- To:
- Subject: Re: [cgal-discuss] Repair a self-intersecting triangle mesh
- Date: Wed, 19 Jul 2023 13:14:57 +0200
- Authentication-results: mail3-relais-sop.national.inria.fr; dkim=none (message not signed) header.i=none; spf=SoftFail ; dmarc=fail (p=none dis=none) d=inria.fr
Is a a fixed version
-- Bruno
On 7/19/23 13:11, Giles Puckett wrote:
Attached here as an OFF file.
G.
On 19/07/2023 5:22 pm, Sebastien Loriot ( via cgal-discuss Mailing List) wrote:Could you share the mesh?
Best,
Sebastien.
On 7/19/23 09:15, Giles Puckett wrote:
Thanks Sebastien,
Unfortunately remove_self_intersections returns false (and the mesh is unchanged, still returning the same self intersections as before). This is with CGAL 5.5.1, if anything has changed since.
G.
On 19/07/2023 3:54 pm, Sebastien Loriot ( via cgal-discuss Mailing List) wrote:Hello,
you can try CGAL::Polygon_mesh_processing::experimental::remove_self_intersections()
provided by CGAL/Polygon_mesh_processing/repair_self_intersections.h.
If you only have local self-intersection, it usually works very well.
For listing all intersecting triangles use `self_intersection()`
https://doc.cgal.org/latest/Polygon_mesh_processing/group__PMP__intersection__grp.html#ga6c5bed399d14ddbba820ce50d3145712
HTH,
Sebastien.
On 7/19/23 07:04, Giles Puckett wrote:
Hello all,
I have a triangle mesh that contains self-intersections (PMP::does_self_intersect returns true) but it is otherwise manifold. Is there an easy way to repair these meshes?
If not, would it work to enumerate all the self-intersecting triangles, delete them from the mesh, and fill the holes left behind? Is there a good way to do this, or would some other method work better?
I suspect that the affected area is very small, so gross physical distortion is unlikely to result.
mesh_fixed.off
Description: model/geomview-off
- [cgal-discuss] Repair a self-intersecting triangle mesh, Giles Puckett, 07/19/2023
- Re: [cgal-discuss] Repair a self-intersecting triangle mesh, Sebastien Loriot, 07/19/2023
- Re: [cgal-discuss] Repair a self-intersecting triangle mesh, Giles Puckett, 07/19/2023
- Re: [cgal-discuss] Repair a self-intersecting triangle mesh, Bruno Levy, 07/19/2023
