cgal-discuss - Re: [cgal-discuss] Repair a self-intersecting triangle mesh
  • To: "Sebastien Loriot ( via cgal-discuss Mailing List)" <>
  • Subject: Re: [cgal-discuss] Repair a self-intersecting triangle mesh
  • Date: Wed, 19 Jul 2023 21:11:00 +1000
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-data: A9a23:rBQkIK7y2FX9/M/m3tOFBQxRtJXFchMFZxGqfqrLsTDasY5as4F+v jEXXG6OaP7bNGGget90a4rj9hgBuJPVytdjHVBkrnhnEysa+MHIO4+Ufxz6V8+wwm0vb67GA +E2MISowBUcFyeEzvuVGuG96yM6j8lkf5KkYMbcICd9WAR4fykojBNnioYRj5Vh6TSDK1rlV eja/YuHYTdJ5xYuajhPs/3a+Us21BjPkGhwUmIWNKgjUGD2yiF94KI3fcmZM3b+S49IKe+2L 86rIGaRpz6xE78FU7tJo56jGqE4aue60Tum0xK6b5Ofbi1q/UTe5Eqa2M00Mi+7gx3R9zx44 IkW78ToEW/FNIWU8AgWe0Ew/y1WYfYcoOefSZSymZT78qHIT5fj68lES0EIINEExvh2HW4U9 /MqMmoGTx/W0opawJrjIgVtrvd6dI+yetpZ6y9Vpd3bJa98HdaaH/SMvIQImm5g36iiHt6HD yYdQTVuaBnbezVOO1EaFNQ4kfvuj2SXnzhw9A/J//pqszCJpOB3+LT9M9zaVoDWecxqv02Dl nLL+WP7EDhPYbRzzhLAqBpAnNTnlizyXMceFaaz6+VxqFyV3G0aThMMPWZXutHg0BL4Ao4Ob RVPqmx3/fFaGFGXc+QRliaQ+Bas1iPwkfIJewHmwGlhEpbp3js=
  • Ironport-hdrordr: A9a23:uyz7GKrQDSKc3IRVrAv6EUgaV5oteYIsimQD101hICG9E/b2qy nKpp9w6faaslgssR0b+OxoWpPwIk80hKQU3WB5B97LMWXbUQCTXeNfBOXZslrdMhy72ulB1b pxN4hSYeeAa2SSVPyKhTVQxexQpOW6zA==
  • Ironport-phdr: A9a23:wOtN4xZwbKMgfka6tEHN7nj/LTFE2YqcDmcuAnoPtbtCf+yZ8oj4O wSHvLMx1gGPAdWQsqMMotGVmpioYXYH75eFvSJKW713fDhBt/8rmRc9CtWOE0zxIa2iRSU7G MNfSA0tpCnjYgBaF8nkelLdvGC54yIMFRXjLwp1Ifn+FpLPg8it2O2+5Zzebx9HiTe+br9+M RG7phjNu8cLhodvNrw/wQbTrHtSfORWy2JoJVaNkBv5+8y94p1t/TlOtvw478JPXrn0cKo+T bxDETQpKHs169HxtRnCVgSA+H0RWXgLnxVSAgjF6Bb6Xortsib/q+Fw1jWWMdHwQLspQjmp8 btlRwH0hycGLz458X/YispsjKJAvRmtowVzz5PIbI2JMfZzeL7Wc9EHSmpbRsteSy9PDI2zY IQBEuQPI+hYoYn/qFYVqBuyGROhCfnzxjJGhHL727Ax3eQ7EQHB2QwtB9MAsHXQrNrrL6cZT Pq7zLTUwjXAcfxWxSv945XPfxAuoPGMWax/cdHJyUQ0FgPFj1OQppL5Pz+P0OQCrXSb4/B6W uKykmMqrRx6rTezyMk2kIbJmp4VxU7e9SV/2Is7K8C0RVJnbNK6H5VdqS+UOop4T80tQWxmt jg2x70JtJKmeCUG1pQpyh/dZvGGcoWF7RDuWPuVLDtmi3xoeLyyihCv+kauze38U9O70FdMr iddjtbMuWoC1xjJ5siAUPt98UGs0iuM2QDL8uxIP1w4mKTBJ5MhxrM8jIcfvV7eEiL2mEj6l LKaelsr9+Sy9ujqbbHrqoWBO4J6iQzyKLkil8+iDek+LwMARXKU+f6m273m5UD5QKtFjvkxk qTBsZDVOdwbqre+Aw9OyYkv8he/Dy2h0NQenXgLNVVFeA+bj4T3IV3BPv/5DeuhjFS2ljdk3 fTGMqfgApXMKHjMjqvhcax760FC1Ao/18pQ549MBrEAJvL8RFPxucTGAhMlPQG42ebqBdFn2 o8DQ26DH6+UPaPKvV+N/O0vIu2MZIEPuDb6Lvgo//HujX49mVADZqmpxYAaaHG5HvRgPUqZf WDggtEfHmcWpAYxVvHqhEWEUTFIf3myRb4z5iknCIK6CofOXp2hjKSb3CinBp1WenxGCleUH Hj0eIWLQfMMZDuPLc9giTwLSaWhS5Q61Ry1rw/7y79nLvLO9SECtJLj0sJ15+zJmh0o+zx0F ZfV72bYBVp5lGoTWz472uhbplZ8zUvLkbN8hOZZEsAV4vdhXQIzNJqaxOt/Q87zU0rKcd6ND VqnWd67Gip5a9swx94IbA5ZGs6+z1qLiyGlCrtQm72QD4Ev6Yrd2WLwLoBz0SCV+rMmigwJQ 89CLiWem6V8+hTPT9rGkkGUjL6CdKUa0TKL8mqfi2OT6hILGDVsWLnICChMLnDdqs70swabF +fG4dUPNwJAzZTHMa5Wcpjzil4AQv7/OdPYamb3mmGqBB/OyKnfJJHydTA72yPQQFMBjxhV5 WyPYAc/Aiq6u0rfDTpjCRTpbl+q+PQt4GijQBoMxhqRJ1Zky6Lz/xcUgfKGTPZG0bMAtTw5g zR1GluhmdTbF5yJulkpZ71SNPU65loPzmfFr0p9M5inerhlnUIbeh9rslnG1h5vT4Jbm40rt nQs3U91NL7Cll5Raz6C25n0fLzWLGTuuhaid+jfxzkyyf6w/aECoLQ9olTn5kSyE1Y6tm9g2 J9T2med4ZPDCEwTV4jwWwA57UoyobaSeSQ7647OsB8keaCprj/P3c4oD+o5216hedlYKqaNC A71FYUTGcGvLOUgn1XhYAgDOahe86s9PsXucPXjuubjM+dkkSm+pWVG5o1hlESB62x1V6+A3 poIxe2ZwhrSTy313x+qtsH6n5wBZClHRDLkj3W1QtcXP/AvLuNpQS+0Lsa6x8tzncvoUn9cr hu4Ak8endWuclyUZkD82gtZ0QIWp2amkG221W8R8Xlho6yB0SjJ2+mnegAAPzsBS2hmgEz0C Ym1id0GGk6lc04giVH2gCSyj7gev6l5I2TJFA1Hfiz7NHlKU6q2u6bEZcNTrpo1+3YfQKG3Z laUTaT4qh0R3nb4HmdQ8zs8cimjppTzmxESZHu1FH9otzKZfMhxwU2a/9nAXbtL2TFAQiBki D7RD1z6Pt+z/NzSmY2R+uy5UmugUNVUf0yJhcuPtS+2/nVCABy5kuz1nND7VwEnmSP2zNhlU yzUoQ20ONGwkfnrd7shJxQ1TFbno9J3AIR/jpc9iPRykTABi5OZ8GBG2Wb/PNNH2L7vOX8ER DoF2dnQs0Du3ExuKG7MxpqsDC3GhJYwIYD8Oz5LiUdfp4hQBayZ7aJJh35wq1u890fKZORl2 y0awr0o4WIbhOcAvEwsyD+cC/YcBxo9X2SkmhKW4tS5tKgSanyodO3620t6kMu5JLCDpAxAH nD0ZtErAGUji6c3eEKJy3D15oz+LZPfbNYerQW8khbGgvQTLp8t0PMXz3kCWyq1rTguzOg1i gZr1Jexsd2cKmljy6m+BwZRKjz/Y85AsiGol6tVmdyampy+Bpg0UCteR4PmFLj7dVBa/eSiL QuFFycw72uWCaaKVxHK819o9jrOC8z5bSnMYiRIi4wkHF7HeARemFxGBm1h2MdgTUbwn5SnK AAjulVzrhb5skcekLozcUOmDSGD4l/vMGt8SYDDfkAOtUcaoR6KYYrEtrI7HjkErMf590rTc SrLNkIRUARrEgSFHwyxZOH0o4Cbra7BX7L4daeRKbSW9b4ED63OnMnxlNI/p3DWapTqXDEqD uVniBAbBzYgQJqfwmxXDXZMyWWWN4aNrRO4sEWbt+iZ9/LmEELq7IqLUf5JNMl3vgqxiuGFP vKRgyBwLXBZ0IkNzDnG0upX2llakCxoezS3dNZI/SfQUKLdnLNWBB8HemtyMsVP9ac1wghKP 4bSlNr00rdyivN9BU1CUBTtncSgZMpCJG/YVhuPHEGQKLGPPiHG2en2arv5TqZayeROsBuh/ DGGDxWlMySfmiPvXhTpMOBKgT3dOhFC/oigM3MPQSDiQN/gdhynIYp3gDkxkvU/gnLHM3JZM CApKRsW6ODBq3oe26giSAkjpjJ/IOKJmjiU9bzdI5cS675wBzhs0vhd6zI8wqdU6ydNQLp0n jHTp5hguQLD8KHHxzx5XR5JsjsOipiMuBAoNqTd+4JYcXfF+h8Rq2OdF1IDupE2b7+n87AV0 dXJmK/pfX1a9MnI+MIHG8XOAMOMKD8mKhCsGSTTChpASiO3byfSl1BQiveb8juUr543tt7ql YZIQ6IRBzlXXrsKT09iGtIFOpJ+WDgpxKWagMA/7n27tBDNRc9es/gvt9qTCu2qLy2TyLheY B0ZhLTlMd5VO53n1lZkY108nYXMFlaWW91R5CR8PFdcSKpl8Xl4Q3F13U/5LAqwsiZ7/Rucn x8whxc4Z+kxsj7xsQ9fGw==
  • Ironport-sdr: 64b7c4cd_Dq25RmYPXKNzgv8vUCokjeCi1TgxPKuShpZhZMLH8X5zjMz S5a2z5OKS/qqVRedVzkPIHScV1BKMBxXf6uyuSA==
Attached here as an OFF file.
G.
On 19/07/2023 5:22 pm, Sebastien Loriot ( via cgal-discuss Mailing List) wrote:
Could you share the mesh?
Best,
Sebastien.
On 7/19/23 09:15, Giles Puckett wrote:
Thanks Sebastien,
Unfortunately remove_self_intersections returns false (and the mesh is unchanged, still returning the same self intersections as before). This is with CGAL 5.5.1, if anything has changed since.
G.
On 19/07/2023 3:54 pm, Sebastien Loriot ( via cgal-discuss Mailing List) wrote:
Hello,
you can try CGAL::Polygon_mesh_processing::experimental::remove_self_intersections()
provided by CGAL/Polygon_mesh_processing/repair_self_intersections.h.
If you only have local self-intersection, it usually works very well.
For listing all intersecting triangles use `self_intersection()`
https://doc.cgal.org/latest/Polygon_mesh_processing/group__PMP__intersection__grp.html#ga6c5bed399d14ddbba820ce50d3145712
HTH,
Sebastien.
On 7/19/23 07:04, Giles Puckett wrote:
Hello all,
I have a triangle mesh that contains self-intersections (PMP::does_self_intersect returns true) but it is otherwise manifold. Is there an easy way to repair these meshes?
If not, would it work to enumerate all the self-intersecting triangles, delete them from the mesh, and fill the holes left behind? Is there a good way to do this, or would some other method work better?
I suspect that the affected area is very small, so gross physical distortion is unlikely to result.
OFF
923 1877 0
-3.546999931335449 -48.810001373291016 0.000000000000000
-3.546999931335449 -48.810001373291016 17.000000000000000
-3.497999906539917 -48.500000000000000 17.000000000000000
-3.688999891281128 -49.089000701904297 0.000000000000000
-3.688999891281128 -49.089000701904297 17.000000000000000
-3.911000013351440 -49.311000823974609 0.000000000000000
-3.911000013351440 -49.311000823974609 17.000000000000000
-4.190000057220459 -47.547000885009766 17.000000000000000
-4.500000000000000 -47.498001098632812 17.000000000000000
-4.190000057220459 -47.547000885009766 0.000000000000000
-4.500000000000000 -47.498001098632812 0.000000000000000
-3.911000013351440 -47.688999176025391 17.000000000000000
-5.502999782562256 -48.500000000000000 17.000000000000000
-5.453000068664551 -48.810001373291016 17.000000000000000
-5.502999782562256 -48.500000000000000 0.000000000000000
-5.453000068664551 -48.810001373291016 0.000000000000000
-5.453000068664551 -48.189998626708984 0.000000000000000
-5.453000068664551 -48.189998626708984 17.000000000000000
-5.310999870300293 -47.910999298095703 0.000000000000000
-5.089000225067139 -47.688999176025391 17.000000000000000
-5.310999870300293 -47.910999298095703 17.000000000000000
-5.089000225067139 -47.688999176025391 0.000000000000000
-4.809999942779541 -47.547000885009766 17.000000000000000
-4.809999942779541 -47.547000885009766 0.000000000000000
-3.546999931335449 -48.189998626708984 17.000000000000000
-3.546999931335449 -48.189998626708984 0.000000000000000
-3.911000013351440 -47.688999176025391 0.000000000000000
-3.688999891281128 -47.910999298095703 17.000000000000000
-3.688999891281128 -47.910999298095703 0.000000000000000
-3.497999906539917 -48.500000000000000 0.000000000000000
-5.310999870300293 -49.089000701904297 0.000000000000000
-5.310999870300293 -49.089000701904297 17.000000000000000
-5.089000225067139 -49.311000823974609 0.000000000000000
-4.500000000000000 -45.000000000000000 17.000000000000000
-4.500000000000000 -45.000000000000000 1.498000025749207
-5.378838062286377 -45.138893127441406 1.498000025749207
-5.378838062286377 -45.138893127441406 17.000000000000000
-5.400000095367432 -45.118999481201172 17.000000000000000
-5.400000095367432 -45.118999481201172 1.498000025749207
-5.449999809265137 -45.070999145507812 17.000000000000000
-5.500000000000000 -45.020999908447266 1.498000025749207
-5.500000000000000 -45.020999908447266 17.000000000000000
-5.449999809265137 -45.070999145507812 1.498000025749207
-2.443000078201294 -45.667999267578125 17.000000000000000
-2.443000078201294 -45.667999267578125 1.498000025749207
-3.417999982833862 -45.171001434326172 1.498000025749207
-3.417999982833862 -45.171001434326172 17.000000000000000
50.362998962402344 -49.650001525878906 17.000000000000000
50.416999816894531 -49.599998474121094 17.000000000000000
50.362998962402344 -49.650001525878906 1.498000025749207
50.306999206542969 -49.700000762939453 17.000000000000000
-4.190000057220459 -49.452999114990234 0.000000000000000
-4.190000057220459 -49.452999114990234 17.000000000000000
-4.500000000000000 -49.502998352050781 17.000000000000000
53.998001098632812 -52.000000000000000 17.000000000000000
49.180000305175781 -50.450000762939453 17.000000000000000
49.073001861572266 -50.500000000000000 17.000000000000000
49.066219329833984 -50.502998352050781 17.000000000000000
-5.089000225067139 -49.311000823974609 17.000000000000000
50.129001617431641 -49.849998474121094 17.000000000000000
50.066001892089844 -49.900001525878906 17.000000000000000
53.998001098632812 -51.999683380126953 17.000000000000000
50.000000000000000 -49.950000762939453 17.000000000000000
49.931999206542969 -50.000000000000000 17.000000000000000
49.861999511718750 -50.049999237060547 17.000000000000000
49.789001464843750 -50.099998474121094 17.000000000000000
49.713001251220703 -50.150001525878906 17.000000000000000
49.633998870849609 -50.200000762939453 17.000000000000000
49.551998138427734 -50.250000000000000 17.000000000000000
49.465000152587891 -50.299999237060547 17.000000000000000
47.549999237060547 60.000000000000000 17.000000000000000
51.138942718505859 60.000000000000000 17.000000000000000
51.138942718505859 60.000000000000000 12.000000000000000
49.375000000000000 -50.349998474121094 17.000000000000000
49.279998779296875 -50.400001525878906 17.000000000000000
51.140472412109375 60.002998352050781 12.000000000000000
51.140472412109375 60.002998352050781 17.000000000000000
47.502998352050781 60.002998352050781 17.000000000000000
-4.809999942779541 -49.452999114990234 17.000000000000000
-0.800000011920929 -49.712001800537109 1.498000025749207
-0.850000023841858 -49.666000366210938 17.000000000000000
-0.800000011920929 -49.712001800537109 17.000000000000000
-0.899999976158142 -49.618999481201172 1.498000025749207
-0.899999976158142 -49.618999481201172 17.000000000000000
47.502998352050781 61.500000000000000 7.998000144958496
47.502998352050781 60.002998352050781 7.998000144958496
47.502998352050781 61.500000000000000 17.000000000000000
-0.349999994039536 -50.073001861572266 17.000000000000000
-0.349999994039536 -50.073001861572266 1.498000025749207
-0.400000005960464 -50.036998748779297 17.000000000000000
-0.449999988079071 -50.000000000000000 17.000000000000000
-0.449999988079071 -50.000000000000000 1.498000025749207
-0.500000000000000 -49.962001800537109 17.000000000000000
-0.550000011920929 -49.923000335693359 1.498000025749207
-0.550000011920929 -49.923000335693359 17.000000000000000
-0.100000001490116 -50.240001678466797 1.498000025749207
-0.200000002980232 -50.175998687744141 1.498000025749207
-0.100000001490116 -50.240001678466797 17.000000000000000
-0.050000000745058 -50.270999908447266 1.498000025749207
-0.050000000745058 -50.270999908447266 17.000000000000000
0.000000000000000 -50.300998687744141 17.000000000000000
-0.250000000000000 -50.143001556396484 17.000000000000000
-0.200000002980232 -50.175998687744141 17.000000000000000
-0.949999988079071 -49.570999145507812 17.000000000000000
50.250000000000000 -49.750000000000000 17.000000000000000
50.189998626708984 -49.799999237060547 17.000000000000000
0.377083003520966 -50.502998352050781 17.000000000000000
0.377083003520966 -50.502998352050781 1.498000025749207
0.349999994039536 -50.490001678466797 17.000000000000000
0.349999994039536 -50.490001678466797 1.498000025749207
0.250000000000000 -50.439998626708984 1.498000025749207
0.100000001490116 -50.359001159667969 1.498000025749207
0.100000001490116 -50.359001159667969 17.000000000000000
0.000000000000000 -50.300998687744141 1.498000025749207
0.250000000000000 -50.439998626708984 17.000000000000000
53.998001098632812 60.002998352050781 1.498000025749207
38.498001098632812 60.002998352050781 7.998000144958496
19.502000808715820 60.002998352050781 7.998000144958496
-7.999683856964111 -48.498001098632812 0.000000000000000
-8.000000000000000 -48.498001098632812 0.000000000000000
0.500000000000000 -11.000000000000000 0.000000000000000
-6.501999855041504 60.000000000000000 0.000000000000000
-4.498000144958496 60.000000000000000 0.000000000000000
-8.000000000000000 58.000000000000000 0.000000000000000
-7.331999778747559 60.056999206542969 0.000000000000000
-6.501999855041504 60.002998352050781 0.000000000000000
-5.581999778747559 61.328998565673828 0.000000000000000
-4.498000144958496 60.002998352050781 0.000000000000000
-6.557000160217285 60.832000732421875 0.000000000000000
-4.500000000000000 61.500000000000000 0.000000000000000
-7.999683856964111 57.998001098632812 0.000000000000000
0.500000000000000 53.502998352050781 0.000000000000000
-8.000000000000000 43.569419860839844 0.000000000000000
-4.498000144958496 61.499683380126953 0.000000000000000
-7.331999778747559 -50.556999206542969 0.000000000000000
-6.557000160217285 -51.332000732421875 0.000000000000000
-5.581999778747559 -51.828998565673828 0.000000000000000
-8.000000000000000 -48.500000000000000 0.000000000000000
-7.828999996185303 -49.582000732421875 0.000000000000000
-4.500000000000000 -49.502998352050781 0.000000000000000
-4.500000000000000 -52.000000000000000 0.000000000000000
-4.498000144958496 -51.999683380126953 0.000000000000000
-4.809999942779541 -49.452999114990234 0.000000000000000
-8.000000000000000 -48.498001098632812 17.000000000000000
-6.502999782562256 -43.566219329833984 17.000000000000000
-8.000000000000000 57.998001098632812 17.000000000000000
-6.502999782562256 53.122917175292969 17.000000000000000
-6.489999771118164 53.150001525878906 17.000000000000000
-8.000000000000000 58.000000000000000 17.000000000000000
-7.999683856964111 57.998001098632812 17.000000000000000
-5.502999782562256 58.000000000000000 17.000000000000000
-6.176000118255615 53.700000762939453 17.000000000000000
-6.143000125885010 53.750000000000000 17.000000000000000
-6.239999771118164 53.599998474121094 17.000000000000000
-6.440000057220459 53.250000000000000 17.000000000000000
-7.999683856964111 -48.498001098632812 17.000000000000000
53.998001098632812 61.500000000000000 0.000000000000000
38.498001098632812 61.500000000000000 7.998000144958496
49.066219329833984 -50.502998352050781 1.498000025749207
30.003000259399414 -50.502998352050781 7.271999835968018
-7.828999996185303 59.082000732421875 17.000000000000000
-5.310999870300293 58.589000701904297 17.000000000000000
-7.331999778747559 60.056999206542969 17.000000000000000
29.757999420166016 -52.000000000000000 8.817999839782715
29.047000885009766 -52.000000000000000 10.213000297546387
-5.453000068664551 57.689998626708984 17.000000000000000
29.757999420166016 -50.502998352050781 8.817999839782715
-7.331999778747559 -50.556999206542969 17.000000000000000
-7.828999996185303 -49.582000732421875 17.000000000000000
-6.557000160217285 -51.332000732421875 17.000000000000000
-5.581999778747559 -51.828998565673828 17.000000000000000
-8.000000000000000 -48.500000000000000 17.000000000000000
-4.498000144958496 -52.000000000000000 17.000000000000000
-1.100000023841858 -49.416999816894531 17.000000000000000
-4.498000144958496 -51.999683380126953 17.000000000000000
-1.049999952316284 -49.470001220703125 17.000000000000000
-1.138373017311096 -49.375556945800781 17.000000000000000
30.003000259399414 -52.000000000000000 7.271999835968018
29.047000885009766 -50.502998352050781 10.213000297546387
-4.190000057220459 58.952999114990234 17.000000000000000
-3.911000013351440 58.811000823974609 17.000000000000000
-4.498000144958496 61.499683380126953 17.000000000000000
27.940000534057617 -52.000000000000000 11.319000244140625
27.940000534057617 -50.502998352050781 11.319000244140625
-5.089000225067139 58.811000823974609 17.000000000000000
-6.557000160217285 60.832000732421875 17.000000000000000
-5.581999778747559 61.328998565673828 17.000000000000000
26.545999526977539 -52.000000000000000 12.029999732971191
26.545999526977539 -50.502998352050781 12.029999732971191
25.000000000000000 -52.000000000000000 12.274999618530273
25.000000000000000 -50.502998352050781 12.274999618530273
-4.500000000000000 -52.000000000000000 17.000000000000000
23.454000473022461 -52.000000000000000 12.029999732971191
23.454000473022461 -50.502998352050781 12.029999732971191
-1.667999982833862 -46.443000793457031 17.000000000000000
22.059999465942383 -52.000000000000000 11.319000244140625
22.059999465942383 -50.502998352050781 11.319000244140625
20.952999114990234 -52.000000000000000 10.213000297546387
20.952999114990234 -50.502998352050781 10.213000297546387
20.242000579833984 -52.000000000000000 8.817999839782715
20.242000579833984 -50.502998352050781 8.817999839782715
19.997999191284180 -50.502998352050781 7.271999835968018
25.000000000000000 -50.502998352050781 2.269999980926514
26.545999526977539 -52.000000000000000 2.515000104904175
26.545999526977539 -50.502998352050781 2.515000104904175
25.000000000000000 -52.000000000000000 2.269999980926514
27.940000534057617 -52.000000000000000 3.224999904632568
27.940000534057617 -50.502998352050781 3.224999904632568
29.047000885009766 -52.000000000000000 4.331999778747559
29.047000885009766 -50.502998352050781 4.331999778747559
29.757999420166016 -52.000000000000000 5.725999832153320
29.757999420166016 -50.502998352050781 5.725999832153320
-1.171000003814697 -47.417999267578125 17.000000000000000
-1.000000000000000 -48.500000000000000 17.000000000000000
19.997999191284180 -52.000000000000000 7.271999835968018
20.242000579833984 -52.000000000000000 5.725999832153320
20.242000579833984 -50.502998352050781 5.725999832153320
20.952999114990234 -52.000000000000000 4.331999778747559
20.952999114990234 -50.502998352050781 4.331999778747559
22.059999465942383 -52.000000000000000 3.224999904632568
22.059999465942383 -50.502998352050781 3.224999904632568
23.454000473022461 -52.000000000000000 2.515000104904175
23.454000473022461 -50.502998352050781 2.515000104904175
-5.550000190734863 -44.970001220703125 1.498000025749207
-5.550000190734863 -44.970001220703125 17.000000000000000
-5.599999904632568 -44.916999816894531 17.000000000000000
-6.199999809265137 -44.133998870849609 17.000000000000000
-6.150000095367432 -44.213001251220703 17.000000000000000
-6.099999904632568 -44.289001464843750 17.000000000000000
-6.300000190734863 -43.965000152587891 17.000000000000000
-6.250000000000000 -44.051998138427734 17.000000000000000
-6.400000095367432 -43.779998779296875 17.000000000000000
-6.349999904632568 -43.875000000000000 17.000000000000000
-6.449999809265137 -43.680000305175781 17.000000000000000
-6.500000000000000 -43.573001861572266 17.000000000000000
-5.650000095367432 -44.862998962402344 17.000000000000000
-5.699999809265137 -44.806999206542969 17.000000000000000
-5.750000000000000 -44.750000000000000 17.000000000000000
-5.900000095367432 -44.566001892089844 17.000000000000000
-5.849999904632568 -44.629001617431641 17.000000000000000
-5.949999809265137 -44.500000000000000 17.000000000000000
-5.800000190734863 -44.689998626708984 17.000000000000000
-6.099999904632568 -44.289001464843750 1.498000025749207
-6.150000095367432 -44.213001251220703 1.498000025749207
-6.000000000000000 -44.431999206542969 17.000000000000000
-6.199999809265137 -44.133998870849609 1.498000025749207
-6.050000190734863 -44.361999511718750 17.000000000000000
-6.250000000000000 -44.051998138427734 1.498000025749207
-6.300000190734863 -43.965000152587891 1.498000025749207
-6.349999904632568 -43.875000000000000 1.498000025749207
-5.089000225067139 57.188999176025391 17.000000000000000
-5.375555992126465 54.638374328613281 17.000000000000000
-4.809999942779541 57.047000885009766 17.000000000000000
-1.667999982833862 55.943000793457031 17.000000000000000
-3.688999891281128 57.410999298095703 17.000000000000000
-2.443000078201294 55.167999267578125 17.000000000000000
-3.911000013351440 57.188999176025391 17.000000000000000
-3.417999982833862 54.671001434326172 17.000000000000000
-4.190000057220459 57.047000885009766 17.000000000000000
-1.171000003814697 56.917999267578125 17.000000000000000
-4.500000000000000 54.500000000000000 17.000000000000000
-4.500000000000000 56.998001098632812 17.000000000000000
-6.502999782562256 -43.566219329833984 1.498000025749207
48.000000000000000 -11.000000000000000 1.500000000000000
48.000000000000000 -11.000000000000000 0.000000000000000
-5.699999809265137 -44.806999206542969 1.498000025749207
-5.650000095367432 -44.862998962402344 1.498000025749207
-5.750000000000000 -44.750000000000000 1.498000025749207
0.500000000000000 -11.000000000000000 1.500000000000000
-5.900000095367432 -44.566001892089844 1.498000025749207
36.000000000000000 56.000000000000000 1.498000025749207
48.000000000000000 54.000000000000000 1.498000025749207
56.000000000000000 56.000000000000000 1.498000025749207
-5.310999870300293 57.410999298095703 17.000000000000000
36.000000000000000 56.000000000000000 1.500000000000000
56.000000000000000 56.000000000000000 1.500000000000000
-5.469999790191650 54.549999237060547 17.000000000000000
-5.416999816894531 54.599998474121094 17.000000000000000
36.000000000000000 60.000000000000000 1.498000025749207
36.000000000000000 60.000000000000000 1.500000000000000
53.998001098632812 60.000000000000000 1.498000025749207
-6.050000190734863 -44.361999511718750 1.498000025749207
-4.498000144958496 60.002998352050781 1.498000025749207
-0.916999995708466 59.099998474121094 17.000000000000000
-0.970000028610229 59.049999237060547 17.000000000000000
-0.916999995708466 59.099998474121094 12.000000000000000
-0.862999975681305 59.150001525878906 12.000000000000000
-0.689999997615814 59.299999237060547 12.000000000000000
-0.689999997615814 59.299999237060547 17.000000000000000
-0.750000000000000 59.250000000000000 12.000000000000000
-0.629000008106232 59.349998474121094 12.000000000000000
-0.806999981403351 59.200000762939453 12.000000000000000
-0.806999981403351 59.200000762939453 17.000000000000000
-0.750000000000000 59.250000000000000 17.000000000000000
53.998001098632812 61.500000000000000 17.000000000000000
56.000000000000000 60.000000000000000 1.500000000000000
-0.565999984741211 59.400001525878906 17.000000000000000
-0.565999984741211 59.400001525878906 12.000000000000000
-0.500000000000000 59.450000762939453 17.000000000000000
-5.453000068664551 58.310001373291016 17.000000000000000
-3.497999906539917 58.000000000000000 17.000000000000000
-1.000000000000000 58.000000000000000 17.000000000000000
-1.138892054557800 58.878837585449219 17.000000000000000
-3.546999931335449 57.689998626708984 17.000000000000000
-1.118999958038330 58.900001525878906 17.000000000000000
-4.809999942779541 58.952999114990234 17.000000000000000
-4.500000000000000 59.002998352050781 17.000000000000000
-4.500000000000000 61.500000000000000 17.000000000000000
-3.688999891281128 58.589000701904297 17.000000000000000
-3.546999931335449 58.310001373291016 17.000000000000000
50.500000000000000 58.000000000000000 12.000000000000000
53.047000885009766 57.689998626708984 12.000000000000000
50.671001434326172 56.917999267578125 12.000000000000000
48.150001525878906 59.958000183105469 12.000000000000000
48.049999237060547 59.970001220703125 12.000000000000000
47.549999237060547 60.000000000000000 12.000000000000000
47.650001525878906 59.998001098632812 12.000000000000000
47.750000000000000 59.993999481201172 12.000000000000000
47.849998474121094 59.987998962402344 12.000000000000000
47.950000762939453 59.979999542236328 12.000000000000000
48.299999237060547 59.936000823974609 12.000000000000000
48.250000000000000 59.944000244140625 12.000000000000000
-6.359000205993652 53.400001525878906 17.000000000000000
-6.072999954223633 53.849998474121094 17.000000000000000
-6.037000179290771 53.900001525878906 17.000000000000000
-6.000000000000000 53.950000762939453 17.000000000000000
38.498001098632812 61.500000000000000 17.000000000000000
38.498001098632812 60.002998352050781 17.000000000000000
48.700000762939453 59.854000091552734 12.000000000000000
48.599998474121094 59.877998352050781 12.000000000000000
-6.301000118255615 53.500000000000000 17.000000000000000
19.502000808715820 60.002998352050781 17.000000000000000
19.502000808715820 61.500000000000000 7.998000144958496
19.502000808715820 61.500000000000000 17.000000000000000
-6.270999908447266 53.549999237060547 17.000000000000000
48.549999237060547 59.888999938964844 12.000000000000000
48.450000762939453 59.909000396728516 12.000000000000000
7.497000217437744 61.500000000000000 17.000000000000000
7.497000217437744 60.002998352050781 7.998000144958496
7.497000217437744 61.500000000000000 7.998000144958496
7.497000217437744 60.002998352050781 17.000000000000000
-5.711999893188477 54.299999237060547 17.000000000000000
-5.665999889373779 54.349998474121094 17.000000000000000
-5.800000190734863 54.200000762939453 17.000000000000000
-5.842000007629395 54.150001525878906 17.000000000000000
-6.501999855041504 60.002998352050781 12.000000000000000
-1.640473961830139 60.002998352050781 12.000000000000000
49.150001525878906 59.720001220703125 12.000000000000000
49.250000000000000 59.683998107910156 12.000000000000000
49.049999237060547 59.754001617431641 12.000000000000000
48.900001525878906 59.799999237060547 12.000000000000000
48.799999237060547 59.827999114990234 12.000000000000000
49.000000000000000 59.770000457763672 12.000000000000000
-5.961999893188477 54.000000000000000 17.000000000000000
-5.922999858856201 54.049999237060547 17.000000000000000
-5.882999897003174 54.099998474121094 17.000000000000000
0.433840006589890 60.002998352050781 12.000000000000000
-5.618999958038330 54.400001525878906 17.000000000000000
-5.571000099182129 54.450000762939453 17.000000000000000
0.433840006589890 60.002998352050781 17.000000000000000
-5.520999908447266 54.500000000000000 17.000000000000000
54.589000701904297 -49.311000823974609 17.000000000000000
56.056999206542969 -51.332000732421875 17.000000000000000
54.811000823974609 -49.089000701904297 17.000000000000000
57.328998565673828 -49.582000732421875 17.000000000000000
54.952999114990234 -48.810001373291016 17.000000000000000
51.943000793457031 -45.667999267578125 17.000000000000000
51.167999267578125 -46.443000793457031 17.000000000000000
53.188999176025391 -47.910999298095703 17.000000000000000
53.410999298095703 -47.688999176025391 17.000000000000000
-1.049999952316284 -49.470001220703125 1.498000025749207
-1.100000023841858 -49.416999816894531 1.498000025749207
52.917999267578125 -45.171001434326172 17.000000000000000
53.689998626708984 -47.547000885009766 17.000000000000000
-1.138373017311096 -49.375556945800781 1.498000025749207
53.188999176025391 -49.089000701904297 17.000000000000000
50.638893127441406 -49.378837585449219 17.000000000000000
53.410999298095703 -49.311000823974609 17.000000000000000
53.047000885009766 -48.810001373291016 17.000000000000000
50.671001434326172 -47.417999267578125 17.000000000000000
50.500000000000000 -48.500000000000000 17.000000000000000
53.047000885009766 -48.189998626708984 17.000000000000000
49.950000762939453 59.359001159667969 12.000000000000000
49.799999237060547 59.439998626708984 12.000000000000000
50.150001525878906 59.240001678466797 12.000000000000000
50.099998474121094 59.270999908447266 12.000000000000000
57.500000000000000 -47.753463745117188 17.000000000000000
57.499683380126953 -48.498001098632812 17.000000000000000
57.500000000000000 -48.498001098632812 17.000000000000000
54.952999114990234 -48.189998626708984 17.000000000000000
54.811000823974609 -47.910999298095703 17.000000000000000
50.049999237060547 59.300998687744141 12.000000000000000
55.070999145507812 -44.950000762939453 17.000000000000000
55.020999908447266 -45.000000000000000 17.000000000000000
53.047000885009766 58.310001373291016 12.000000000000000
50.640724182128906 58.890422821044922 12.000000000000000
52.998001098632812 58.000000000000000 12.000000000000000
54.589000701904297 -47.688999176025391 17.000000000000000
54.875556945800781 -45.138374328613281 17.000000000000000
54.916999816894531 -45.099998474121094 17.000000000000000
53.188999176025391 57.410999298095703 12.000000000000000
-8.000000000000000 43.569419860839844 5.000000000000000
-8.000000000000000 49.430580139160156 5.000000000000000
-1.171000003814697 -47.417999267578125 1.498000025749207
-1.667999982833862 -46.443000793457031 1.498000025749207
-8.000000000000000 49.430580139160156 0.000000000000000
-8.000000000000000 57.998001098632812 0.000000000000000
50.599998474121094 58.923000335693359 12.000000000000000
50.549999237060547 58.962001800537109 12.000000000000000
50.400001525878906 59.073001861572266 12.000000000000000
50.299999237060547 59.143001556396484 12.000000000000000
-16.829999923706055 45.206001281738281 0.000000000000000
-16.329999923706055 44.000000000000000 0.000000000000000
-16.829999923706055 45.206001281738281 5.000000000000000
-17.000000000000000 46.500000000000000 5.000000000000000
-17.000000000000000 46.500000000000000 0.000000000000000
-16.829999923706055 47.793998718261719 0.000000000000000
-16.829999923706055 47.793998718261719 5.000000000000000
-16.329999923706055 49.000000000000000 0.000000000000000
-16.329999923706055 49.000000000000000 5.000000000000000
50.500000000000000 59.000000000000000 12.000000000000000
50.450000762939453 59.036998748779297 12.000000000000000
-15.536000251770020 50.035999298095703 0.000000000000000
-15.536000251770020 50.035999298095703 5.000000000000000
50.250000000000000 59.175998687744141 12.000000000000000
-14.652000427246094 49.152000427246094 5.000000000000000
-15.248000144958496 48.375000000000000 0.000000000000000
-14.652000427246094 49.152000427246094 0.000000000000000
-15.248000144958496 48.375000000000000 5.000000000000000
-15.621999740600586 47.471000671386719 0.000000000000000
-15.621999740600586 47.471000671386719 5.000000000000000
-15.536000251770020 42.964000701904297 5.000000000000000
-16.329999923706055 44.000000000000000 5.000000000000000
-15.536000251770020 42.964000701904297 0.000000000000000
-15.750000000000000 46.500000000000000 0.000000000000000
-15.750000000000000 46.500000000000000 5.000000000000000
-14.500000000000000 42.169998168945312 0.000000000000000
54.970001220703125 -45.049999237060547 17.000000000000000
55.118999481201172 -44.900001525878906 17.000000000000000
55.166000366210938 -44.849998474121094 17.000000000000000
54.000000000000000 -45.000000000000000 1.498000025749207
51.000000000000000 -18.500000000000000 1.498000025749207
52.917999267578125 -45.171001434326172 1.498000025749207
51.943000793457031 -45.667999267578125 1.498000025749207
55.118999481201172 -44.900001525878906 1.498000025749207
55.070999145507812 -44.950000762939453 1.498000025749207
55.020999908447266 -45.000000000000000 1.498000025749207
49.500000000000000 59.583000183105469 12.000000000000000
49.549999237060547 59.561000823974609 12.000000000000000
49.599998474121094 59.537998199462891 12.000000000000000
54.875556945800781 -45.138374328613281 1.498000025749207
55.800998687744141 -44.000000000000000 1.498000025749207
55.859001159667969 -43.900001525878906 1.498000025749207
55.166000366210938 -44.849998474121094 1.498000025749207
55.299999237060547 -44.700000762939453 1.498000025749207
55.341999053955078 -44.650001525878906 1.498000025749207
55.212001800537109 -44.799999237060547 1.498000025749207
55.770999908447266 -44.049999237060547 1.498000025749207
55.740001678466797 -44.099998474121094 1.498000025749207
49.700000762939453 59.490001678466797 12.000000000000000
55.299999237060547 -44.700000762939453 17.000000000000000
49.400001525878906 59.625000000000000 12.000000000000000
-1.000000000000000 -48.500000000000000 1.498000025749207
49.299999237060547 59.665000915527344 12.000000000000000
56.002998352050781 60.002998352050781 12.000000000000000
55.675998687744141 -44.200000762939453 1.498000025749207
55.608001708984375 -44.299999237060547 1.498000025749207
55.573001861572266 -44.349998474121094 1.498000025749207
55.536998748779297 -44.400001525878906 1.498000025749207
55.382999420166016 -44.599998474121094 1.498000025749207
55.423000335693359 -44.549999237060547 1.498000025749207
55.462001800537109 -44.500000000000000 1.498000025749207
55.500000000000000 -44.450000762939453 1.498000025749207
-1.000000000000000 -49.520999908447266 17.000000000000000
-1.000000000000000 -49.520999908447266 1.498000025749207
56.001998901367188 -43.625000000000000 1.498000025749207
55.990001678466797 -43.650001525878906 1.498000025749207
55.939998626708984 -43.750000000000000 1.498000025749207
-0.500000000000000 59.450000762939453 12.000000000000000
-0.432000011205673 59.500000000000000 12.000000000000000
-0.432000011205673 59.500000000000000 17.000000000000000
-0.361999988555908 59.549999237060547 12.000000000000000
-0.134000003337860 59.700000762939453 12.000000000000000
-0.052000001072884 59.750000000000000 12.000000000000000
-0.052000001072884 59.750000000000000 17.000000000000000
-0.970000028610229 59.049999237060547 12.000000000000000
-1.021000027656555 59.000000000000000 12.000000000000000
-1.021000027656555 59.000000000000000 17.000000000000000
55.212001800537109 -44.799999237060547 17.000000000000000
-0.629000008106232 59.349998474121094 17.000000000000000
-0.361999988555908 59.549999237060547 17.000000000000000
-0.289000004529953 59.599998474121094 12.000000000000000
-0.289000004529953 59.599998474121094 17.000000000000000
-0.212999999523163 59.650001525878906 12.000000000000000
55.462001800537109 -44.500000000000000 17.000000000000000
55.423000335693359 -44.549999237060547 17.000000000000000
0.035000000149012 59.799999237060547 12.000000000000000
-0.862999975681305 59.150001525878906 17.000000000000000
-3.417999982833862 54.671001434326172 12.000000000000000
-2.443000078201294 55.167999267578125 12.000000000000000
-1.667999982833862 55.943000793457031 12.000000000000000
-1.171000003814697 56.917999267578125 12.000000000000000
-1.000000000000000 58.000000000000000 12.000000000000000
-1.138892054557800 58.878837585449219 12.000000000000000
-1.118999958038330 58.900001525878906 12.000000000000000
-1.070999979972839 58.950000762939453 12.000000000000000
-0.212999999523163 59.650001525878906 17.000000000000000
-0.134000003337860 59.700000762939453 17.000000000000000
-15.621999740600586 45.528999328613281 0.000000000000000
-15.621999740600586 45.528999328613281 5.000000000000000
0.125000000000000 59.849998474121094 12.000000000000000
0.125000000000000 59.849998474121094 17.000000000000000
0.219999998807907 59.900001525878906 12.000000000000000
0.219999998807907 59.900001525878906 17.000000000000000
-14.500000000000000 42.169998168945312 5.000000000000000
-15.248000144958496 44.625000000000000 0.000000000000000
-15.248000144958496 44.625000000000000 5.000000000000000
0.321000009775162 59.950000762939453 12.000000000000000
-13.293999671936035 41.669998168945312 0.000000000000000
-13.293999671936035 41.669998168945312 5.000000000000000
-14.652000427246094 43.847999572753906 0.000000000000000
-14.652000427246094 43.847999572753906 5.000000000000000
-1.070999979972839 58.950000762939453 17.000000000000000
-12.000000000000000 41.500000000000000 5.000000000000000
-12.000000000000000 41.500000000000000 0.000000000000000
-13.875000000000000 43.251998901367188 5.000000000000000
-13.875000000000000 43.251998901367188 0.000000000000000
-12.970999717712402 42.877998352050781 5.000000000000000
-12.970999717712402 42.877998352050781 0.000000000000000
-12.000000000000000 42.750000000000000 0.000000000000000
-12.000000000000000 42.750000000000000 5.000000000000000
-8.463999748229980 42.964000701904297 0.000000000000000
-9.500000000000000 42.169998168945312 5.000000000000000
-9.500000000000000 42.169998168945312 0.000000000000000
-8.463999748229980 42.964000701904297 5.000000000000000
-10.706000328063965 41.669998168945312 5.000000000000000
-10.706000328063965 41.669998168945312 0.000000000000000
-11.029000282287598 42.877998352050781 5.000000000000000
-11.029000282287598 42.877998352050781 0.000000000000000
-10.125000000000000 43.251998901367188 5.000000000000000
-10.125000000000000 43.251998901367188 0.000000000000000
-9.347999572753906 43.847999572753906 5.000000000000000
-9.347999572753906 43.847999572753906 0.000000000000000
-8.751999855041504 44.625000000000000 5.000000000000000
-8.751999855041504 44.625000000000000 0.000000000000000
-8.378000259399414 45.528999328613281 5.000000000000000
-8.378000259399414 45.528999328613281 0.000000000000000
-8.250000000000000 46.500000000000000 5.000000000000000
-8.250000000000000 46.500000000000000 0.000000000000000
0.035000000149012 59.799999237060547 17.000000000000000
0.321000009775162 59.950000762939453 17.000000000000000
0.426999986171722 60.000000000000000 12.000000000000000
0.426999986171722 60.000000000000000 17.000000000000000
55.990001678466797 -43.650001525878906 17.000000000000000
-3.688999891281128 57.410999298095703 12.000000000000000
-3.911000013351440 57.188999176025391 12.000000000000000
-3.497999906539917 58.000000000000000 12.000000000000000
-3.546999931335449 58.310001373291016 12.000000000000000
-3.546999931335449 57.689998626708984 12.000000000000000
-4.498000144958496 -52.000000000000000 0.000000000000000
53.998001098632812 -52.000000000000000 0.000000000000000
-0.600000023841858 -49.882999420166016 17.000000000000000
-0.600000023841858 -49.882999420166016 1.498000025749207
-0.699999988079071 -49.799999237060547 17.000000000000000
-0.649999976158142 -49.841999053955078 1.498000025749207
-0.699999988079071 -49.799999237060547 1.498000025749207
-0.850000023841858 -49.666000366210938 1.498000025749207
-8.378000259399414 47.471000671386719 5.000000000000000
-8.378000259399414 47.471000671386719 0.000000000000000
-8.751999855041504 48.375000000000000 5.000000000000000
-8.751999855041504 48.375000000000000 0.000000000000000
-9.347999572753906 49.152000427246094 0.000000000000000
-9.347999572753906 49.152000427246094 5.000000000000000
-0.250000000000000 -50.143001556396484 1.498000025749207
-12.000000000000000 51.500000000000000 0.000000000000000
-13.293999671936035 51.330001831054688 0.000000000000000
-12.000000000000000 51.500000000000000 5.000000000000000
-10.706000328063965 51.330001831054688 0.000000000000000
-10.706000328063965 51.330001831054688 5.000000000000000
-9.500000000000000 50.830001831054688 0.000000000000000
-9.500000000000000 50.830001831054688 5.000000000000000
-8.463999748229980 50.035999298095703 0.000000000000000
-8.463999748229980 50.035999298095703 5.000000000000000
-10.125000000000000 49.748001098632812 5.000000000000000
-10.125000000000000 49.748001098632812 0.000000000000000
-14.500000000000000 50.830001831054688 0.000000000000000
-13.293999671936035 51.330001831054688 5.000000000000000
-11.029000282287598 50.122001647949219 5.000000000000000
-11.029000282287598 50.122001647949219 0.000000000000000
-14.500000000000000 50.830001831054688 5.000000000000000
-12.000000000000000 50.250000000000000 5.000000000000000
-12.000000000000000 50.250000000000000 0.000000000000000
-0.949999988079071 -49.570999145507812 1.498000025749207
-12.970999717712402 50.122001647949219 0.000000000000000
-12.970999717712402 50.122001647949219 5.000000000000000
-13.875000000000000 49.748001098632812 0.000000000000000
-13.875000000000000 49.748001098632812 5.000000000000000
51.000000000000000 54.000000000000000 1.498000025749207
51.000000000000000 54.000000000000000 1.500000000000000
48.000000000000000 54.000000000000000 1.500000000000000
48.000000000000000 53.502998352050781 1.498000025749207
48.000000000000000 53.502998352050781 0.000000000000000
55.770999908447266 -44.049999237060547 17.000000000000000
55.800998687744141 -44.000000000000000 17.000000000000000
13.000000000000000 56.000000000000000 1.498000025749207
-4.498000144958496 61.500000000000000 0.000000000000000
-5.800000190734863 -44.689998626708984 1.498000025749207
-5.849999904632568 -44.629001617431641 1.498000025749207
0.500000000000000 53.502998352050781 1.498000025749207
13.000000000000000 60.000000000000000 1.498000025749207
-4.498000144958496 60.000000000000000 1.498000025749207
-6.501999855041504 56.000000000000000 1.498000025749207
0.500000000000000 54.000000000000000 1.498000025749207
-3.000000000000000 54.000000000000000 1.498000025749207
-5.949999809265137 -44.500000000000000 1.498000025749207
-6.501999855041504 60.000000000000000 1.500000000000000
13.000000000000000 60.000000000000000 1.500000000000000
-6.400000095367432 -43.779998779296875 1.498000025749207
-3.000000000000000 54.000000000000000 1.500000000000000
0.500000000000000 54.000000000000000 1.500000000000000
-6.449999809265137 -43.680000305175781 1.498000025749207
13.000000000000000 56.000000000000000 1.500000000000000
-4.498000144958496 61.500000000000000 17.000000000000000
-3.000000000000000 -18.500000000000000 1.500000000000000
-3.000000000000000 -18.500000000000000 1.498000025749207
51.000000000000000 -18.500000000000000 1.500000000000000
-6.000000000000000 -44.431999206542969 1.498000025749207
50.500000000000000 -48.500000000000000 1.498000025749207
50.638893127441406 -49.378837585449219 1.498000025749207
50.618999481201172 -49.400001525878906 1.498000025749207
49.073001861572266 -50.500000000000000 1.498000025749207
50.416999816894531 -49.599998474121094 1.498000025749207
50.470001220703125 -49.549999237060547 1.498000025749207
50.570999145507812 -49.450000762939453 1.498000025749207
51.167999267578125 -46.443000793457031 1.498000025749207
50.671001434326172 -47.417999267578125 1.498000025749207
-6.500000000000000 -43.573001861572266 1.498000025749207
49.180000305175781 -50.450000762939453 1.498000025749207
49.279998779296875 -50.400001525878906 1.498000025749207
55.900001525878906 53.279998779296875 17.000000000000000
55.900001525878906 53.279998779296875 12.000000000000000
55.950000762939453 53.180000305175781 17.000000000000000
55.950000762939453 53.180000305175781 12.000000000000000
56.000000000000000 53.073001861572266 12.000000000000000
56.000000000000000 53.073001861572266 17.000000000000000
56.001998901367188 53.068481445312500 12.000000000000000
56.001998901367188 53.068481445312500 17.000000000000000
49.633998870849609 -50.200000762939453 1.498000025749207
49.551998138427734 -50.250000000000000 1.498000025749207
49.465000152587891 -50.299999237060547 1.498000025749207
49.375000000000000 -50.349998474121094 1.498000025749207
51.943000793457031 55.167999267578125 17.000000000000000
51.943000793457031 55.167999267578125 12.000000000000000
52.917999267578125 54.671001434326172 12.000000000000000
54.000000000000000 54.500000000000000 12.000000000000000
54.000000000000000 54.500000000000000 17.000000000000000
51.167999267578125 55.943000793457031 12.000000000000000
51.167999267578125 55.943000793457031 17.000000000000000
50.250000000000000 -49.750000000000000 1.498000025749207
50.189998626708984 -49.799999237060547 1.498000025749207
50.129001617431641 -49.849998474121094 1.498000025749207
50.066001892089844 -49.900001525878906 1.498000025749207
50.000000000000000 -49.950000762939453 1.498000025749207
49.931999206542969 -50.000000000000000 1.498000025749207
49.861999511718750 -50.049999237060547 1.498000025749207
49.789001464843750 -50.099998474121094 1.498000025749207
49.713001251220703 -50.150001525878906 1.498000025749207
50.306999206542969 -49.700000762939453 1.498000025749207
50.520999908447266 -49.500000000000000 1.498000025749207
52.917999267578125 54.671001434326172 17.000000000000000
55.250000000000000 54.250000000000000 17.000000000000000
55.200000762939453 54.306999206542969 17.000000000000000
55.250000000000000 54.250000000000000 12.000000000000000
55.299999237060547 54.189998626708984 17.000000000000000
55.299999237060547 54.189998626708984 12.000000000000000
55.740001678466797 -44.099998474121094 17.000000000000000
-0.400000005960464 -50.036998748779297 1.498000025749207
-0.500000000000000 -49.962001800537109 1.498000025749207
-5.599999904632568 -44.916999816894531 1.498000025749207
56.001998901367188 -43.625000000000000 17.000000000000000
55.859001159667969 -43.900001525878906 17.000000000000000
55.049999237060547 54.470001220703125 12.000000000000000
55.049999237060547 54.470001220703125 17.000000000000000
55.000000000000000 54.520999908447266 12.000000000000000
55.099998474121094 54.416999816894531 12.000000000000000
55.099998474121094 54.416999816894531 17.000000000000000
55.150001525878906 54.362998962402344 12.000000000000000
55.150001525878906 54.362998962402344 17.000000000000000
54.878837585449219 54.638893127441406 17.000000000000000
54.878837585449219 54.638893127441406 12.000000000000000
54.900001525878906 54.618999481201172 17.000000000000000
54.900001525878906 54.618999481201172 12.000000000000000
55.200000762939453 54.306999206542969 12.000000000000000
55.349998474121094 54.129001617431641 12.000000000000000
55.349998474121094 54.129001617431641 17.000000000000000
55.400001525878906 54.066001892089844 12.000000000000000
55.400001525878906 54.066001892089844 17.000000000000000
53.998001098632812 60.000000000000000 0.000000000000000
55.500000000000000 53.931999206542969 12.000000000000000
55.549999237060547 53.861999511718750 12.000000000000000
55.549999237060547 53.861999511718750 17.000000000000000
55.599998474121094 53.789001464843750 12.000000000000000
55.650001525878906 53.713001251220703 12.000000000000000
55.650001525878906 53.713001251220703 17.000000000000000
55.700000762939453 53.633998870849609 12.000000000000000
53.998001098632812 60.002998352050781 0.000000000000000
53.998001098632812 61.499683380126953 0.000000000000000
55.799999237060547 53.465000152587891 12.000000000000000
55.849998474121094 53.375000000000000 12.000000000000000
55.849998474121094 53.375000000000000 17.000000000000000
54.950000762939453 54.570999145507812 12.000000000000000
52.998001098632812 -48.500000000000000 0.000000000000000
53.047000885009766 -48.810001373291016 0.000000000000000
53.188999176025391 -49.089000701904297 0.000000000000000
53.998001098632812 -51.999683380126953 0.000000000000000
53.410999298095703 -49.311000823974609 0.000000000000000
53.047000885009766 -48.189998626708984 0.000000000000000
55.573001861572266 -44.349998474121094 17.000000000000000
55.608001708984375 -44.299999237060547 17.000000000000000
53.188999176025391 -47.910999298095703 0.000000000000000
-0.649999976158142 -49.841999053955078 17.000000000000000
54.950000762939453 54.570999145507812 17.000000000000000
55.000000000000000 54.520999908447266 17.000000000000000
55.450000762939453 54.000000000000000 12.000000000000000
55.599998474121094 53.789001464843750 17.000000000000000
55.450000762939453 54.000000000000000 17.000000000000000
55.500000000000000 53.931999206542969 17.000000000000000
55.700000762939453 53.633998870849609 17.000000000000000
55.750000000000000 53.551998138427734 12.000000000000000
55.750000000000000 53.551998138427734 17.000000000000000
55.799999237060547 53.465000152587891 17.000000000000000
57.499683380126953 57.998001098632812 17.000000000000000
57.500000000000000 57.998001098632812 17.000000000000000
53.188999176025391 57.410999298095703 17.000000000000000
50.671001434326172 56.917999267578125 17.000000000000000
53.410999298095703 57.188999176025391 17.000000000000000
53.689998626708984 57.047000885009766 17.000000000000000
54.000000000000000 56.998001098632812 17.000000000000000
55.939998626708984 -43.750000000000000 17.000000000000000
55.500000000000000 -44.450000762939453 17.000000000000000
-7.828999996185303 59.082000732421875 0.000000000000000
50.500000000000000 58.000000000000000 17.000000000000000
55.341999053955078 -44.650001525878906 17.000000000000000
55.382999420166016 -44.599998474121094 17.000000000000000
48.450000762939453 59.909000396728516 17.000000000000000
48.700000762939453 59.854000091552734 17.000000000000000
-6.502999782562256 53.122917175292969 1.498000025749207
47.849998474121094 59.987998962402344 17.000000000000000
49.000000000000000 59.770000457763672 17.000000000000000
49.049999237060547 59.754001617431641 17.000000000000000
54.811000823974609 57.410999298095703 17.000000000000000
54.589000701904297 57.188999176025391 17.000000000000000
54.310001373291016 57.047000885009766 17.000000000000000
55.675998687744141 -44.200000762939453 17.000000000000000
55.536998748779297 -44.400001525878906 17.000000000000000
52.998001098632812 58.000000000000000 17.000000000000000
53.047000885009766 57.689998626708984 17.000000000000000
50.640724182128906 58.890422821044922 17.000000000000000
53.047000885009766 58.310001373291016 17.000000000000000
53.689998626708984 58.952999114990234 17.000000000000000
53.998001098632812 61.499683380126953 17.000000000000000
53.410999298095703 58.811000823974609 17.000000000000000
53.188999176025391 58.589000701904297 17.000000000000000
48.150001525878906 59.958000183105469 17.000000000000000
48.250000000000000 59.944000244140625 17.000000000000000
48.049999237060547 59.970001220703125 17.000000000000000
48.900001525878906 59.799999237060547 17.000000000000000
48.799999237060547 59.827999114990234 17.000000000000000
-6.501999855041504 56.000000000000000 1.500000000000000
48.549999237060547 59.888999938964844 17.000000000000000
-6.501999855041504 53.125000000000000 1.498000025749207
-6.501999855041504 53.125000000000000 12.000000000000000
-6.501999855041504 55.139965057373047 12.000000000000000
47.650001525878906 59.998001098632812 17.000000000000000
47.750000000000000 59.993999481201172 17.000000000000000
47.950000762939453 59.979999542236328 17.000000000000000
48.299999237060547 59.936000823974609 17.000000000000000
-4.809999942779541 57.047000885009766 12.000000000000000
-4.500000000000000 56.998001098632812 12.000000000000000
48.599998474121094 59.877998352050781 17.000000000000000
-5.089000225067139 57.188999176025391 12.000000000000000
-5.310999870300293 57.410999298095703 12.000000000000000
-5.375555992126465 54.638374328613281 12.000000000000000
-4.500000000000000 54.500000000000000 12.000000000000000
-4.190000057220459 57.047000885009766 12.000000000000000
-5.416999816894531 54.599998474121094 12.000000000000000
-5.469999790191650 54.549999237060547 12.000000000000000
-5.520999908447266 54.500000000000000 12.000000000000000
56.001998901367188 57.998001098632812 12.000000000000000
53.689998626708984 57.047000885009766 12.000000000000000
53.410999298095703 57.188999176025391 12.000000000000000
54.589000701904297 57.188999176025391 12.000000000000000
54.000000000000000 56.998001098632812 12.000000000000000
54.811000823974609 57.410999298095703 12.000000000000000
54.310001373291016 57.047000885009766 12.000000000000000
-5.571000099182129 54.450000762939453 12.000000000000000
-5.618999958038330 54.400001525878906 12.000000000000000
-4.190000057220459 58.952999114990234 12.000000000000000
-3.911000013351440 58.811000823974609 12.000000000000000
-3.688999891281128 58.589000701904297 12.000000000000000
-5.453000068664551 57.689998626708984 12.000000000000000
-5.502999782562256 58.000000000000000 12.000000000000000
-5.453000068664551 58.310001373291016 12.000000000000000
-5.310999870300293 58.589000701904297 12.000000000000000
-4.809999942779541 58.952999114990234 12.000000000000000
-5.089000225067139 58.811000823974609 12.000000000000000
-4.500000000000000 59.002998352050781 12.000000000000000
54.952999114990234 57.689998626708984 12.000000000000000
56.002998352050781 57.998001098632812 12.000000000000000
54.952999114990234 58.310001373291016 12.000000000000000
55.002998352050781 58.000000000000000 12.000000000000000
53.689998626708984 58.952999114990234 12.000000000000000
53.410999298095703 58.811000823974609 12.000000000000000
54.000000000000000 59.002998352050781 12.000000000000000
54.589000701904297 58.811000823974609 12.000000000000000
54.310001373291016 58.952999114990234 12.000000000000000
54.811000823974609 58.589000701904297 12.000000000000000
53.188999176025391 58.589000701904297 12.000000000000000
56.001998901367188 57.998001098632812 1.498000025749207
56.000000000000000 57.998001098632812 1.498000025749207
50.618999481201172 -49.400001525878906 17.000000000000000
50.570999145507812 -49.450000762939453 17.000000000000000
50.520999908447266 -49.500000000000000 17.000000000000000
50.470001220703125 -49.549999237060547 17.000000000000000
56.002998352050781 60.002998352050781 0.000000000000000
56.002998352050781 57.998001098632812 0.000000000000000
56.000000000000000 57.998001098632812 0.000000000000000
56.000000000000000 60.000000000000000 0.000000000000000
57.500000000000000 58.000000000000000 17.000000000000000
57.499683380126953 57.998001098632812 0.000000000000000
57.500000000000000 58.000000000000000 0.000000000000000
57.328998565673828 59.082000732421875 0.000000000000000
56.056999206542969 60.832000732421875 17.000000000000000
56.832000732421875 60.056999206542969 0.000000000000000
56.056999206542969 60.832000732421875 0.000000000000000
55.082000732421875 61.328998565673828 0.000000000000000
54.000000000000000 61.500000000000000 0.000000000000000
54.000000000000000 61.500000000000000 17.000000000000000
57.328998565673828 59.082000732421875 17.000000000000000
57.500000000000000 57.998001098632812 0.000000000000000
56.832000732421875 60.056999206542969 17.000000000000000
55.082000732421875 61.328998565673828 17.000000000000000
54.589000701904297 58.811000823974609 17.000000000000000
54.310001373291016 58.952999114990234 17.000000000000000
54.811000823974609 58.589000701904297 17.000000000000000
57.500000000000000 -48.498001098632812 0.000000000000000
54.952999114990234 58.310001373291016 17.000000000000000
54.952999114990234 57.689998626708984 17.000000000000000
55.002998352050781 58.000000000000000 17.000000000000000
54.000000000000000 59.002998352050781 17.000000000000000
54.310001373291016 -49.452999114990234 0.000000000000000
54.310001373291016 -49.452999114990234 17.000000000000000
54.589000701904297 -49.311000823974609 0.000000000000000
54.000000000000000 -49.502998352050781 0.000000000000000
53.689998626708984 -49.452999114990234 17.000000000000000
53.689998626708984 -49.452999114990234 0.000000000000000
54.000000000000000 -52.000000000000000 0.000000000000000
54.000000000000000 -52.000000000000000 17.000000000000000
55.082000732421875 -51.828998565673828 0.000000000000000
55.082000732421875 -51.828998565673828 17.000000000000000
56.056999206542969 -51.332000732421875 0.000000000000000
56.832000732421875 -50.556999206542969 0.000000000000000
56.832000732421875 -50.556999206542969 17.000000000000000
57.328998565673828 -49.582000732421875 0.000000000000000
53.689998626708984 -47.547000885009766 0.000000000000000
54.000000000000000 -47.498001098632812 0.000000000000000
54.310001373291016 -47.547000885009766 0.000000000000000
54.589000701904297 -47.688999176025391 0.000000000000000
54.811000823974609 -47.910999298095703 0.000000000000000
55.002998352050781 -48.500000000000000 0.000000000000000
55.002998352050781 -48.500000000000000 17.000000000000000
54.952999114990234 -48.189998626708984 0.000000000000000
54.952999114990234 -48.810001373291016 0.000000000000000
52.998001098632812 -48.500000000000000 17.000000000000000
54.811000823974609 -49.089000701904297 0.000000000000000
57.499683380126953 -48.498001098632812 0.000000000000000
53.410999298095703 -47.688999176025391 0.000000000000000
57.500000000000000 -48.500000000000000 0.000000000000000
49.150001525878906 59.720001220703125 17.000000000000000
49.250000000000000 59.683998107910156 17.000000000000000
54.916999816894531 -45.099998474121094 1.498000025749207
54.970001220703125 -45.049999237060547 1.498000025749207
54.000000000000000 -49.502998352050781 17.000000000000000
54.310001373291016 -47.547000885009766 17.000000000000000
54.000000000000000 -47.498001098632812 17.000000000000000
-6.440000057220459 53.250000000000000 12.000000000000000
-6.489999771118164 53.150001525878906 12.000000000000000
-6.359000205993652 53.400001525878906 12.000000000000000
-6.301000118255615 53.500000000000000 12.000000000000000
-6.270999908447266 53.549999237060547 12.000000000000000
-6.239999771118164 53.599998474121094 12.000000000000000
-6.176000118255615 53.700000762939453 12.000000000000000
-6.143000125885010 53.750000000000000 12.000000000000000
-5.842000007629395 54.150001525878906 12.000000000000000
-5.882999897003174 54.099998474121094 12.000000000000000
-5.922999858856201 54.049999237060547 12.000000000000000
-6.072999954223633 53.849998474121094 12.000000000000000
-6.037000179290771 53.900001525878906 12.000000000000000
-6.000000000000000 53.950000762939453 12.000000000000000
-5.961999893188477 54.000000000000000 12.000000000000000
-5.711999893188477 54.299999237060547 12.000000000000000
-5.800000190734863 54.200000762939453 12.000000000000000
-5.665999889373779 54.349998474121094 12.000000000000000
49.400001525878906 59.625000000000000 17.000000000000000
49.500000000000000 59.583000183105469 17.000000000000000
50.549999237060547 58.962001800537109 17.000000000000000
50.299999237060547 59.143001556396484 17.000000000000000
50.250000000000000 59.175998687744141 17.000000000000000
50.400001525878906 59.073001861572266 17.000000000000000
50.450000762939453 59.036998748779297 17.000000000000000
49.950000762939453 59.359001159667969 17.000000000000000
50.099998474121094 59.270999908447266 17.000000000000000
50.150001525878906 59.240001678466797 17.000000000000000
50.500000000000000 59.000000000000000 17.000000000000000
49.700000762939453 59.490001678466797 17.000000000000000
49.599998474121094 59.537998199462891 17.000000000000000
49.549999237060547 59.561000823974609 17.000000000000000
49.299999237060547 59.665000915527344 17.000000000000000
49.799999237060547 59.439998626708984 17.000000000000000
50.049999237060547 59.300998687744141 17.000000000000000
50.599998474121094 58.923000335693359 17.000000000000000
54.000000000000000 -45.000000000000000 17.000000000000000
57.500000000000000 -48.500000000000000 17.000000000000000
3 0 1 2
3 3 4 0
3 3 5 4
3 6 4 5
3 7 8 9
3 10 9 8
3 9 11 7
3 12 13 14
3 15 14 13
3 16 17 14
3 16 18 17
3 19 20 21
3 19 21 22
3 8 22 10
3 23 10 22
3 24 25 2
3 12 14 17
3 18 21 20
3 23 22 21
3 26 11 9
3 11 26 27
3 28 25 27
3 29 2 25
3 29 0 2
3 1 0 4
3 30 15 31
3 20 17 18
3 26 28 27
3 24 27 25
3 30 31 32
3 13 31 15
3 33 34 35
3 35 36 33
3 37 38 39
3 36 35 37
3 40 41 39
3 39 42 40
3 43 44 45
3 34 33 45
3 46 45 33
3 47 48 49
3 47 49 50
3 51 52 5
3 51 53 52
3 54 55 56
3 56 57 54
3 32 31 58
3 59 60 61
3 60 62 61
3 62 63 61
3 54 61 63
3 64 65 54
3 63 64 54
3 66 67 54
3 65 66 54
3 68 69 54
3 67 68 54
3 70 71 72
3 69 73 54
3 6 5 52
3 73 74 54
3 55 54 74
3 75 76 77
3 58 78 32
3 79 80 81
3 82 83 80
3 77 84 85
3 86 84 77
3 87 88 89
3 90 89 91
3 90 91 92
3 93 94 92
3 77 85 75
3 95 96 97
3 98 99 100
3 95 97 98
3 96 101 102
3 82 103 83
3 47 50 61
3 50 104 61
3 104 105 61
3 105 59 61
3 106 107 108
3 109 108 107
3 109 110 108
3 111 112 110
3 111 113 112
3 110 112 114
3 110 114 108
3 115 116 117
3 118 119 120
3 18 16 118
3 121 122 123
3 121 124 125
3 126 127 128
3 129 127 126
3 18 118 120
3 130 131 132
3 122 131 130
3 130 123 122
3 125 128 127
3 129 133 127
3 14 118 16
3 21 18 120
3 23 21 120
3 134 32 135
3 136 135 32
3 137 14 138
3 136 139 140
3 141 140 139
3 51 141 139
3 32 142 136
3 139 136 142
3 15 30 138
3 32 134 30
3 118 14 137
3 15 138 14
3 134 138 30
3 85 84 116
3 143 144 145
3 146 147 145
3 148 149 150
3 151 152 145
3 153 151 145
3 147 154 145
3 144 146 145
3 36 37 155
3 20 36 155
3 12 17 155
3 84 156 157
3 158 159 57
3 160 161 162
3 160 148 150
3 163 54 164
3 165 150 149
3 166 57 159
3 167 31 168
3 169 170 58
3 58 31 167
3 155 171 12
3 171 168 12
3 106 172 57
3 173 174 175
3 176 174 173
3 166 177 163
3 78 58 170
3 6 52 174
3 6 174 176
3 172 90 174
3 166 164 178
3 166 163 164
3 179 180 181
3 178 182 183
3 178 164 182
3 162 184 185
3 186 185 184
3 183 187 188
3 183 182 187
3 167 169 58
3 12 168 13
3 13 168 31
3 188 189 190
3 188 187 189
3 170 191 53
3 52 53 174
3 192 190 189
3 192 193 190
3 43 27 194
3 193 195 196
3 193 192 195
3 176 4 6
3 11 27 43
3 196 197 198
3 196 195 197
3 198 199 200
3 198 197 199
3 191 174 53
3 78 170 53
3 200 199 201
3 202 203 204
3 202 205 203
3 204 206 207
3 204 203 206
3 207 208 209
3 207 206 208
3 209 210 211
3 209 208 210
3 27 24 212
3 176 213 2
3 24 2 213
3 213 212 24
3 43 46 11
3 211 177 159
3 211 210 177
3 177 166 159
3 37 39 155
3 20 19 36
3 19 22 36
3 33 36 8
3 7 11 46
3 46 33 7
3 8 7 33
3 22 8 36
3 201 199 214
3 215 201 214
3 215 216 201
3 216 217 218
3 216 215 217
3 218 219 220
3 218 217 219
3 220 221 222
3 220 219 221
3 222 205 202
3 222 221 205
3 4 176 1
3 1 176 2
3 200 201 106
3 39 41 155
3 38 37 35
3 42 39 38
3 223 224 40
3 46 43 45
3 41 224 155
3 198 200 106
3 224 225 155
3 226 143 227
3 227 143 228
3 17 20 155
3 229 143 230
3 230 143 226
3 231 143 232
3 232 143 229
3 233 143 231
3 234 143 233
3 144 143 234
3 225 235 155
3 235 236 155
3 236 237 155
3 238 143 239
3 143 155 239
3 240 143 238
3 237 241 155
3 241 239 155
3 242 243 228
3 244 143 240
3 226 227 245
3 246 143 244
3 228 143 246
3 245 247 226
3 247 248 229
3 248 249 229
3 250 251 252
3 253 254 255
3 255 256 257
3 258 257 256
3 259 254 253
3 260 257 258
3 258 261 260
3 144 234 262
3 201 216 107
3 107 106 201
3 120 263 264
3 265 236 266
3 267 236 265
3 263 120 268
3 238 239 269
3 270 271 272
3 165 149 273
3 274 272 275
3 276 277 149
3 278 279 280
3 242 228 281
3 278 280 115
3 270 272 274
3 282 278 115
3 86 77 76
3 283 284 285
3 286 283 285
3 287 288 289
3 290 288 287
3 291 292 286
3 289 293 292
3 291 289 292
3 294 86 76
3 295 280 279
3 296 297 298
3 277 251 149
3 273 149 251
3 250 273 251
3 261 252 251
3 251 260 261
3 184 162 161
3 299 160 150
3 300 301 302
3 259 301 303
3 300 303 301
3 302 304 181
3 211 159 158
3 220 222 107
3 158 107 202
3 222 202 107
3 305 306 186
3 307 186 306
3 306 179 181
3 181 307 306
3 178 57 166
3 303 254 259
3 190 193 106
3 106 57 190
3 188 190 57
3 256 255 254
3 183 188 57
3 183 57 178
3 180 302 181
3 156 84 294
3 86 294 84
3 308 302 180
3 309 302 308
3 309 300 302
3 310 311 312
3 198 106 196
3 193 196 106
3 313 314 72
3 315 72 316
3 316 72 317
3 299 161 160
3 317 72 318
3 184 305 186
3 202 204 158
3 318 72 319
3 204 207 158
3 207 209 158
3 319 72 314
3 211 158 209
3 320 321 72
3 216 218 107
3 220 107 218
3 154 322 145
3 323 324 145
3 324 325 145
3 313 72 321
3 326 116 157
3 326 327 116
3 328 329 72
3 322 330 145
3 331 332 117
3 331 333 332
3 330 334 145
3 335 336 72
3 337 338 339
3 337 340 338
3 117 339 338
3 117 332 339
3 329 335 72
3 334 153 145
3 152 323 145
3 331 116 327
3 331 117 116
3 282 115 117
3 320 72 336
3 341 342 149
3 343 341 149
3 344 343 149
3 345 125 282
3 149 145 325
3 346 345 282
3 347 72 348
3 349 72 347
3 350 351 72
3 352 350 72
3 351 328 72
3 325 353 149
3 353 354 149
3 354 355 149
3 355 344 149
3 338 340 356
3 282 338 356
3 357 358 149
3 342 357 149
3 359 356 340
3 360 276 149
3 338 282 117
3 361 362 363
3 363 364 365
3 366 367 368
3 368 369 366
3 352 72 349
3 173 370 371
3 372 366 369
3 369 373 372
3 371 374 173
3 375 376 377
3 378 376 375
3 379 380 381
3 72 382 383
3 72 384 385
3 386 387 388
3 389 386 390
3 391 72 385
3 392 393 386
3 72 394 395
3 311 310 396
3 310 395 396
3 397 390 398
3 399 398 386
3 390 386 398
3 394 396 395
3 400 312 311
3 358 360 149
3 401 132 119
3 402 401 145
3 212 213 403
3 143 145 401
3 194 403 404
3 405 402 406
3 145 406 402
3 43 194 44
3 404 44 194
3 407 408 72
3 395 407 72
3 401 119 143
3 409 410 72
3 411 412 413
3 414 411 413
3 414 415 411
3 416 414 417
3 416 415 414
3 418 417 419
3 418 416 417
3 420 421 72
3 408 420 72
3 422 418 423
3 419 423 418
3 176 374 213
3 421 409 72
3 410 424 72
3 384 72 424
3 425 426 427
3 425 428 426
3 428 429 426
3 428 430 429
3 412 431 432
3 412 433 431
3 412 432 413
3 430 434 429
3 430 435 434
3 374 176 173
3 431 433 436
3 437 399 386
3 438 386 439
3 440 441 442
3 443 442 441
3 444 445 392
3 445 446 392
3 382 72 391
3 447 72 448
3 448 72 449
3 440 450 441
3 444 441 445
3 451 452 441
3 444 453 441
3 454 455 441
3 456 454 441
3 453 456 441
3 457 441 458
3 449 72 459
3 459 72 383
3 460 455 454
3 461 72 447
3 462 403 213
3 348 72 463
3 463 72 461
3 462 213 374
3 464 75 115
3 85 115 75
3 370 173 175
3 457 451 441
3 458 441 465
3 465 441 466
3 466 441 467
3 467 441 468
3 455 469 441
3 469 470 441
3 470 471 441
3 471 472 441
3 468 441 472
3 473 474 370
3 475 441 476
3 476 441 477
3 452 477 441
3 478 479 298
3 480 298 479
3 479 481 480
3 175 473 370
3 482 483 484
3 485 284 486
3 212 403 194
3 445 441 446
3 487 486 284
3 488 460 456
3 489 288 290
3 296 489 297
3 290 297 489
3 478 298 297
3 481 490 480
3 491 492 481
3 490 481 492
3 493 492 491
3 472 471 494
3 470 495 471
3 483 496 484
3 293 289 288
3 286 292 497
3 255 498 499
3 253 499 500
3 253 255 499
3 253 501 259
3 253 500 501
3 501 301 259
3 485 285 284
3 302 502 503
3 302 301 502
3 504 505 304
3 304 503 504
3 493 506 492
3 507 506 482
3 482 484 507
3 435 508 434
3 435 509 508
3 510 511 496
3 512 511 510
3 512 513 511
3 302 503 304
3 436 514 431
3 509 515 508
3 509 516 515
3 517 513 512
3 518 514 436
3 518 519 514
3 516 520 515
3 516 521 520
3 522 304 505
3 523 519 524
3 518 524 519
3 505 486 522
3 525 520 521
3 525 526 520
3 527 526 525
3 527 528 526
3 487 522 486
3 529 528 530
3 527 530 528
3 286 497 283
3 531 532 533
3 531 534 532
3 533 535 536
3 533 532 535
3 536 523 524
3 536 535 523
3 537 529 530
3 537 538 529
3 132 534 531
3 539 538 537
3 539 540 538
3 541 540 539
3 541 542 540
3 543 542 541
3 543 544 542
3 545 544 543
3 545 546 544
3 547 546 545
3 547 548 546
3 493 482 506
3 549 484 496
3 511 549 496
3 517 550 513
3 551 550 517
3 551 552 550
3 476 553 475
3 356 359 551
3 552 551 359
3 289 291 346
3 501 502 301
3 285 346 286
3 485 346 285
3 500 554 501
3 498 555 499
3 289 346 287
3 502 556 503
3 557 503 556
3 501 558 502
3 346 504 503
3 290 346 297
3 287 346 290
3 291 286 346
3 505 504 346
3 297 346 478
3 478 346 479
3 479 346 481
3 486 505 346
3 485 486 346
3 481 346 491
3 491 346 493
3 454 456 460
3 496 483 346
3 493 346 482
3 482 346 483
3 446 393 392
3 496 346 510
3 456 453 488
3 510 346 512
3 356 551 346
3 512 346 517
3 555 554 499
3 517 346 551
3 326 332 333
3 326 157 332
3 195 192 172
3 214 199 172
3 257 498 255
3 215 214 559
3 219 217 559
3 559 560 205
3 560 203 205
3 203 560 206
3 206 560 208
3 208 560 210
3 210 560 177
3 560 54 177
3 164 54 182
3 54 187 182
3 54 189 187
3 54 172 189
3 561 93 562
3 563 564 565
3 565 79 563
3 80 79 566
3 567 548 547
3 567 568 548
3 569 568 567
3 569 570 568
3 80 566 82
3 571 569 572
3 571 570 569
3 101 96 573
3 132 401 534
3 573 88 101
3 574 575 576
3 577 576 578
3 577 574 576
3 579 578 580
3 579 577 578
3 581 580 582
3 581 579 580
3 402 581 582
3 402 405 581
3 583 571 572
3 583 584 571
3 575 585 586
3 575 586 576
3 587 584 583
3 587 588 584
3 423 589 585
3 585 589 586
3 590 588 587
3 590 591 588
3 82 592 103
3 585 422 423
3 590 593 591
3 590 594 593
3 592 474 103
3 332 157 156
3 594 595 593
3 594 596 595
3 596 427 595
3 596 425 427
3 414 435 417
3 430 428 417
3 413 435 414
3 430 417 435
3 597 272 271
3 419 417 428
3 428 425 419
3 423 419 425
3 85 116 115
3 597 271 598
3 598 271 599
3 263 600 264
3 601 264 600
3 602 603 457
3 599 600 263
3 599 271 600
3 270 604 600
3 271 270 600
3 249 232 229
3 413 432 516
3 431 521 432
3 435 413 509
3 509 413 516
3 514 521 431
3 527 525 519
3 516 432 521
3 521 514 525
3 523 530 519
3 527 519 530
3 514 519 525
3 523 535 530
3 537 530 535
3 534 541 532
3 532 539 535
3 401 541 534
3 537 535 539
3 539 532 541
3 541 401 543
3 339 332 605
3 239 606 607
3 600 608 601
3 601 608 131
3 131 608 120
3 268 120 608
3 609 282 610
3 604 611 612
3 613 612 611
3 607 269 239
3 614 240 269
3 476 477 553
3 612 608 604
3 282 609 278
3 270 278 609
3 609 604 270
3 608 600 604
3 356 346 282
3 247 230 226
3 547 545 401
3 543 401 545
3 572 569 402
3 547 402 567
3 567 402 569
3 615 616 610
3 232 249 617
3 618 619 612
3 402 547 401
3 233 617 620
3 613 618 612
3 268 608 619
3 612 619 608
3 270 279 278
3 270 274 279
3 606 241 267
3 609 621 604
3 609 616 621
3 622 339 605
3 156 605 332
3 237 236 267
3 576 590 578
3 587 583 578
3 583 572 580
3 582 580 572
3 402 582 572
3 623 624 625
3 580 578 583
3 594 590 586
3 587 578 590
3 589 596 586
3 423 425 589
3 238 269 240
3 576 586 590
3 596 589 425
3 594 586 596
3 614 626 240
3 441 625 624
3 411 415 434
3 418 426 416
3 429 434 416
3 627 628 376
3 418 422 427
3 422 585 427
3 427 426 418
3 429 416 426
3 415 416 434
3 629 376 628
3 434 508 411
3 508 515 411
3 158 630 627
3 515 520 412
3 412 411 515
3 433 412 520
3 520 526 436
3 436 433 520
3 529 518 528
3 526 528 518
3 518 436 526
3 524 518 529
3 631 632 627
3 629 627 633
3 524 529 536
3 538 540 536
3 533 536 540
3 538 536 529
3 132 531 542
3 531 533 542
3 540 542 533
3 443 441 634
3 542 544 132
3 132 546 548
3 132 544 546
3 635 634 107
3 548 568 405
3 568 570 405
3 636 234 620
3 405 570 571
3 132 548 405
3 637 638 627
3 41 40 224
3 571 581 405
3 571 579 581
3 571 584 579
3 577 579 584
3 584 588 577
3 588 591 577
3 224 223 225
3 574 577 591
3 575 574 591
3 591 593 575
3 235 225 266
3 585 575 595
3 593 595 575
3 595 427 585
3 237 267 241
3 597 598 441
3 625 441 598
3 239 241 606
3 639 640 641
3 642 643 641
3 644 641 643
3 643 645 644
3 646 644 645
3 67 66 647
3 648 649 69
3 626 244 240
3 649 650 69
3 651 652 653
3 654 655 653
3 652 651 656
3 243 227 228
3 656 651 657
3 658 627 659
3 660 627 661
3 661 627 662
3 662 627 663
3 663 627 664
3 664 627 665
3 665 627 666
3 666 627 647
3 647 627 648
3 648 627 649
3 638 650 627
3 649 627 650
3 243 245 227
3 247 229 230
3 197 195 172
3 192 189 172
3 197 172 199
3 658 659 105
3 659 660 105
3 50 49 667
3 628 627 629
3 633 627 668
3 668 627 632
3 49 627 667
3 667 627 658
3 217 215 559
3 635 107 627
3 631 627 49
3 659 627 660
3 630 637 627
3 653 669 651
3 205 221 559
3 219 559 221
3 54 57 172
3 327 333 331
3 327 326 333
3 340 337 359
3 337 622 359
3 163 177 54
3 158 627 107
3 107 634 441
3 175 174 473
3 370 441 371
3 592 441 474
3 374 371 462
3 231 232 617
3 462 441 403
3 233 231 617
3 670 671 672
3 45 44 624
3 624 44 441
3 233 620 234
3 673 670 674
3 404 441 44
3 636 262 234
3 494 471 495
3 113 441 98
3 566 441 82
3 458 675 457
3 676 441 91
3 573 441 88
3 95 441 96
3 96 441 573
3 88 441 676
3 91 441 677
3 677 441 93
3 79 441 566
3 93 441 562
3 562 441 564
3 565 441 79
3 564 441 565
3 678 225 223
3 678 266 225
3 474 441 370
3 109 441 110
3 111 441 113
3 110 441 111
3 107 441 109
3 98 441 95
3 462 371 441
3 404 403 441
3 82 441 592
3 475 553 679
3 452 680 477
3 669 653 655
3 266 236 235
3 681 682 683
3 681 684 682
3 685 682 684
3 684 686 687
3 688 689 690
3 691 690 689
3 244 626 281
3 692 671 686
3 688 655 689
3 674 693 673
3 694 673 693
3 693 695 694
3 696 694 695
3 172 559 214
3 473 174 103
3 131 697 601
3 25 28 264
3 26 264 28
3 698 699 700
3 699 701 700
3 701 702 703
3 702 704 703
3 705 131 706
3 156 706 131
3 707 708 709
3 640 639 708
3 709 708 639
3 642 641 640
3 672 674 670
3 692 672 671
3 705 697 131
3 690 691 710
3 281 246 244
3 281 228 246
3 122 127 156
3 131 122 156
3 127 133 156
3 120 132 131
3 711 712 29
3 712 713 29
3 714 29 715
3 711 29 716
3 29 714 560
3 685 684 687
3 687 686 671
3 713 715 29
3 194 27 212
3 304 522 181
3 560 0 29
3 717 718 467
3 264 719 25
3 487 284 181
3 522 487 181
3 561 562 564
3 284 283 181
3 101 87 172
3 101 172 102
3 102 172 97
3 100 99 172
3 97 172 99
3 80 174 81
3 563 174 720
3 720 174 561
3 561 174 94
3 89 172 87
3 81 174 563
3 83 174 80
3 88 87 101
3 90 172 89
3 92 174 90
3 710 721 690
3 94 174 92
3 103 174 83
3 683 722 710
3 106 108 172
3 108 114 172
3 114 112 172
3 100 172 112
3 283 497 181
3 497 292 181
3 293 288 181
3 292 293 181
3 79 81 563
3 696 695 723
3 700 701 724
3 701 703 724
3 92 677 93
3 721 710 722
3 683 682 722
3 84 157 116
3 92 91 677
3 654 689 655
3 725 696 723
3 723 726 725
3 723 698 726
3 698 700 726
3 703 704 727
3 704 728 727
3 729 727 728
3 707 730 728
3 729 728 730
3 100 112 113
3 707 709 730
3 474 473 103
3 731 726 732
3 732 646 386
3 646 732 644
3 641 732 639
3 644 732 641
3 679 386 646
3 89 88 676
3 651 733 657
3 734 657 733
3 735 733 651
3 651 669 735
3 736 735 669
3 688 737 655
3 477 738 553
3 288 489 181
3 489 296 181
3 298 480 181
3 296 298 181
3 622 181 480
3 480 490 622
3 506 622 492
3 490 492 622
3 507 484 622
3 506 507 622
3 549 622 484
3 549 511 622
3 513 550 622
3 511 513 622
3 552 622 550
3 359 622 552
3 559 141 560
3 599 263 598
3 263 268 625
3 625 598 263
3 739 472 494
3 623 618 613
3 613 624 623
3 619 618 268
3 145 130 406
3 623 625 268
3 145 149 130
3 185 126 128
3 279 274 295
3 185 128 124
3 186 126 185
3 275 295 274
3 162 185 124
3 124 740 160
3 160 740 123
3 160 123 148
3 148 123 149
3 130 149 123
3 162 124 160
3 118 155 119
3 155 143 119
3 118 137 171
3 137 138 171
3 134 135 169
3 169 135 136
3 155 118 171
3 138 168 171
3 134 167 138
3 717 467 468
3 739 468 472
3 168 138 167
3 134 169 167
3 623 268 618
3 680 452 603
3 451 457 603
3 312 734 310
3 741 310 734
3 656 657 312
3 734 312 657
3 475 679 645
3 742 743 455
3 335 744 336
3 469 743 470
3 744 320 336
3 745 329 328
3 351 745 328
3 746 146 262
3 747 317 318
3 352 748 350
3 352 749 748
3 352 349 749
3 349 347 749
3 750 688 731
3 673 731 670
3 671 731 687
3 685 731 682
3 751 752 688
3 736 655 737
3 451 603 452
3 144 262 146
3 444 392 438
3 453 439 488
3 439 453 438
3 444 438 453
3 469 455 743
3 675 458 753
3 754 717 468
3 468 739 754
3 602 457 675
3 690 731 688
3 682 731 722
3 722 731 721
3 721 731 690
3 687 731 685
3 670 731 671
3 737 688 752
3 669 655 736
3 379 634 635
3 627 380 635
3 694 696 731
3 696 725 731
3 673 694 731
3 725 726 731
3 724 732 700
3 700 732 726
3 703 732 724
3 727 732 703
3 729 732 727
3 730 732 729
3 639 732 709
3 709 732 730
3 755 741 756
3 756 734 733
3 757 758 71
3 757 741 755
3 758 757 755
3 734 756 741
3 759 760 761
3 758 762 71
3 313 763 314
3 764 763 321
3 753 465 718
3 738 477 680
3 747 318 319
3 765 319 314
3 764 321 320
3 350 748 766
3 351 767 745
3 766 351 350
3 495 470 743
3 609 610 616
3 610 121 615
3 615 121 125
3 621 768 604
3 611 604 768
3 335 769 744
3 466 467 718
3 770 771 746
3 616 615 621
3 768 621 615
3 771 770 772
3 768 770 611
3 615 345 768
3 772 768 345
3 125 345 615
3 742 455 460
3 316 773 315
3 70 315 773
3 768 772 770
3 317 774 316
3 773 316 774
3 774 317 747
3 319 775 747
3 765 775 319
3 466 718 465
3 320 776 764
3 777 252 778
3 779 769 329
3 76 760 294
3 252 777 780
3 761 760 76
3 781 780 772
3 780 777 772
3 777 782 772
3 783 784 498
3 555 498 784
3 783 778 784
3 777 778 782
3 782 785 772
3 786 787 772
3 785 786 772
3 701 788 702
3 702 788 704
3 556 502 558
3 704 788 728
3 728 788 707
3 558 501 554
3 500 499 554
3 789 736 737
3 789 735 736
3 707 788 708
3 400 733 735
3 708 788 640
3 783 782 778
3 642 640 788
3 790 656 400
3 652 656 790
3 312 400 656
3 735 790 400
3 750 791 751
3 751 791 752
3 737 792 789
3 790 735 789
3 786 276 787
3 793 791 750
3 794 752 791
3 785 276 786
3 752 794 737
3 792 737 794
3 251 277 782
3 787 795 772
3 795 796 772
3 653 652 790
3 257 783 498
3 558 303 556
3 300 556 303
3 558 554 303
3 254 303 554
3 797 798 179
3 799 557 309
3 300 309 556
3 309 557 556
3 273 780 781
3 800 165 781
3 273 781 165
3 801 165 800
3 802 299 801
3 299 802 803
3 804 305 805
3 806 305 804
3 797 179 806
3 180 179 798
3 802 801 345
3 781 772 800
3 800 772 801
3 772 345 801
3 799 798 346
3 503 557 346
3 346 806 345
3 802 345 803
3 805 345 804
3 804 345 806
3 346 797 806
3 798 797 346
3 799 346 557
3 791 793 689
3 794 791 689
3 792 654 789
3 794 689 792
3 788 689 793
3 793 807 788
3 465 753 458
3 803 345 805
3 778 261 784
3 258 784 261
3 778 252 261
3 808 788 464
3 788 809 464
3 809 788 810
3 250 780 273
3 75 811 812
3 811 75 813
3 814 815 464
3 784 258 256
3 816 814 464
3 75 464 813
3 254 555 256
3 816 464 809
3 815 813 464
3 784 256 555
3 780 250 252
3 810 788 807
3 254 554 555
3 394 72 817
3 812 817 75
3 597 441 272
3 783 260 782
3 475 645 818
3 818 272 475
3 251 782 260
3 272 818 819
3 272 819 275
3 295 275 819
3 629 820 376
3 820 629 821
3 822 821 668
3 821 629 633
3 668 632 822
3 475 272 441
3 632 823 822
3 464 115 824
3 705 824 115
3 464 824 825
3 788 808 818
3 280 705 115
3 280 697 705
3 825 826 818
3 819 818 826
3 697 280 827
3 295 827 280
3 827 819 826
3 827 295 819
3 828 829 830
3 785 782 277
3 787 276 360
3 831 828 830
3 785 277 276
3 832 833 834
3 832 834 835
3 835 836 837
3 706 760 836
3 260 783 257
3 825 808 464
3 180 799 308
3 825 818 808
3 799 309 308
3 838 828 831
3 838 831 833
3 803 161 299
3 805 184 803
3 161 803 184
3 837 836 760
3 294 706 156
3 294 760 706
3 805 305 184
3 179 306 806
3 180 798 799
3 731 829 828
3 829 732 839
3 829 731 732
3 840 838 833
3 833 832 840
3 801 150 165
3 835 841 832
3 801 299 150
3 806 306 305
3 826 825 264
3 839 264 829
3 825 829 264
3 697 826 601
3 141 559 172
3 282 122 610
3 282 127 122
3 622 605 133
3 706 836 705
3 831 825 833
3 833 824 834
3 824 705 834
3 835 834 705
3 836 835 705
3 307 126 186
3 307 129 126
3 830 829 825
3 831 830 825
3 824 833 825
3 121 610 122
3 127 282 125
3 133 129 307
3 53 139 78
3 78 142 32
3 140 170 136
3 697 827 826
3 633 668 821
3 627 376 380
3 367 634 379
3 379 635 380
3 788 818 645
3 646 645 679
3 439 386 488
3 488 386 460
3 393 437 386
3 392 386 438
3 460 386 742
3 742 386 743
3 743 386 495
3 494 386 739
3 495 386 494
3 739 386 754
3 717 386 718
3 602 386 603
3 718 386 753
3 753 386 675
3 762 812 761
3 761 812 759
3 814 842 843
3 816 844 814
3 842 814 844
3 386 845 839
3 732 386 839
3 816 846 844
3 847 848 807
3 847 807 750
3 733 400 756
3 756 396 755
3 311 396 756
3 755 396 758
3 601 826 264
3 762 817 812
3 759 811 849
3 843 849 813
3 810 848 846
3 758 394 762
3 850 851 852
3 361 852 851
3 853 851 850
3 377 854 715
3 759 812 811
3 813 849 811
3 361 363 852
3 815 843 813
3 814 843 815
3 854 853 855
3 771 146 746
3 855 715 854
3 848 810 807
3 750 807 793
3 754 386 717
3 675 386 602
3 311 756 400
3 679 553 386
3 738 680 386
3 553 738 386
3 394 758 396
3 680 603 386
3 817 762 394
3 856 61 714
3 856 857 61
3 560 714 61
3 856 858 859
3 859 860 362
3 859 858 860
3 861 862 860
3 862 861 863
3 816 809 846
3 846 809 810
3 373 864 865
3 397 866 867
3 867 868 397
3 869 870 871
3 869 872 870
3 381 716 719
3 873 378 711
3 712 711 378
3 390 397 868
3 390 868 871
3 388 845 386
3 716 381 711
3 714 853 856
3 856 853 858
3 850 852 858
3 860 858 852
3 850 858 853
3 860 874 861
3 874 860 852
3 34 45 624
3 373 369 864
3 853 714 855
3 855 714 715
3 624 613 746
3 613 611 770
3 861 874 863
3 872 863 874
3 869 871 875
3 871 868 875
3 868 264 875
3 719 716 25
3 243 624 245
3 242 624 243
3 245 624 247
3 247 624 248
3 636 620 624
3 248 624 249
3 249 624 617
3 617 624 620
3 29 25 716
3 876 719 264
3 223 40 624
3 678 223 624
3 266 678 624
3 265 266 624
3 267 265 624
3 606 267 624
3 607 606 624
3 269 607 624
3 614 269 624
3 626 614 624
3 839 845 264
3 864 264 865
3 875 877 869
3 281 626 624
3 877 863 869
3 378 375 712
3 770 746 613
3 262 624 746
3 347 878 749
3 765 314 763
3 313 321 763
3 875 264 845
3 872 869 863
3 335 329 769
3 329 745 779
3 320 744 776
3 351 766 767
3 835 837 841
3 879 878 347
3 828 848 731
3 751 688 750
3 840 844 838
3 750 731 847
3 76 71 762
3 847 731 848
3 848 838 846
3 832 844 840
3 846 838 844
3 842 841 843
3 759 849 760
3 843 841 849
3 837 760 849
3 841 837 849
3 841 842 832
3 844 832 842
3 364 863 877
3 440 398 450
3 820 821 61
3 820 61 376
3 378 873 376
3 821 822 61
3 880 399 881
3 823 48 61
3 398 880 450
3 48 47 61
3 881 441 880
3 822 823 61
3 880 398 399
3 380 376 873
3 446 881 437
3 880 441 450
3 446 441 881
3 57 56 158
3 366 372 443
3 366 443 634
3 63 62 663
3 713 375 715
3 48 632 631
3 882 851 853
3 661 662 62
3 662 663 62
3 665 666 66
3 666 647 66
3 860 862 362
3 863 364 862
3 876 369 719
3 876 864 369
3 866 883 865
3 884 865 883
3 866 397 883
3 63 663 664
3 377 715 375
3 648 68 647
3 74 650 638
3 713 712 375
3 637 55 638
3 74 638 55
3 637 630 55
3 865 884 373
3 630 56 55
3 630 158 56
3 885 886 772
3 771 772 886
3 873 711 381
3 154 147 885
3 885 772 887
3 888 772 889
3 889 772 890
3 890 772 891
3 891 772 892
3 89 676 91
3 890 891 153
3 887 322 885
3 154 885 322
3 888 322 887
3 889 330 888
3 889 334 330
3 334 889 153
3 890 153 889
3 48 631 49
3 887 772 888
3 344 355 893
3 894 355 895
3 896 323 892
3 65 664 665
3 897 323 896
3 898 325 897
3 899 325 898
3 354 899 895
3 795 358 796
3 787 358 795
3 900 341 901
3 902 341 900
3 34 624 38
3 242 281 624
3 35 34 38
3 262 636 624
3 40 42 624
3 42 38 624
3 564 720 561
3 564 563 720
3 172 174 141
3 894 895 772
3 772 893 894
3 136 170 169
3 772 896 892
3 897 896 772
3 899 898 772
3 191 170 140
3 174 191 141
3 900 901 772
3 893 772 901
3 140 141 191
3 897 772 898
3 772 895 899
3 796 902 772
3 902 900 772
3 133 181 622
3 886 147 771
3 133 307 181
3 100 113 98
3 99 98 97
3 142 78 139
3 53 51 139
3 102 97 96
3 903 461 904
3 146 771 147
3 886 885 147
3 93 561 94
3 153 891 151
3 892 152 891
3 905 420 408
3 888 330 322
3 906 907 410
3 409 908 410
3 909 908 421
3 909 421 420
3 741 395 310
3 354 895 355
3 382 910 383
3 911 391 385
3 912 911 384
3 385 384 911
3 912 384 907
3 757 407 395
3 906 410 908
3 913 909 420
3 879 347 348
3 879 348 463
3 461 903 463
3 447 904 461
3 914 449 459
3 459 383 914
3 864 876 264
3 344 893 901
3 897 324 323
3 360 358 787
3 357 342 796
3 915 916 449
3 449 914 915
3 894 893 355
3 448 916 447
3 901 343 344
3 463 917 879
3 918 914 383
3 448 449 916
3 904 447 916
3 324 897 325
3 368 381 719
3 901 341 343
3 391 919 382
3 357 796 358
3 902 342 341
3 902 796 342
3 151 891 152
3 409 421 908
3 913 420 905
3 905 408 407
3 424 410 907
3 892 323 152
3 899 353 325
3 424 907 384
3 918 383 910
3 910 382 919
3 919 391 911
3 920 407 757
3 920 905 407
3 917 463 903
3 365 870 872
3 899 354 353
3 337 339 622
3 406 130 132
3 119 132 120
3 123 740 121
3 128 125 124
3 124 121 740
3 141 5 560
3 5 3 560
3 51 5 141
3 120 264 26
3 3 0 560
3 605 156 133
3 757 395 741
3 658 104 667
3 437 881 399
3 440 442 921
3 372 921 442
3 867 264 868
3 442 443 372
3 874 852 363
3 866 264 867
3 865 264 866
3 64 63 664
3 853 854 882
3 650 73 69
3 70 773 71
3 773 774 71
3 774 747 71
3 747 775 71
3 775 765 71
3 50 667 104
3 763 71 765
3 763 764 71
3 776 71 764
3 59 660 60
3 64 664 65
3 871 389 390
3 871 870 389
3 365 872 363
3 660 59 105
3 368 719 369
3 661 60 660
3 76 75 72
3 72 71 76
3 762 761 76
3 75 817 72
3 874 363 872
3 665 66 65
3 67 647 68
3 648 69 68
3 823 632 48
3 658 105 104
3 661 62 60
3 367 366 634
3 387 877 875
3 71 779 745
3 769 779 71
3 744 769 71
3 387 845 388
3 387 875 845
3 767 766 71
3 749 878 71
3 749 71 748
3 748 71 766
3 776 744 71
3 440 921 398
3 9 10 120
3 26 9 120
3 767 71 745
3 71 878 879
3 10 23 120
3 918 71 914
3 911 71 919
3 907 71 912
3 912 71 911
3 910 71 918
3 919 71 910
3 73 650 74
3 393 446 437
3 757 71 920
3 913 905 71
3 913 71 909
3 908 71 906
3 906 71 907
3 909 71 908
3 838 848 828
3 645 643 788
3 642 788 643
3 61 54 560
3 856 859 857
3 790 789 653
3 653 789 654
3 654 792 689
3 710 691 788
3 672 692 788
3 672 788 674
3 689 788 691
3 681 683 788
3 710 788 683
3 681 788 684
3 684 788 686
3 686 788 692
3 920 71 905
3 914 71 915
3 71 916 915
3 916 71 904
3 904 71 903
3 903 71 917
3 917 71 879
3 387 922 877
3 315 70 72
3 877 922 364
3 674 788 693
3 693 788 695
3 873 381 380
3 377 376 61
3 364 363 862
3 362 862 363
3 859 362 361
3 361 851 859
3 851 882 859
3 882 854 61
3 61 857 882
3 857 859 882
3 922 870 364
3 695 788 723
3 723 788 698
3 698 788 699
3 699 788 701
3 854 377 61
3 381 368 379
3 367 379 368
3 365 364 870
3 922 387 870
3 387 386 870
3 389 870 386
3 398 883 397
3 921 372 373
3 373 884 921
3 884 883 398
3 398 921 884
