coq-club - Strange non-wellformed error with Coinductive types
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: Strange non-wellformed error with Coinductive types
  • Date: Mon, 29 Dec 1997 19:45:23 +0100 (MET)
Hello,
we are facing a strange error with proofs of Coinductive predicates,
involving names.  In the following, we will explain it in a very
simple and useless case, but the same problem arises in a real (and
MUCH MORE complex) case.
--- beginning of Coq V6.1 code
(* Let's take a nonempty set *)
Parameter N : Set.
Axiom     x : N.
(* and define a coinductive predicate, whose only constructors takes
 * a proof of A over all N
CoInductive A : Prop :=
  a: ((n:N)A) -> A.
(* We can prove without problems the following lemma, which let us
 * to prove an universal quantification by proving an existential one
Lemma WEIRD : (Ex [n:N]A) -> (n:N)A.
Intros; Inversion_clear H; Assumption.
Qed.
(* Now, we want to prove the following lemma *)
Lemma FOO : A.
Cofix; Apply a; Intro.
(* 1 subgoal
  FOO : A
  n : N
   A
 The shortest way would be
Apply FOO.
Qed.
 which would lead to
 FOO = CoFix FOO{FOO : A := a [_:N]FOO}
     : A
 But we take a longer way (because in the real case we are facing,
 there is no choice): we reduce the universal quantification to the
 existential one, and then give it a witness.
Apply WEIRD with 2:=n.
(* 1 subgoal
  FOO : A
  n : N
   (Ex [_:N]A)
Exists x.
(* 1 subgoal
  FOO : A
  n : N
   A
  And now, like before, we try to close with FOO.
Apply FOO.
Qed.
(* But Coq loudly complains about a non-guarded occurrence of FOO:
(Cofix; Apply a; Intro).
Exists  x.
Apply FOO.
Error: Definition not in guarded form
        The recursive definition
       (a [n:N](WEIRD (ex_intro N [_:N]A n FOO) n)) is not well-formed
during command
Save.
--- end of Coq listing
Actually, the proof can be carried out as desired if we do not prove
WEIRD as a separate lemma, but rather inside the main proof: we
introduce it by means of a Cut, and prove it like in the lemma:
--- begin of Coq listing
(* As before... *)
Parameter N : Set.
Axiom     x : N.
  a: ((n:N)A) -> A.
Lemma FOO : A.
Cut (Ex [n:N]A).
(* 2 subgoals
  FOO : A
  n : N
   (Ex [_:N]A)->A
subgoal 2 is:
 (Ex [_:N]A)
First goal is the former WEIRD lemma *)
Intro; Inversion_clear H; Assumption.
(* Second goal is the last part of FOO *)
Exists x.
(* 1 subgoal
  FOO : A
  n : N
   A
  And now we close with FOO.
Apply FOO.
Qed.
Print FOO.
     : A
So, why does Coq complain if we use a "named" lemma, instead of an
"unnamed" one? Does this mean that we cannot use lemmata in proving
(some) coinductive predicates? And what in the case WEIRD is an axiom,
instead of a lemma? In such case, there would be no proof to "expand"
within another one - there would be no solution at all...
Thanks in advance,
Ivan and Marino
