- To:
- Subject: Re: [cgal-discuss] ARAP_parameterizer_3/Eigen crash when launched in parallel
- Date: Tue, 14 Dec 2021 15:29:59 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-data: A9a23:OwSsRKy8hVSMnQyB04Z6t+eMxCrEfRIJ4+MujC/XYbTApGx33j1UnTAeXW+FPquKMGvxLtpzbt7ipBgA6p7dxoJjOVdlrnsFo1Bi+ZOUX4zBRqvTF3rPdZObFBoPA/3z27AsFehsJpPnjkrrYuiJQUVUj/nSH+OmUbKcYEideCc9IMsfoUI78wIGqtUw6TSJK1vlVeLa+6UzCnf9s9JHGj58B5a4lf9alK+aVAX0EbAJTasjUFf2zxH5BX+ETE27ByOQroJ8RoZWSwtfpYxV8F81/z91Yj+kuqj+N0gaG/jYIAbIgX1TM0SgqkIb/Wprj/x9badaMBYK49mKt4gZJNFlroC3VB0vM7DcsO4AXV9TFCQW0ahuoeeWeSjn7Z37I0ruKCGwnao0XSnaJ7Yw8el+BSRC9OcTNSsWRguSgvq/hrO9UOhlwMo5RPQHlqsL4iQ4i2nNVKN+B8jXGfCSo4JMh2JowJ1aQqPgZu8NMGI6MEuEOkUQakN/5IkWguLtg2mmNTdFphSeoq9f3oQa9yQpuJCFDTYfUo3bLSmUoqqZmo4C13r8RxQKbZqV1DTD+XWp7gMKtUsXR6pKfIBUNNYz6LFQ+oDXIBcLWx2wpvzRZouWRYdEM0JNksYxhfFayaFoJ+URmzWyvXDCtRkZMzaVO4XW9ynVopfpD82l6qTog9KPhBHKdCP7eNDy6mK0og==
- Ironport-hdrordr: A9a23:Xmkt/aiflpzBdpg9Lj7O9pLfqXBQXs8ji2hC6mlwRA09TyX4ra+TdZEgviMc5wx6ZJheo7690cW7MBDhHOdOgLX5Xo3PYOCFggaVxehZhOPfKlvbexEWndQtsJuIHZIOauHNMQ==
- Ironport-phdr: A9a23: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
Sorry for the late answer, I was indeed unintentionally sharing the parametrized between threads. Thanks a lot !
On a side note, when using the ARAP parametrization, I sometimes get a "Border is not simple!" warning that cannot be silenced I think (std::cerr). https://github.com/CGAL/cgal/blob/33fd57c0f117296c3e0708b6652cd5bf9093ac6d/Surface_mesh_parameterization/include/CGAL/Surface_mesh_parameterization/MVC_post_processor_3.h#L695
This is unnecessary as we
have the return code ERROR_NON_CONVEX_BORDER indicating the problem.
Thanks again for you
answer,
On 12/3/21 3:37 PM, Sebastien Loriot
( via cgal-discuss Mailing List) wrote:
Do you
have a minimal example showing the problem?
In particular, I wonder if you have share the parameterization class between threads.
Best regards,
Sebastien.
On 12/2/21 3:57 PM, Sebastien Tourneux wrote:
Hello,
I use ARAP_parameterizer_3 to parametrize a model made of several disconnected parts. I want to parametrize independently each part. When each part is processed sequentially, everything is fine, but when processed in parallel, I got a free/malloc crash (see backtrace below) from an `Eigen::SparseLU::factorize` call from `ARAP_parameterizer_3::parameterize`. I use TBB to handle the parallelization.
I am not sure if it is an actual issue or if ARAP_parameterizer_3 (or Eigen factorize) is not supposed to be launched in parallel. Looking very briefly at the code, I found `output_uvmap` that seems to write to an hardcoded file (I believe), could it be the cause ?
I am using CGAL_VERSION 5.3 (CGAL_GIT_HASH caacd806dc55c61cc68adaad99f2240f00493b29) on Debian 10.
Thanks in advance for you help,
Sébastien Tourneux
Backtrace :
malloc(): mismatching next->prev_size (unsorted)
free(): invalid size
munmap_chunk(): invalid pointer
munmap_chunk(): invalid pointermunmap_chunk(): invalid pointer
double free or corruption (out)
corrupted size vs. prev_size while consolidating
malloc(): invalid next size (unsorted)
free(): corrupted unsorted chunks
double free or corruption (!prev)
Thread 128 "exec" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fff217f7700 (LWP 3382513)]
0x00007fffddd46125 in Eigen::SparseLU<Eigen::SparseMatrix<double, 0, int>, Eigen::COLAMDOrdering<int> >::factorize(Eigen::SparseMatrix<double, 0, int> const&) () from /path/to/lib/libCgalModel.so
#0 0x00007fffddd46125 in Eigen::SparseLU<Eigen::SparseMatrix<double, 0, int>, Eigen::COLAMDOrdering<int> >::factorize(Eigen::SparseMatrix<double, 0, int> const&) () at /path/to/lib/libCgalModel.so
#1 0x00007fffde22cb2c in CGAL::Eigen_solver_traits<Eigen::SparseLU<Eigen::SparseMatrix<double, 0, int>, Eigen::COLAMDOrdering<int> > >::linear_solver(CGAL::Eigen_sparse_matrix<double> const&, CGAL::Eigen_vector<double, -1> const&, CGAL::Eigen_vector<double, -1>&, double&) ()
#2 0x00007fffde216a95 in CGAL::Surface_mesh_parameterization::Error_code CGAL::Surface_mesh_parameterization::ARAP_parameterizer_3<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >, CGAL::Surface_mesh_parameterization::Two_vertices_parameterizer_3<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > > >, CGAL::Default>::update_solution<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_2<CGAL::Simple_cartesian<double> > >, CGAL::internal::Dynamic<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >, CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >::Property_map<CGAL::SM_Vertex_index, int> >, CGAL::internal::Dynamic<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >, CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >::Property_map<CGAL::SM_Vertex_index, bool> > >(CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > > const&, boost::unordered::unordered_set<CGAL::SM_Vertex_index, boost::hash<CGAL::SM_Vertex_index>, std::equal_to<CGAL::SM_Vertex_index>, std::allocator<CGAL::SM_Vertex_index> > const&, boost::associative_property_map<CGAL::Unique_hash_map<CGAL::SM_Halfedge_index, double, boost::hash<CGAL::SM_Halfedge_index>, std::allocator<double> > >, std::vector<CGAL::Point_2<CGAL::Simple_cartesian<double> >, std::allocator<CGAL::Point_2<CGAL::Simple_cartesian<double> > > > const&, boost::associative_property_map<CGAL::Unique_hash_map<CGAL::SM_Halfedge_index, std::pair<int, int>, boost::hash<CGAL::SM_Halfedge_index>, std::allocator<std::pair<int, int> > > >, boost::associative_property_map<CGAL::Unique_hash_map<CGAL::SM_Face_index, std::pair<double, double>, boost::hash<CGAL::SM_Face_index>, std::allocator<std::pair<double, double> > > >, CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_2<CGAL::Simple_cartesian<double> > >, CGAL::internal::Dynamic<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >, CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >::Property_map<CGAL::SM_Vertex_index, int> >, CGAL::internal::Dynamic<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >, CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >::Property_map<CGAL::SM_Vertex_index, bool> >, CGAL::Eigen_sparse_matrix<double> const&) ()
#3 0x00007fffde2139b5 in CGAL::Surface_mesh_parameterization::Error_code CGAL::Surface_mesh_parameterization::ARAP_parameterizer_3<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >, CGAL::Surface_mesh_parameterization::Two_vertices_parameterizer_3<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > > >, CGAL::Default>::parameterize<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_2<CGAL::Simple_cartesian<double> > >, CGAL::internal::Dynamic<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >, CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >::Property_map<CGAL::SM_Vertex_index, int> >, CGAL::internal::Dynamic<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >, CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >::Property_map<CGAL::SM_Vertex_index, bool> > >(CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >&, CGAL::SM_Halfedge_index, CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_2<CGAL::Simple_cartesian<double> > >, CGAL::internal::Dynamic<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >, CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >::Property_map<CGAL::SM_Vertex_index, int> >, CGAL::internal::Dynamic<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >, CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >::Property_map<CGAL::SM_Vertex_index, bool> >) () at /path/to/lib/libCgalModel.so
#4 0x00007fffde210c7d in CGAL::Surface_mesh_parameterization::Error_code CGAL::Surface_mesh_parameterization::parameterize<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >, CGAL::Surface_mesh_parameterization::ARAP_parameterizer_3<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >, CGAL::Surface_mesh_parameterization::Two_vertices_parameterizer_3<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > > >, CGAL::Default>, CGAL::SM_Halfedge_index, CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_2<CGAL::Simple_cartesian<double> > > >(CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >&, CGAL::Surface_mesh_parameterization::ARAP_parameterizer_3<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >, CGAL::Surface_mesh_parameterization::Two_vertices_parameterizer_3<CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > > >, CGAL::Default>, CGAL::SM_Halfedge_index, CGAL::Surface_mesh<CGAL::Point_3<CGAL::Simple_cartesian<double> > >::Property_map<CGAL::SM_Vertex_index, CGAL::Point_2<CGAL::Simple_cartesian<double> > >) () at /path/to/lib/libCgalModel.so
-- Sebastien Tourneux Buf Compagnie - R&D
- [cgal-discuss] ARAP_parameterizer_3/Eigen crash when launched in parallel, Sebastien Tourneux, 12/02/2021
- Re: [cgal-discuss] ARAP_parameterizer_3/Eigen crash when launched in parallel, Sebastien Tourneux, 12/02/2021
- Re: [cgal-discuss] ARAP_parameterizer_3/Eigen crash when launched in parallel, Sebastien Loriot, 12/03/2021
- Re: [cgal-discuss] ARAP_parameterizer_3/Eigen crash when launched in parallel, Sebastien Tourneux, 12/14/2021
