calling the other function.
Best,
Sebastien.
On 11/25/21 6:58 PM, Bruno Manganelli ( via cgal-discuss Mailing List) wrote:
Hi Sebastien,
Glad you could reproduce the issue. Do you have any suggestions for workarounds for the time being?
I tried using PMP::experimental::autorefine_and_remove_self_intersections but I get an assertion violation.
Thanks,
Bruno
On Wed, Nov 24, 2021 at 8:26 AM Sebastien Loriot < <>> wrote:
Thanks I could reproduce the issue.
So it turns out that this function does not use the mesher but a
dedicated code.
As it is based on the dual of the Delaunay triangulation and that your
points are on a grid, I suspect that the dedicated code does not handle
correctly degenerate cases. To check that, I added some noise to the
input points and that removed the self-intersecting faces (mostly
because of degenerate faces).
I opened the following issue to track the patching:
https://github.com/CGAL/cgal/issues/6147
<https://github.com/CGAL/cgal/issues/6147>
Best,
Sebastien.
On 11/23/21 8:55 PM, Bruno Manganelli (
<> via
> Here is a somewhat minimal example.
> Hope it's good enough!
> Bruno
> On Tue, Nov 23, 2021 at 5:55 PM Sebastien Loriot
> < <>>> wrote:
> It should not happen. IIRC, it is the output from the
Surface_mesher
> so it should be clean.
> Would you have a minimal example showing the problem?
> Best,
> Sebastien.
> On 11/23/21 6:44 PM, Bruno Manganelli
<>> via
> > Hi,
> > I am using the Union_of_balls_3 class and
the mesh_union_of_balls_3
> > function.
> > However, in certain scenarios, the resulting mesh contains
> > self-intersections (PMP::does_self_intersect(mesh) returns
true).
> > Is this expected?
> > I can provide an example if required.
> > Thanks!
> > Bruno
> > You are currently subscribed to cgal-discuss.
> > To unsubscribe or access the archives, go to
> > https://sympa.inria.fr/sympa/info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
<https://sympa.inria.fr/sympa/info/cgal-discuss>>
-- You are currently subscribed to cgal-discuss.
- Re: [cgal-discuss] Union of balls and self-intersecting mesh, Sebastien Loriot, 12/02/2021
